Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: hey all here is my scale rig
Old 04-21-2006, 05:23 PM   #1
Default hey all here is my scale rig
hey check out my scale rig
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
thanks that is a new bright body i painted up it has locked tlt axles the chassie is a tlt carbin fiber with costum made alum 1-10 couversion add to it and costum made body mounts Click the image to open in full size.Click the image to open in full size.
it's about 11.5" on the wheel base 4 wheel stear motor is stock but has a 12 tooth pinon. has a water prof esc and 2.2 swamp dawgs it flexes up nice for a scale rigClick the image to open in full size.
i allso made a set of servo mounts for it so the links would mount to them
fire627man is offline   Reply With Quote
Old 04-21-2006, 05:25 PM   #2
rbl
rbl's Avatar
it looks good
rbl is offline   Reply With Quote
Old 04-21-2006, 05:27 PM   #3
thanks i have a little spot behind my house we built a corse
Old 04-21-2006, 05:31 PM   #4
trost's Avatar
looks good!
trost is offline   Reply With Quote
Old 04-21-2006, 05:31 PM   #5
1 man, 2 sons
Unimoger's Avatar
looks good, nice find on the jeep body. Post up some specs for everyone to see, like wb, cog, motor, trans, chassis, axles, etc. nice work.
Unimoger is offline   Reply With Quote
Old 04-21-2006, 05:37 PM   #6
thanks that is a new bright body i painted upit has locked tlt axles the chassie is a tlt carbin fiber with costum made alum 1-10 couversion add to it and costum made body mounts Click the image to open in full size.Click the image to open in full size.
Old 04-21-2006, 05:59 PM   #7
Haters gonna Hate
1BadJeepBruiser's Avatar
Throw in some King black foot half shafts, they will get it a slightly wider stance and they are really cheap from tower. Only other thing I would do is maybe drop the body down a lil bit, then it will look great
Mike
Old 04-21-2006, 06:00 PM   #8
how could i make it more scale do you think it is too tall
Old 04-21-2006, 06:02 PM   #9
i al so have a set of all T's for it and they rub if the body set any lower in fact they rud a little at full flex now that is why thous tires are on it when i crawl
Old 04-21-2006, 06:08 PM   #10
Haters gonna Hate
Yes, I think its a tid bit to tall in my opinion, I mean it doesnt look bad, but if it were my rig I would lower it a touch. Plus with that body I am sure its a bit top heavy and it will probably crawl better with it lowered a bit.
Mike
Old 04-21-2006, 06:11 PM   #11
it not to bad on the top heavy crawling but a little at top speed with the four wheel stear it will turn on a dime cut all the way it will turn in 3.5' O but i know what you are saying
