06-22-2010, 08:40 AM | #1 |
| eric113's TTC FJ Current Setup Front Axle Axial wraith stock housing Axial universals Hot racing locker FastEddies bearings Axial HD gears VP bearing caps VP diff cover STRC aluminum chubs Axial stock knuckles Rear Axle Axial stock wraith housing Axial Universals FastEddie bearings Hotracing locker Axial HD Gears VP bearing caps VP diff cover STRC aluminum chubs Axial stock knuckles Axial steering arms Rolling Stock Vanquish Products SSZ-9's Stock axial foams Axial 2.2 whitedot ripsaws Vanquish Products SLW 225 hubs Transmission Traxxas 2 speed summit transmission FATTBATT fab trans mount Driveshafts Traxxas Maxx shafts Traxxas Maxx yokes - Jason modded Suspension RockCrawler stainless steel links Traxxas revo rod ends Traxxas revo rod ends Proline power stroke scaler shocks Chassis and Body Axial Scx10 chassis R2J tube work FATTBATT Fab CMS servo mount RC Screwz stainless steel screws Proline bushwacker body Fattbatt electronics tray Power and Control Castle Creations Mamba Maxx Pro esc Castle Creations BEC Pro Tekin 3300kv pro brushless motor Hitec HS7950 x 2 Hitec ? shift servo Quicksand winch Heyok HV winch controller 2200mah 3s lipo packs Last edited by eric113; 09-04-2012 at 08:06 PM. |
06-22-2010, 09:43 AM | #2 |
Sick Eric I was looking forward to the pics. Any plans to narrow it or are you gonna run it wide? What body?
06-22-2010, 02:38 PM | #3 |
06-22-2010, 02:46 PM | #4 |
06-22-2010, 02:47 PM | #5 |
Just give up already. |
06-22-2010, 02:48 PM | #6 |
06-22-2010, 07:30 PM | #7 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
Looks like a coat hanger job to me. |
06-24-2010, 05:37 PM | #8 |
06-24-2010, 09:58 PM | #9 |
Quarry Creeper Join Date: Feb 2008 Location: Pittsburgh PA
More pics, Get'r done, More Pics, Action videos. Looks good man, Lance |
06-24-2010, 11:47 PM | #10 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
What are the width of those axles? Those might make for some nice 1/6 scalers
06-25-2010, 06:03 AM | #11 |
06-28-2010, 05:57 PM | #12 |
First Thanks sloppy for finding these knuckles. I searched and searched for place that carried the DF-03 dark impact knuckles that were in the u.s. Finally found a place. http://www.thetoyz.com/cart/thetoyz_...9492&cat_name= Wanted to show the difference in height. Looks like I'm going to have make tall shock hoops to keep the panhard bar and tie rod level. You can see the diffence between stock knuckles and 3racing knuckles. They help angles out alot. Wish G-made would come out with their own hi steer knuckles. Last edited by eric113; 06-28-2010 at 06:27 PM. |
06-28-2010, 06:22 PM | #13 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Great work Eric. The new Knuckles look the part, how much improvement do they offer. |
07-01-2010, 07:14 AM | #14 |
Quarry Creeper Join Date: Nov 2006 Location: land of make believe
x2 on Gmade making their own high steer knuckles. DF-03 knuckles didnt last the first run.
07-01-2010, 11:29 AM | #15 |
Pebble Pounder Join Date: Jun 2010 Location: belgium
nice build so far one to watch |
07-01-2010, 02:02 PM | #16 |
The countersunk screw in the knuckle is classy.
07-01-2010, 02:20 PM | #17 |
RCC Addict Join Date: Jun 2005 Location: Prosser
Looks good, but with my experience from the TLT days and those knuckles, be careful, they are very weak...
07-07-2010, 07:50 AM | #18 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
Cool build Eric! Now it needs some tube work! |
07-30-2010, 02:19 PM | #19 |
Quarry Creeper Join Date: Aug 2004 Location: Virginia Beach
Any updates on this, how about the knuckles?
10-21-2010, 10:48 PM | #20 |
First off I'd like to say thank you Eric for being so very patient! I've had this for a while, but is now full steam ahead. Thanks E! Spent some time getting it to sit lower so the stock dimension could be used for the shocks. Modified the shock/lower link mounts by removing the shock mount part, thanks sloppy, and moved the shocks down with the links. Perfect now and nice and smooth. Next, worked on getting the Summit trans lower. Found a pretty good mod for the jason mount. Instead of using the Delrin spacer/mount, I bent the bracket in the brake and wella. Bolts right down on the skid it's self and lowered it about a 1/2". Now for some of what the tube work is going to look like. Should be sending this home mid week next week.....yah! Last edited by R2j; 10-21-2010 at 10:57 PM. |
