Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Project Tundra Frist Highlift Build
Old 09-26-2009, 04:11 PM   #1
Arrow Project Tundra Frist Highlift Build
Hello Everyone. This is my frist highlift truck build. have alot of plans for the truck. I have gotten the truck body painted and the flares mounted, and the snorkel mounted. Click the image to open in full size.[/IMG] Click the image to open in full size.[/IMG]I am not sure yet if i will mount the tundra light bar or a roll bar from a f350. Click the image to open in full size.[/IMG] Click the image to open in full size.[/IMG]I have moved the battery from under the truck to in between the rear frame rails. This is going to be slow build . Did not relize the cost involed.
Samuel01 is offline   Reply With Quote
Old 09-26-2009, 04:21 PM   #2
fixed you links for you
onecleanjetta is offline   Reply With Quote
Old 09-27-2009, 06:20 AM   #3
Thanks very new at this
Old 09-27-2009, 11:11 AM   #4
any suggestions on what servos to run, will not be in comp, just backyrad bashing?
