Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Like Tree2Likes
Thread: Little TJ
Old 10-10-2009, 09:46 PM   #1
Rally Rally Rally
TURTLE's Avatar
Default Little TJ
Ok, so it wont be that little when I slap some rubber on it.
Anyway, I started this project about two weeks ago, I got sick of never going all the way with a scaler so I decided to do it this time, I started looking around for YJ's but kinda out of my price range and alot are popping up every where. I decided to sit on it a couple days...
The next day I went on my usual thrift store runs only to look down and see this nikko R/C TJ sitting on the ground, I grabbed it and was stoked, first thing I thought of was I need a tape measure! A little old lady next to me happen to have one and gladly pulled it out of her purse and allowed me to use it.
The dimensions are almost identical to the YJ so for 7.99 I figured what the hell, I could probaly use something on it at some point anyway.
Well I quickly knew where I wanted to go with this project, I wanted to build a scaler that I was proud of and actually want to keep for more then a month. I have wanted to model something similar to some aspirations I have for my TJ, so here it is.
Going for as scale as possible, its a huge advantage that most of the interior is a bolt on system.
Ended ip pulling out stock seats and using some recaro seats I had sitting around, they ended up being a much better fit. Raised them off the floor and BAM!
The dash is almost 100% stock how it came in the Nikko R/C, all I had to do was lay down some paint.
I did have to drop the floor, I was sick of the elevated look of everything so the back and front had to go down, I did opt. for a functional tunnel though.
As it sits now. Its a really cool body the grill, windshield, head lights, and a radiator are all snap on inserts.
I have also opt'ed for a warn style rock slider out of some styrene.
I still have tons of detail work to do, along with some touch ups, body paint radiator, bumpers and cage, but its coming along body wise.
Now the tech stuff, I trade to use what I had sitting around for most of the parts, what I didn't I worked out some trades and what not.
I had one scale chassis, it was a MSD ute, it was way to big, buts its what I had, so I cut both sides of the chassis down. Fits now.
I picked up some parts of a transfer case from Crawlin Coles, I needed bearings and gears, but it happen to be stuff I had sitting around.
I also had some axial axles so that made it an easy axle choice.
Im still some what in limbo with what tires and wheels to use. Im thinking about some roc lox, but they might be a bit to monster trucky, we will find up in mock up.
Ty
TURTLE is offline   Reply With Quote
Old 10-10-2009, 10:09 PM   #2
R2j
I'M ON IT!
R2j's Avatar
Looks like a good start. What are you using for running gear? And is there going to be any tube work? I'm getting ready to start a scaler for myself finally. Just need to get Rodney's done first.
R2j is offline   Reply With Quote
Old 10-10-2009, 10:34 PM   #3
Rally Rally Rally
TURTLE's Avatar
Yeah, Im planning out a pretty aggressive style cage around the front seats, Im still thinking about a front and rear bumper, I will probably do something pretty simple just to protect the body. I don't want to hurt the approach and departure angles to much.
Old 10-10-2009, 10:37 PM   #4
R2j
I'M ON IT!
R2j's Avatar
Sounds good! Can't wait to see it. You going to do any of the scale events?
Old 10-10-2009, 10:42 PM   #5
Rally Rally Rally
TURTLE's Avatar
I would like too, I would also like to make it to Montana this coming year.
Old 10-10-2009, 11:23 PM   #6
[HOONIGAN]
RPMJ's Avatar
Looking good Tyler, I can't wait to see it finished. We would really like to see you at the local scale events. Now how's the other Jeep body coming along?
RPMJ is online now   Reply With Quote
Old 10-11-2009, 01:35 AM   #7
Rally Rally Rally
TURTLE's Avatar
I layed down some paint on the body tonight.
Not sure if Im happy with the color or not. I'll start some detail work tomorrow and see if that helps.
Ty
Old 10-12-2009, 01:03 AM   #8
Rally Rally Rally
TURTLE's Avatar
Thanks Rodney, just waitin on you to start the cage work.
Well I spent a ton of time this weekend building stairing and trying to figure things out with my creation.
I grabbed a few more parts I had sitting around (old links, etc.) I mocked it up with the stock axle width and I just could not get it to sit as low as I wanted and still have the aggressive profile I was after, I kept trying to figure out what it needed, I almost went to a different axle, then I realized I had some wideners sitting in a bin, slapped em on and got a profile I was more comfortable width.
I also starting doing some detail painting work, and scavanged some shocks from one of my RC18t's. they look alright but I only get 3" of flex overall, I might do something else, but Im trying to stay away from a droop suspension set up.
I had some 2.1 inch traxxas (pin slot) wheels sitting around since I built the croc 1 and never did anything with them. I mocked them up and realized there is no way they will fit the bead. So Im keeping my options open for some new wheels...
I have to admit the Roc Loxs look awesome, but they are way way way bigger then the 5.2" RC4WD website does, hell they are bigger then my Rovers... Despite the size I kind of like the monster trucky look she has right now.
Outside of tire to outside of tire I am sitting at 10 7/8" as of right now...
Im pretty happy with most of it so far, I, however have know idea how I am going to mount the body or where in the chassis the steering servo is going to go...
Im trying to make it really capable and am well aware that there are some strict guidelines for competition for these, but I am thinking rear steer or dig, not to mention a winch... I can always disengage it for comps.
Ty
Old 10-12-2009, 02:13 AM   #9
wow looking sic.. i been thinking about the same setup but i was worried about COG and flex also. ill be wtching to see how u go with the suspension.
ati2de22 is offline   Reply With Quote
Old 10-12-2009, 08:25 AM   #10
hitman46mod's Avatar
Monster Jeep looks good though.
hitman46mod is offline   Reply With Quote
Old 10-12-2009, 09:53 AM   #11
damn, didn't realize the rock lox were so tall, can you post a pic with a ruler next to them?
I've got rovers on my big hummer for now, but something a little larger, yet still capable would be perfect, plus the tread pattern is cool too.
monkeyracer is offline   Reply With Quote
Old 10-12-2009, 12:11 PM   #12
Rally Rally Rally
TURTLE's Avatar
Yeah Im still unsure about it, For now I might just put a longer shaft in the shocks and mount them a bit higher to get a better look on them. If the shocks do stay on I have some threaded metal body ones that will take the place of the plastic.
As of now link geometry is a little up in the air, the rear will probably get a three link and the front is going to get some type of panhard set up to account for the steering.
Thanks man.
Yeah Ill get that up later tonight for ya.
Old 10-12-2009, 01:39 PM   #13
whats the wheelbase set at now? maby some styrene body extention to keep things in porportion. u are right the monster look to is awsome.
Old 10-12-2009, 02:30 PM   #14
Rally Rally Rally
TURTLE's Avatar
The wheel base right now is just over 12". Im not quite sure what you mean by extensions, care to elaborate?
Here is the general look I was after.
Then just imagine it with a tire like this on it.
Ty
Old 10-12-2009, 02:36 PM   #15
I put these on my Pirate this weekend
15mm Wheel Wideners for AX10. You do have to use the old lock out not straight axial
saydee1800 is offline   Reply With Quote
Old 10-12-2009, 02:40 PM   #16
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
I am not a Jeep guy, but this thing is bad arse.
chip cross is offline   Reply With Quote
Old 10-12-2009, 03:20 PM   #17
[HOONIGAN]
RPMJ's Avatar
That is F-ing sick.......
We have to get to work on mine.
Old 10-12-2009, 03:46 PM   #18
this is the idea i had. hope this helps
Old 10-12-2009, 09:37 PM   #19
Rally Rally Rally
TURTLE's Avatar
They are some pretty cool lookin tires.
Thanks Buddy!
We made a little progress today bud.
Yeah that first one is about where I am going, Im just thinking no front bumper just a small spot to set a winch down.
Got started on the cage this afternoon, I'll try to get some photos up soon.
Old 10-12-2009, 09:44 PM   #20
0 0
romulus22's Avatar
Ty
i know the tires are out there but have never seen a tire that big in person. looking at this picture makes me think, thats just silly
romulus22 is offline   Reply With Quote
