Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: it wont be heavy
Old 04-06-2006, 12:20 PM   #1
perfictsib's Avatar
Default it wont be heavy
A while ago I put some pics up of my axle gaurds I made, some one said when am I going to make a chassie, the pics show how far i am into the build
perfictsib is offline   Reply With Quote
Old 04-06-2006, 12:22 PM   #2
perfictsib's Avatar
some more pics and the reason there is only one chassie rail is i havent cut it down the middle yet
Old 04-07-2006, 04:26 PM   #3
perfictsib's Avatar
Angry
well i done some more to it tonight welded rear shock mounts on and nearly cut chassie the full length into two halfs, when my dremel packed in so i got the air die grinder out all going well, untill i run out of cutting discs 2" from the end will get more tomorrow so i can make the cross members and put the 2 halfs together
Old 04-07-2006, 04:35 PM   #4
Looking good!
taazzukcb is offline   Reply With Quote
Old 04-08-2006, 09:34 AM   #5
perfictsib's Avatar
finished getting it cut and this is what it looks like at moment
Old 04-08-2006, 09:47 AM   #6
Nice- thats a good way of making the two side the same-I hadn't thought of that! Looks good keep the picts coming.
chaotic_life is offline   Reply With Quote
Old 04-08-2006, 10:16 AM   #7
That's a freakin awsome Idea.
It looks like it's turning out nice.
Cole82 is offline   Reply With Quote
Old 04-08-2006, 10:29 AM   #8
perfictsib's Avatar
its not to hard to cut it straight down the middle, but next time i do it im going to score the box section first before i weld bits on, it just needs cleaning up with file now.
Old 04-08-2006, 12:10 PM   #9
thats killer scale work, hope its done soon
Magic is offline   Reply With Quote
Old 04-08-2006, 03:47 PM   #10
perfictsib's Avatar
thanks for all your kind replies will post more pics when i get more done
Old 04-08-2006, 05:38 PM   #11
Get off my lawn!
microgoat's Avatar
Very nice, that's usin' your head. Looks a lot like Buster Gonna weld in the crossmembers, or bolt 'em?
microgoat is online now   Reply With Quote
Old 04-10-2006, 10:49 AM   #12
perfictsib's Avatar
i am going to weld crossmembers in later i had 2 days off it, learned a few things while making it (1 dont change design halfway when making it or problems later) (2 frame needs tweaking each time you send 185 amps through it) (3 only tack weld stuff on or its a bugger to remove after) pic below show how frame rails should of been marked in red, and blue is how i done them, the frame was designd to accept laydown or standup tranny, but this one is now only standup i got two more to make after this one is finished. so long as i keep the center at the required length the others will be ok. the pic shows diffront ideas i had and didnt like.
Old 04-10-2006, 03:23 PM   #13
perfictsib's Avatar
got 2 crossmembers in tonight. just got battery tray, skidplate , and radio gear tray left to do but i couldnt resist putting front axle on to see how it looks what a shock i got when i did that it was high 3.1/2 " under chassie, so i put battery on and all the other stuff it needed to run and it dropped to 2.1/2" sigh of relief, plus there still some other bits to be added like bullbar, rear bumper and spare wheel took 2 pics for all of you.
Old 04-10-2006, 06:22 PM   #14
Get off my lawn!
microgoat's Avatar
Looks great, but it's going to be pretty tippy with the battery way up there. Got any shorter shocks you can put on?
Old 04-10-2006, 07:26 PM   #15
TLTCrawlin's Avatar
Try shorter shocks. I really like your idea, I am going to try it on my TLT.. Thanks for the idea, and yours is looking SICK. Im loving it, but yah the battery is kinda high.
TLTCrawlin is offline   Reply With Quote
Old 04-10-2006, 09:38 PM   #16
i dont get it...when will you people learn? listen bud, thats a great lookin truck! super scale..but yes its a little high...dont get shorter shocks...CUT THE FUKIN SPRINGS! why get shorter shocks and limit your travel when u can cut the springs and lower the truck but keep the flex by letting the axle droop...instead of "ride height" already being full droop.
GREAT JOB!
Nick~
RC_MANIAC21 is offline   Reply With Quote
Old 04-12-2006, 06:45 PM   #17
perfictsib's Avatar
well i wont be fitting shorter shocks unless i realy need to, with my old setup they worked ok and this is same but on a frame instead of 2 bits of plate the plywood mockup worked ok to but i could be wrong and i wont know untill i run it. All thats left to do is fit the body mounting tabs and spray it so i can start putting it back together, i used 12mm box section steel cut down middle so i ended up with 5mm x 12mm x 1mm C section and some flat steel plate that is nearly 2mm thick for skid plate/radiogear and battery tray.
length of frame is 425mm
width is 61mm (supposed to been 60)
height 95mm (including shock mounts)
weight 13oz (bare nothing fitted)
wheel base 12" to 12.5 "inches
still to do after tabs are fitted is, fit body then make bumpers
(but i intend to try it first before i do body and bumpers)
will post pics when tabs are fitted
Old 04-12-2006, 07:17 PM   #18
trost's Avatar
humm looks good so far...git er done!
trost is offline   Reply With Quote
Old 04-12-2006, 07:55 PM   #19
that looks sweet! what the hell are those tires?
Crawlsalot is offline   Reply With Quote
Old 04-13-2006, 02:48 AM   #20
perfictsib's Avatar
the tires and wheels are off a thundertiger ssk truck , tyres have been cut for more flex they work well seeing as theres no foams in them and they used to hold it up when it weighed 5lbs with little side wall roll.
they were to cheap to turn down £3.98 for 4 wheels and tyres had them from diagostaini 1st issue 98p so bought 4 issues same with shocks they came with 2nd issue they cost a couple of quid more
