11-17-2011, 02:31 AM | #21 |
Rock Stacker Join Date: Sep 2011 Location: NS
Took it out for some more testing. Had two problems: First, the shocks were way to soft for all the weight. Solved it by changing the springs to stiffer ones and added 20wt oil. There was no oil at all in them. The second problem is one of the pins on the drive shaft backed out a bit and rubbed on the drive gear. Used some locktite on it. We'll see if it holds. Here are some action shots. I know.....pretty lame, but thats all I got for now. |
11-17-2011, 02:34 AM | #22 |
Getting close to the end. Still got tweaking to do. Also gotta find a better place to run it. |
11-17-2011, 03:16 AM | #23 |
Build List: (Should have put this in the beginning) RCP Wreckluse Frame TSS Grill Axial axles Axial Trans 48T Spur Junfac drive shafts Novak 55T motor Novak XR ESC RC4WD Rockstar wheels RC4WD Tires Dinky RC 4 Link Axle mounts HR 120mm Shocks 3Racing Winch Scale Stuff Last edited by deaddant; 11-18-2011 at 01:37 AM. |
11-17-2011, 04:56 AM | #24 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Looks good man like the paint.
11-17-2011, 09:09 AM | #25 |
RCC Addict Join Date: Nov 2008 Location: Santa Fe, NM
Nice looking rig |
11-17-2011, 12:35 PM | #26 |
Thanks for the kind words!
11-17-2011, 08:53 PM | #27 |
Update.... Added a couple scale accessories and made this tow strap. Finished up the dash gauges and installed the steering wheel. Took some measurements. The wheelbase came out to 11 1/4". Here are some different angle shots. |
11-17-2011, 11:49 PM | #28 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
You're looking like an old pro! The dash and overall build is really impressive! No wonder why your wife is getting on you! It's probably a little top heavy, for that, you could always run a droop setup or semidroop (look it up!) Also, with the shock setup, you could run a couple of the HR springs (2 of the included) in the shock body. I didn't run oil in mine...on the dually. I also removed some of the rubber o rings. You won't get dampening, but with a crawler setup you might not need it. The shocks will recoil quicker and the springs will keep it at the ride height easier. My shocks were way sluggish until I did that little mod. As for more wheel speed, a 35 will certainly wake it up. Holmes hobbies seams to be the go to motor. PM him and tell him what you're doing and he'll set you up. A 35 turn with different slots makes a big difference. Do some research and you'll get way too much info on motor specs! He doesn't mess around! |
11-18-2011, 08:26 PM | #29 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
very clean |
11-19-2011, 04:38 PM | #30 |
Quarry Creeper Join Date: Aug 2006 Location: Pilgrim,Ky
Very nice wreckluse.I have a question about your headlights.I know you said you used a 10mm led but what did you mount it too?From the pics I couldn't tell.
11-19-2011, 09:43 PM | #31 | |
Dan | |
11-19-2011, 10:29 PM | #32 |
Quarry Creeper Join Date: Jul 2011 Location: Brodhead, Ky
What size links are you running?
11-21-2011, 10:12 PM | #33 |
Quarry Creeper Join Date: Sep 2011 Location: NW
Very cool looking Wreckluse.
11-21-2011, 10:44 PM | #34 |
11-21-2011, 10:47 PM | #35 |
11-21-2011, 11:05 PM | #36 |
Quarry Creeper Join Date: May 2010 Location: Kaena Point, Hawaii
looks good, you should take it to kaena point. have you checked out the hawaii section
11-21-2011, 11:29 PM | #37 |
Newbie Join Date: May 2010 Location: WAIANAE
nice build bro
11-21-2011, 11:44 PM | #38 | |
11-22-2011, 04:23 PM | #39 |
Newbie Join Date: Feb 2009 Location: San Diego
Very detailed Rig! I have been working on my wreckluse for almost 2 years and doesn't look like this thing,
11-25-2011, 04:24 PM | #40 |
Thanks for all the comments! Pretty much finished with the build. Ended up making a few setup changes. I decreased the shock lengths to 110mm. Put on some wider offset wheels for more stability and weighted the fronts. I'm using a 3S lipo to give it some speed. Seems to work really well. Here are some pics: Electronics Lipo placement Hitec 645 MG Servo Secret switch for the winch And finished !!!! |
