Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: fj crusier build
Old 09-27-2009, 09:35 AM   #1
Default fj crusier build
Well this is my first attemt at a scale build . I started with a nikko fj crusier from a few years ago thats been sitting around, and then there was my axial ax-10 rtr. So i bought the x-trail chassiis, and have had alot of fun making it fit the 10 1/2" wheelbase of the body. So on with the specs.
x- trail frame
futiba reciver
intella speed ecs.
stock axial servo
rock lizards
homemade links
14t racing motor
start
whats done for now
mandatory flex shot
After Makeover
New link mount, Axel truss
rch8r is offline   Reply With Quote
Old 09-27-2009, 10:05 AM   #2
Nice. I always liked those bodies.
theslowguy is offline   Reply With Quote
Old 09-27-2009, 11:14 AM   #3
thanks im going to see how it works on the trails shortly
Old 09-27-2009, 12:39 PM   #4
that turned out nice!!
pvtjrt01550 is offline   Reply With Quote
Old 09-27-2009, 01:14 PM   #5
Well i just got back from a test run, and other then somedrive shaft issues mounted it upside down [switch on trail] it worked great. i am switching back to the 27t for better battery life. i think some 1.9s are def in the future. Heres some pics.
thanks for the replys, tires bumpers, and rock sliders next.
Old 10-03-2009, 11:56 AM   #6
So I took it out for a trail ride today, after making the rear 4-link. Worked amazing!! After running and tuning, I decieded to do a four wheel burnout, 14t makes this fun. Well i ended up with traction couseing a wheelie into flip down 25ft enbankment. Enough said on to pics.
set-up pre flip
set-up after flip
body damage {stayed mounted to frame}
Old 10-03-2009, 12:32 PM   #7
blakeski's Avatar
with your 4 link like that , dont you get sway in it?? i had my links set up like that and the rear end sway back and forth??
blakeski is offline   Reply With Quote
Old 10-03-2009, 01:16 PM   #8
I didn't notice any, sitting it felt really stiff, running it only lasted 10 or 15 mins. but it did good while it was running.
Old 10-03-2009, 02:34 PM   #9
time to slap some body armor on that thing!!
Old 10-03-2009, 08:35 PM   #10
I'm going to get some tubing tomm. I'm doing bumpers, sliders. Now i need to deciede on a color to paint it.
Old 10-04-2009, 09:53 AM   #11
do an exo-cage! i have an FJ cruiser body sittin in my garage but its like a 10" wheelbase was going to hack up an MRC to build it, but workin on a JK rightnow. front links need to be shortened it looks like, other than that looks good!
Arnel is offline   Reply With Quote
Old 10-04-2009, 01:13 PM   #12
yeah the wheel base is just a hair off. I have to play around with it some more. I'm actulley thinking about build a whole new frame for it, and getting a tundra or f-350 body for the tcs frame. thanks for the complament. Exo cage would def be sweet, I've got some learning to do before that comes.
Old 10-04-2009, 02:50 PM   #13
Get some 1/4" delrin rod and make some shorter links!
Old 10-04-2009, 10:01 PM   #14
I've got about 4ft of 3/16 threaded rod. I just have to get it done.
Old 10-05-2009, 09:25 AM   #15
Tnaks i got hooked real quick after looking st some of the other builds on here.
