| | #1 |
| Paradox Team Leader ![]() Join Date: Jan 2006 Location: The PARADOX NATION
| I have started the design process for my scaler... 3/16th brakeline cage/chassis fully gusseted custom 1:1 t-case planetary tranny not sure on the motor yet,,possibly BL later rear motor ds8711 servo winch ds8711 steering servo,,,probably axle mounted,,unsure at least a partial interior lipo power wheels,,unsure but probably Axial to start out lights Aluminum handformed pie tin skins,,,gotta hav ethe rock rash paint,,leaning towards desert camo Here's a snapshot of the cad,,its still in design stage,,but its close Last edited by rmdesignworks; 11-15-2009 at 12:26 PM. |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: May 2008 Location: in the shop
| That is going to look great im sure. are you going for sort of scale aperance or more comp crawler styler |
| | #3 |
| going for a combination of both,,it as to be scale in appearance but have some seriously adjustable articulation to comp in scale or 2.2,,im gonna make the interior removable so i can lighten it up for 2.2 comps but have the interior for scale comps im working the chassis/cage to support a winch on a removable plate and the lights will be removable too,,the chassis meets usrcca rules for 2.2 bodiless too im also planning on making axle trusses and skids,,and im using my inverted reversed 3 link set up like on my comp rig,,only ill make the links out of tubing with perf'd skids,,and adjustable upper links Last edited by rmdesignworks; 11-15-2009 at 02:16 PM. |
| | #4 |
| in the pic,, bottom view split view top view working on gussets and steel panel sections |
| | #5 |
| Rally Rally Rally ![]() Join Date: Feb 2006 Location: Hooning
| What kind of wheel base and roof height are you looking at? |
| | #6 |
| hey Ty,,the cad has the wb at 12.5,,might move it in a bit,,still to be determined,,the cad also shows it sitting at a roof height of 7.125" and a belly clearance of 3.3" which i'll lower down from that |
| | #7 |
| So are you going to build some shock hoops? how long of a shock are you going to run? |
| | #8 |
| i have plans to braze in steel strips for mounts for links and shocks,,so probably some where around a 70mm shock up front and 80-85mm in the rear the cad above is drawn with about 5.5" tires and the one below is dropped on around 4" tires...10.8"wb,,6.3"roof height,,2.6" belly clearance |
| | #9 |
| do you think it would look better with shock hoops? im looking at the pic out of cad and i can see hoops front and rear on it |
| | #10 |
| Ty,,i really like the squat look of your TJ,,,and i like the longer wb with the 2.2's and maybe some rovers or similar tires,,more gc,,more stable imo and if i go full droop i can bring it way down on the 5.5's im gonna make a wooden modl for making the body tins,,that way i can make a raised hood panel that can get all F'd up,,and make replacements real easy Last edited by rmdesignworks; 11-15-2009 at 08:49 PM. |
| | #11 |
| im thinkin about doin a cut n shut on some Rovers,,take about an inch out of the center,,keep em at 2.2's but much narrower....does anyone know who makes some 1/2" wide Solid Delrin wheels? Eritex? |
| | #12 |
| I think you should rock one of rc4wd scale tires. I was thinking it would be cool if you took a hilux hardbody and cut all the panels apart and bolted them on to this. |
| | #13 |
| I'M ON IT! ![]() Join Date: Dec 2008 Location: Johnstown,CO
| Hey enough chit chat! Lets see some tube! I got started on my 1.9 this week, check out my build thread. |
| | #14 |
| Hey Shon,,Thanks for the ups,,,i have been watching your build,,,im in a bit of a pickle right now money wise,,this is still in planning stage anyway,,,but yeah it will defintely be detailed,,I just went through all of Robbob's thread on his FUnBuggy,,,im definitely going for something like that,,well ok i know ill be scratching the bedliner off the frame long before it gets done. ive figured out how im doing the t-case in the sub-floor under the seats,,,im gonna try a scale engine like Robbob's too,,,but id like to go Ford or Dodge...im figuring the 2S lipo will fit inside the radiator behind the seats,,and im gonna try to run all the wire in the tube work. I might even go for a negative grounded chassis using an isolator between the lipo and the tubework connection. servo winch up front with over body wedge pulleys for side pulling too,,i was thinkin about doing the steering like Robbob has his,,but I wasnt sure if it would work,,but after seeing his I now know it would. maybe a small gear box to cover the input linkages and a 1:1 2 gear set up to drive the steering wheel instead of doing a second micro servo for that. i also saw a very small mp3 player recently that would be cool to record cb radio recordings on and i have an amp circuit that could run a 1.5-2" speaker,,one thing i know for sure is if i go for all the scale details i am gonna be de-casing most of the electronics and waterproofing them,,i think ill mount the esc on the roof in a roofrack in a "cooler" or "roofbag" Last edited by rmdesignworks; 11-19-2009 at 08:46 PM. |
| | #15 |
| ive gone through a lot of the scale threads and there are some damn nice rigs out there,,but they are pretty much the same10 or so bodies....not my cup of tea,,so i'm gonna stick with the handformed tin skins i originally planned on making,,,plus i like the idea of rock rash and torn and then repaired body panels,,heavier stuff in certain places on the rig but the main skins will be the disposable baking tins from the grocery store,,,i can easily make a mold for the hood piece and all the other panels will be formed in place |
| | #16 |
| Ty,,it looks like you are probably gonna what you asked for,,a cut and paneled Yota,,I have dug out my hand carved foam Toyota 22R motor,,I still have a ways to finish the motor,,it needs to be glued up and finish painted,,,it needs exhaust, wiring, an air breather, pulleys and belts,,but I think it will be a nice touch for a scale tuber,,I'll get some pics when I can. Stay tuned. I'd really like to do this build with the new RC4WD Yota 4-Runner body Last edited by rmdesignworks; 11-27-2009 at 08:48 AM. |
| | #17 |
| Please excuse the quality of the pics,,cell phone pics are all I could get as my wife left the camera at the in-laws The motor is done in approx. 1/8th,,it is being supported by a wire on a 2.2 Proline Memory foam insert for size comparison Thos motor represents 9 pieces of 1" blue construction foam hand carved to closely represent a Toyota 22R motor like the one I had in my 1:1 87 Toy Pick up Last edited by rmdesignworks; 11-27-2009 at 10:51 AM. |
| | #18 |
| Pebble Pounder Join Date: Oct 2008 Location: albuquerque
| Thats pretty detailed. I like!! |
| | #19 |
| thanks dezslash,,it will look even better all wired up,,workin on it,,i am also glueing up a v8 block to carve it out,,,3 blocks of 1" thick foam,,as soon as the glue dries i'll get started on it |
| | #20 |
| I'm probably not going to use it,,cuz I'd like to have a V8 in the scaler,,but the motor turned out pretty nice... |
| Thread Tools | |
| Display Modes | |
