02-14-2012, 05:41 AM | #1 |
Pebble Pounder Join Date: Jul 2008 Location: saipan cnmi
| stretchwreck rebuild
had this stretchluse on some axial axles with some mutiwidth hot racing wideners. i wanted the width, but without the wideners. then i got so lucky with a set of wraith axles from RPP (great service btw, thanks Corey) assembled them and this is what i came out with... i had some drive shaft clearance issues but i solved that. i cut the lower section and moved it out. ill post the updated pics soon, im in between another build at the moment |
02-14-2012, 08:50 AM | #2 |
Rock Stacker Join Date: Jun 2009 Location: GUAM671
| Re: stretchwreck rebuild
Looks good Paul |
02-14-2012, 08:54 AM | #3 |
Rock Stacker Join Date: Sep 2011 Location: Perth, Western Australian
Wraith axles look perfect mate!
02-14-2012, 05:29 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
I really like this stretched out Wreckluse, I really like it. I noticed that you are doing axle mounted servo. I am trying to figure out how to do CMS on it.
02-15-2012, 10:47 PM | #5 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Subscribed: I see you dremeled the front of your chassis as I did to clear the servo |
02-16-2012, 06:23 AM | #6 |
| Re: stretchwreck rebuild |
02-16-2012, 08:28 AM | #7 |
RCC Addict Join Date: May 2010 Location: Midwest
Looks good. Are you going to make your own body panels?
02-16-2012, 09:07 AM | #8 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
^^x2 on the body panels and are they goin to be flat lexan or actual body resembling panels?
02-16-2012, 03:02 PM | #9 |
They are actually a really thin sheet of aluminum. It's thin enough to get dented and banged up for that really scale look. I found the material at a local hardware store and it is actually intended for the dryer ducting. I will post pics later on today. |
stretchwreck rebuild - Similar Threads | ||||
Rebuild of a FJ 40 | Straightjacket | 1.9 Scale Rigs | 16 | 01-19-2011 07:22 PM |
JK rebuild | atvdude775 | Axial SCX-10 | 9 | 01-18-2011 03:13 PM |
my jk rebuild | adamargue | 2.2 Scale Rigs | 8 | 08-22-2010 01:52 PM |
rebuild | quarterpounder | Newbie General | 2 | 12-16-2008 09:43 PM |
Rebuild of my GC-1 | yukon635 | Tamiya TLT Crawlers | 17 | 10-26-2007 05:31 PM |
