K2-4 Bronco - Topless with interior. This is my Scaler for the W.Pa.C. club runs for this year. We just had a GTG today and the Bronco performs as well as I had hoped. Here is my build thread from our W.Pa.C. Site: I have too many things I want to do and not enough time to do it, so I decided to only have a Scaler this year. I parted out my comp truck and started to piece the Bronco back together. I have a brand new body that will have full fenders...flairs and all. K2-4S chassis Mamba Max ESC Holmes Hobbies Scorpion Brushless RC4WD R2 tranny RPP Hobbbies Beadlocks Mud Slingers Rs4-MT shocks with 4-links in front Mini-T shocks with leafs in rear Full Interior Full bed This is with my old cut up body as it stands now. http://img.villagephotos.com/p/2002-...0305081503.jpg I was going to do coil springs up front, but took the easy way out and just 4-linked it. http://img.villagephotos.com/p/2002-...305081507a.jpg It's got leafs in the rear with my own home-made shackles. Used a half-link from a bike chain. http://img.villagephotos.com/p/2002-...0305081504.jpg Hard to see in the pic, but the design lets the rear droop more than a normal set up. http://img.villagephotos.com/p/2002-...0305081505.jpg Mini-T shocks seem to be fine on the rear and look pretty scale. I used small springs inside the shocks and no oil. I'm probably going to do some sanding/grinding on them and the mandatory white paint. http://img.villagephotos.com/p/2002-...305081505a.jpg This setup gives me a full bed area...no wanna-be 1/4" deep bed here! :twisted: http://img.villagephotos.com/p/2002-...0305081507.jpg Driveshaft angles seem fine. I had to tilt the trans down in the front a little to clear my links, but seems like it will be fine. http://img.villagephotos.com/p/2002-...0305081502.jpg |
Here's a peak "under the hood". http://img.villagephotos.com/p/2002-...305081416a.jpg I bought this expensive electronics box and it came with a brushless motor...go figure! http://img.villagephotos.com/p/2002-...0305081416.jpg It won't be water-proof, but should be pretty water and mud resistent. I'll probably make a gasket and seal around all the wires...as long as it's not submerged, it should be fine. It hides all the wires and holds the battery. |
This Bronco will have a full bed and interior. This is the start of the bed...a PVC pipe cap. The one in the pic is a 3", but for my truck I needed the 4". http://img.villagephotos.com/p/2002-...0310081307.jpg First I cut it in half, then figured out how tall and wide I wanted it and cut it down to size. I laid it out on some plexiglass. http://img.villagephotos.com/p/2002-...310081307a.jpg I bolted the fenderwheels down and then cut out the plexi. http://img.villagephotos.com/p/2002-...0310081515.jpg Checking out the fit. Another couple pieces would complete the sides. http://img.villagephotos.com/p/2002-...0310081518.jpg Sides are done. http://img.villagephotos.com/p/2002-...0310081726.jpg Looks like a bed! http://img.villagephotos.com/p/2002-...310081726a.jpg Shot it with some truck bed coating and set it in place. http://img.villagephotos.com/p/2002-...0310081821.jpg http://img.villagephotos.com/p/2002-...0310081823.jpg More to come! |
I was under the "crunch time" to get this finished...so not too many actual build pics available from here. She's finished with a simple red paintjob. I was shooting for something more elaborate, but wanted to get this done for the GTG. The spare tire was just sort of thrown in there for now. Still need to do the front fenderwheels and protect the wiring. http://img.villagephotos.com/p/2002-...0316081143.jpg http://img.villagephotos.com/p/2002-...0316081144.jpg http://img.villagephotos.com/p/2002-...316081144a.jpg http://img.villagephotos.com/p/2002-...316081144b.jpg http://img.villagephotos.com/p/2002-...0316081145.jpg http://img.villagephotos.com/p/2002-...0316081105.jpg |
Very nice! I like your fender idea. "thumbsup" |
man that looks good"thumbsup""thumbsup""thumbsup" |
Nice looking Bronco! |
Thanks guys. The ABS / PVC pipe cap seemed like the easiest way to make the bed. I have a couple pieces left that should make nice fenderwheels for the front. |
the bed looks awesome |
another cool bronco , and my is not finish............... |
Holy crap you've done one heck of a job with that build. Without a doubt my favorite K2-4 build-up. Well done "thumbsup" 8) |
That is great. Very clean "thumbsup" |
Thanks everyone. kaetwo - At first I wasn't sure how I was going to make everything work out, but the combination of your chassis and the R2 transmission give good clearance both above AND below the frame rails. It really allowed me to build the full interior and gives 2 5/8" of clearance under the tranny. Once I started building, the ideas just came. Here is a pic showing the clearance and the mild angle of the driveshafts...no binding issues here! http://img.villagephotos.com/p/2002-...0317080821.jpg The motor is on the rear side of the transmision due to lack of space in the front from running a 4-link. http://img.villagephotos.com/p/2002-...0317080819.jpg Overall body off shot. I use industrial velcro and foam weatherstripping under the body to hold it on...works great and NO bodymounts to break or show. http://img.villagephotos.com/p/2002-...0317080817.jpg Rear leafs and shackles actually flex pretty good. http://img.villagephotos.com/p/2002-...0317080813.jpg Mini-T shocks turned down and detailed. http://img.villagephotos.com/p/2002-...0317080815.jpg Door panels and center console are from a Bratz Caddy. The shifter is just a bolt. http://img.villagephotos.com/p/2002-...0317080810.jpg http://img.villagephotos.com/p/2002-...0317080811.jpg Can't find 'em...grind 'em! http://img.villagephotos.com/p/2002-...0317080812.jpg Nobody likes a smart-azz! http://img.villagephotos.com/p/2002-...0317080809.jpg |
damn!!! she looks great"thumbsup" can't wait to see that in person. |
Looks pretty good for a Ford! JK.... nice rig man. I like what you did w/that chassis No more comp rig, what's up w/that? |
Really looks great. You definatly did a nice job. Is that the Undertaker driving?:lol: |
Just not enough time for all my hobbies! I'll be on the dirt bike more since my brother is cancer-free and just bought a new bike. Roadtrips on the Harley and family time will take some of the time, too. Truthfully, I ran my Scaler more at our GTG than I probably ran my comp truck all of last season...and it was great. |
Ah...no...it's a 1:10 scale version of me...only with 1:6 scale muscles! ;) :lol: http://img.villagephotos.com/p/2002-...eandHarley.jpg |
My mommy doesn't want me to get any! |
