Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Toyota Truggy, the latest
Old 02-04-2006, 05:34 PM   #1
Default Toyota Truggy, the latest
Well since my other truggy thread is soo long I decided to start a new thread. So here's the latest, I went to the Mini Hammers and went thru some drivelines. Then I got a bit bored with going slow and swapped out the lather motor for a mag mayhem and changed the gearing. It hails arse now(for a crawler) but snapped both drivelines at the yoke within 2 minutes. The pede shafts can't handle the ponies I guess. I also finally got the ultra narrowed Duratrax wheels all glued up with some Moabs and Losi uncut firm foams. Since the truck is so heavy they should help more than hurt. Once I get some more pede shafts I'll test out the foams.
Oh, I'm also looking at sinking the tranny into the frame. Though I'm not sure how yet.
rckjeep is online now   Reply With Quote
Old 02-04-2006, 08:04 PM   #2
Over-Rev's Avatar
why dont you upgrade the shafts?were they metal yokes?
Over-Rev is offline   Reply With Quote
Old 02-04-2006, 08:08 PM   #3
CSR
I like the other thread better.... it had pics! Come on, let's see the skinny wheels!
CSR is offline   Reply With Quote
Old 02-04-2006, 08:15 PM   #4
Yes....Show me some pics!!
Going Up! is offline   Reply With Quote
Old 02-04-2006, 08:16 PM   #5
we want pics
Fordx4 is offline   Reply With Quote
Old 02-04-2006, 08:26 PM   #6
I'll get some up soon. I left my camera in thew womans ride and she's out of town tonight. Sorry, The wheels are pretty sweet looking. They're double narrowed Duratrax maximum ST's painted silver then partially painted flat black with (3rd)Rock Rings, of course. They are between 1 1/8" -1 1/4" wide. They fit the Moabs well.
Old 02-05-2006, 01:52 AM   #7
Interesting, I have a mag mayhem in my Original RBX with the plastic pede shafts and never twisted them!
RandyatBBY is offline   Reply With Quote
Old 02-05-2006, 01:54 AM   #8
Ya, I ran one in my Bulu too, but the weight of this thing and the gearing are the issue. Plus the traction of Moabs. Oh and yes I run metal yokes, the issue is the plastic shafts pop off under a good load.
Ok here's the pics
here's the cut & uncut wheel
Old 02-05-2006, 02:49 AM   #9
Oh Sorry for needing it spelled out ot me your truck is way heavy:-)
Old 02-05-2006, 02:55 AM   #10
how about some maxx shafts?
skyjacker_rc_club is offline   Reply With Quote
Old 02-05-2006, 08:27 AM   #11
I'm not sure if you can.. but my suggestion is to use some square stuff... I found some perfect size square tubes and they are slip fit with each other.. and just braze them onto your new steel yokes.. If you think thats week, then go with a small solid square, hex, or spline rod and braze it to your new steel yokes..
BTW.. I get goosebumps when I look at that rig or yours.. Pure jealousy..!
skipstr71 is offline   Reply With Quote
Old 02-05-2006, 12:58 PM   #12
looks good i really like the way all those trail rigs look
Old 02-06-2006, 12:43 AM   #13
Well I had an idea to reduce the angle on my driveshafts and it went together well. Check it out. A CV driveshaft.
It didn't work though. The joints are just to loose. Oh and I was at Sportsmart today getting some pellets for my new air rifle when I found a box of Daisy slingshot ammo in a neat little plastic box. It'll make a nice scale cooler or toolbox, plus gives you a bunch of 1/4 steel balls for weight in your tires. I'll post some pics tomorrow.
Old 02-06-2006, 09:13 AM   #14
Haters gonna Hate
1BadJeepBruiser's Avatar
Dave, the truggy looks sweet man, I have a question on that driveshaft you made, you say it didnt work? that it was to loose? what was to loose? My 4runner has some serious steep drive shaft angles and I am trying to figure something out what will work...Your idea there looks pretty good.
Mike
Old 02-06-2006, 10:05 AM   #15
Well the CV portion came unscrewed within seconds and the metal yoke to CV joint took all the angle but when rotating the CV to shaft joint would stay straight. So when the truck rolled forward the driveshaft would flop around. It was good in theory.
Old 02-06-2006, 10:10 AM   #16
2006 2.2 National Champ
BENDER's Avatar
A carrier bearing will fix it. But, it may be more of a hassle then it's worth.
BENDER is offline   Reply With Quote
Old 02-06-2006, 12:03 PM   #17
Haters gonna Hate
Gotcha, The angle on my truck is steep but it doesnt bind...guess ill just have to stick with it for now.
Mike
Old 02-06-2006, 12:34 PM   #18
Location: a place of settlement, activity, or residence.
Are you having any problems with rounding out the hex on the wheels due to the weight? I just got through wasting two stampede wheels.
thaclodking is offline   Reply With Quote
Old 02-06-2006, 01:03 PM   #19
I did round out some wheels, I just glued them in and it's been fine. I don't remember exactly what the weight of my tuber Ralph was, maybe JIA can chime in. But I didn't have any issues with it. So I'm kinda stumped as to why I'm having some issue's. Mine doesn't bind at all, but I think when under extreme load the angle makes it weaker.
Old 02-06-2006, 11:50 PM   #20
chino63's Avatar
dave, i had the same problem on my mountaineer. you could use t/e maxx shafts but get the heavy duty "x" part #'s. the yokes eventually wear out but last quite awhile. or option #2, get some old bruiser mounty shafts or juggy shafts. a little pricey, but they work. i am using the bruiser shaft for my rear, works great. waiting for tower to get the juggy shafts in stock (all steel not brass). the other thing i was thinking about using was some old snap-on 1/4 drive universal sockets. you would have to make custom shafts and drill/tap set screw holes but you would never break them. not sure if they are too big to use on the 1/10 stuff. most have an offset pin block for greater angularity also.
chino63 is online now   Reply With Quote
