Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Few scale questions (frame, axles, body..)
Old 10-31-2009, 12:34 PM   #1
Default Few scale questions (frame, axles, body..)
Well the whole comp thing isn't for me, and I want to convert my crawler into a scaler. I currently have a axial setup with a torsion chassis. I want to take this and make a scaler out of it. Here is what I am hoping you guys can help me out with:
What is the best aftermarket frame for these (preferably in steel if they make it so that I can weld to it)
Does nayone make a Flatfender body for the 1:10 scale rigs?
Are the axial axles fine for this, or should I be looking at other options?
Should I go brushless, or is a brushed motor just fine? Also what sized motor should I run on here?
I am in the build process of a 52 CJ3A for a 1:1, so I was hoping to "copy" this build in a scaler. I would like to build the cage out of some reular tubing (not al). I don't know how to braze, but I can weld all day.
Thanks
DIma
Flatty is offline   Reply With Quote
Old 10-31-2009, 03:06 PM   #2
motor i would stay with a brushed motor. i have heard brushless not so good for water. and i know my scaler like water
as for tubing brake line 3/16 and 1/4 inch make sure not the coated stuff use the silver stuff. you can weld it, braze it and solder it
canadianlimited is offline   Reply With Quote
Old 10-31-2009, 03:48 PM   #3
The SCX10 chassis kit would be a good start, I've seen a few people weld to it, you'll just have to paint it or something afterwards.
http://www.axialracing.com/ftp/ax10o...frame_set.html
BigB_117 is offline   Reply With Quote
Old 10-31-2009, 07:57 PM   #4
2D
Harvo's Avatar
Any idea of the wheelbase on that? Website doesn't specify. :?
Harvo is online now   Reply With Quote
Old 10-31-2009, 08:46 PM   #5
Fumb Ducker
DonsATV's Avatar
The wheel base on my brand new SCX-10 is 11 5/16".
DonsATV is offline   Reply With Quote
Old 10-31-2009, 09:57 PM   #6
The stock scx10 kit is about 11.5 but that determined by the suspension links. You can use longer or shorter ones to set it where you need it.
