02-22-2010, 11:38 PM | #1 |
Rock Stacker Join Date: May 2007 Location: Pascagoula,Ms
| csc-1 rebirth
Well i was into r/c cars and trucks years ago and i got out of it in 2007 after building a 2.2 scale rig and now im getting back into it.....but im lost in all this brushless and lipo stuff! im redoing my rig and need some help on a setup. what i have so far is- custom scale CSC-1 frame Locked pede tranny Locked tlt axles 2 tlt shocks traxxas radio and reciever futuba s3305 steering servo narrowed rims with proline masher 2ks Now what i need- motor....ive been out the scene so long i dont know whats good, but i want something fairly inexpensive esc.....same as above front shocks????? gearing???? i have some pics that i was just messing around with it and mocked up some links for the rear and i still need to make a link mount for the uppers on the front. So any suggestions on the things i need? |
02-22-2010, 11:39 PM | #2 |
there were only a few csc-1's made and ive looked at all the builds and none really show how the front servo and links are mounted so if anyone has any ideas i would apreciate it. thanks |
02-23-2010, 02:56 AM | #3 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Just like any other axle, one link to both knuckles & one link from the servo to either knuckle.
02-23-2010, 05:55 AM | #4 |
02-23-2010, 05:41 PM | #5 | |
http://rcpcrawlers.com/product.php?p...&cat=17&page=1 or this http://rcpcrawlers.com/product.php?p...&cat=17&page=1 0r this http://rcpcrawlers.com/product.php?p...&cat=17&page=1 or this http://www.montanascaledesigns.com/s...432upr15gshmb6 or this http://www.montanascaledesigns.com/s...432upr15gshmb6 | |
02-23-2010, 06:29 PM | #6 |
thanks a ton for those links....i have been looking and i think im gona get the last one posted. also looking at getting the moped esc and a JPH 23t motor.....does that sound like a good combo? thanks for helpin the newb out! |
02-23-2010, 07:16 PM | #7 |
played with the suspention a bit and took some poser shots.....still need to get my link mounts for the front and make all my links, i just made some quick mock up links out of old rod ends and some plastic stock. what rod ends are yall guys using? |
02-25-2010, 09:23 AM | #8 |
Ordered a moped v16r ESC.... Picked up some 6/32 threaded rod.........what rod ends do i use? I had some old traxxas ones laying around but there 4-40 thread. And im going to try my Trininty D5 Flatwire 19t motor in it! Thanks, Caleb |
02-25-2010, 06:41 PM | #9 |
No comments? anyone even remember the CSC-1 chassis'? anyway today i used some scrap metal and formed me up a link/servo mount really quick....works perfect. kinda hard to see in this pic now this weekend ill try to go to hobbytown and grab some rod ends, tubing to cover the links and some screws to mount my links up. then wait for my esc to get here and ill give her a trial run! |
02-25-2010, 07:08 PM | #10 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
That chassis looks great! Lots of great parts have come out since 2007. Looks like you have good flex. Stay with brushed motors for now. They give better drag braking anyway. Get a good ESC with a drag or hold brake. Novak Rooster Crawler ed., Mamba Max, Tekin FXR, Holmes Hobbies, etc. With a normal pede trans and TLT axles, a 45-55t motor with a 6-7 cell will be fine. Can run a 2/3a cell pack on the front rails (over front axle). Your old charger will prob charge these. Looks like the chassis was set up for a sub-C 6cell stick pack laying in front of the trans. Could stick with it for now. Lots of run time. If you want to go Lipo, can go with a +/-2000mah pack accross the rails. Need a Lipo charger and balancer though. What steering servo are you running? You'll want some power up there and some amps pushing it. Some esc's give you less then 3a BEC current, and none that I have used give you adjustable BEC voltage. Might consider running a Castle Creations BEC. Adjustable voltage, so you can bump it up to +/-6v, and it will give you 5a continuous. Lots of great parts for TLTs too! Straight axle rear lockout kits. RCP lockers. High clearance front knuckles and alum C's. |
02-25-2010, 09:07 PM | #11 |
Thanks! im running a futuba s3305 steering servo and i ordered a moped v16r esc i want wheelspeed so i was going to get a 23t from JPH later on, but for now i got a old trinity d5 flatwire 19t and yea i have a battery mount i made for a 6cell team orion 3000mah stick pack and a superbrain 959 charger still need to get some rod ends for my 6/32 rod but not sure which ones? and some tubing to sleeve them. Last edited by 87bigblazer; 02-25-2010 at 09:21 PM. |
02-25-2010, 09:20 PM | #12 |
WOW, 9/32 rod, that is beefy! My LHS has some associated rod ends that are huge, but I cannot remember what rig they are a spare part for. Sure it's 9/32? 8/32 and 10/32 are more standard sizes. RC4WD carries up to 8/32 and 5mm in their metal rod ends. Hate to spend that kind of money on something to drill out, but there is enough meat there to do it, if you have a 9/32 tap. http://www.rc4wdstore.com/2/index.ph...dc8d70076ad259 |
02-25-2010, 09:22 PM | #13 |
doh! 6/32 is what i meant! nice catch lol
02-25-2010, 09:25 PM | #14 |
Mcmaster Carr carries 10/32 nylon swivel ends. $3.50ea http://www.mcmaster.com/#rod-ends/=5z9y06 Also carry alum and steel versions of 6/2, 8/32 and 10/32. These might be the Associated ones. They are for 1/8th Nitro trucks. 5.4mm balls, so by scale, it looks like 5+mm rod size. http://www3.towerhobbies.com/cgi-bin...5121&search=Go Last edited by sweli; 02-25-2010 at 09:31 PM. |
02-25-2010, 09:38 PM | #15 |
i read somewhere u can use traxxas ???? rod ends but cant find what the part number is or what vehicle they are used on?
02-26-2010, 04:39 AM | #16 |
These are the Traxxas ones that a lot of guys use, but not sure they will take 6/32. http://www3.towerhobbies.com/cgi-bin...&I=LXKMD6&P=FR Tmaxx end links will work with 6/32. Info might be buried here: ~Link Size Questions~ |
02-27-2010, 01:59 AM | #17 |
im gona head to the hobby shop hopefully sunday and get some tubing and rod ends.....i pluged up my old novak rooster and a team orion 3000mah batt and the battarys are done for i think.....i set up my super brain charger at 0.5a and a 30mv setting.....i was hoping a few cycles would revive em but theve been sitting for several years discharged.....oh well, whats a good battery pack to run? i was looking at a cheapbatterypack.com Elite 5000. any suggestions are welcome. thanks |
