02-07-2021, 12:35 PM | #1 |
Newbie Join Date: Jan 2012 Location: Central PA
| SCX-10 rebuild - tube buggy
This started off as a Honcho SCX-10 with a few upgrades and mods. It was wheeled hard and held up well. It then sat on the shelf for years until I recently got the motivation to rebuild it the way that I originally intended. Visually it was ugly as F, but performed well… Anyway, here are the specs and the rebuild. Specs : Stock axles Stock gear case Stock ESC 18 tooth pinion Hitech 7955TG servo Castle BEC (set to 6v) Tekin 35t motor Custom 3 link front with panhard 3.5oz weights front / 1.75 rear Proline 2.2 TSL’s |
02-07-2021, 12:40 PM | #2 |
Chassis stripped down to the frame. Rear section cut off and started to tube it out. Always wanted to learn how to braze and this was the perfect way to do it. Tube is standard 3/16 brake line. |
02-07-2021, 12:44 PM | #3 |
Body panels mocked up and then traced on a .20 aluminum sheet Chassis cleaned up and painted Drivetrain and wiring tucked in |
02-07-2021, 12:49 PM | #4 |
Skins painted and installed. All done, it was a fun build, hope you guys enjoy it. |
02-08-2021, 01:36 AM | #5 |
Quarry Creeper Join Date: Nov 2008 Location: N. California
| Re: SCX-10 rebuild - tube buggy
Turned out awesome! Nice work. I just started reviving a 1.9 first gen honcho so this thread is great motivation.
02-08-2021, 09:24 AM | #6 | |
| Re: SCX-10 rebuild - tube buggy Quote:
A couple more pics - I was itching for a real test run and had to get it outside. It's very balanced and has a very low COG - super pleased with how it performed | |
03-05-2021, 03:33 PM | #7 |
Added some much needed splash guards. Used rubber roofing for this Also designed and had the wife print out some vinyl graphics to give it a little flair. Really happy with how they turned out |
SCX-10 rebuild - tube buggy - Similar Threads | ||||
Scx rebuild- new direction | 98sporttj | Axial SCX-10 | 2 | 04-15-2015 09:10 PM |
tube buggy rebuild | dittohead | 1.9 Scale Rigs | 1 | 07-13-2013 05:12 PM |
