Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: First Scaler Project
Old 10-30-2009, 02:55 PM   #1
Default First Scaler Project
Ok so this is probably going to take a bit beacuse Im expecting a little girl to pop out anytime but thought I would post what I have so far to keep me motivated. Started with a AX10 RTC and made a chassis from delrin from a template I found here (Ill post the source when I get back home). Doing a F150 flatdeck but might change that up.
bboybean is offline   Reply With Quote
Old 10-31-2009, 01:43 PM   #2
nice start, and gl.
custumrig is offline   Reply With Quote
Old 10-31-2009, 03:03 PM   #3
what part of alberta????
check this out
http://www.crawlcanada.com/
looking good so far
canadianlimited is offline   Reply With Quote
Old 11-30-2009, 04:27 PM   #4
Ok so still working on the chassis but spending most of my time on the body. Im hopefully getting the chassis done soon but until then just using the stock AX10. took it out today and ended up sinking it after crashing through the ice. After working on this body I think Its not really what I want after all. I also traded my dad for his RTR beadlocks, I wasnt really feeling the green.
The snow + a 75T dont really go well together, If I dont need to replace the electronics I may pick up some new gears.
Im from the Edmonton area so If there are others that know some good places to crawl pppplllleeeeeaaasseee let me know lol.
Old 12-01-2009, 07:21 PM   #5
Just dumping some more pics, thanks for lookin
Old 12-03-2009, 08:44 AM   #6
Should I get a 8.4 or 9.6v battery or a used Tekin 2.4 Tx/Rx ? I havent put caps on my Integy 75T and its a little glitchy (not too bad).
Old 12-04-2009, 06:47 PM   #7
I was debating a similar thought not too long ago. I ended up with a Tx/Rx...
Would it be possible to get more close up pics on the chassis? I wanted to try and make my own frame using delrin so I wanted to use your rig as my baseline
mangus7175 is offline   Reply With Quote
