04-04-2012, 10:23 AM | #1 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Operation: Super Scrambler NWSC TTC Entrant #20 Lets do this! This, should turn these, which spin these, and make this go. More to come, stay tuned. Last edited by Highmark; 07-25-2012 at 01:17 PM. |
04-04-2012, 10:30 AM | #2 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: Operation: Super Scrambler a PNW inspired Kentucky fried CJ8
Nice! I assume this is coming to Oregon and Washington this fall? Looks like it's going to be a great build!
04-04-2012, 11:13 AM | #3 |
RCC Addict Join Date: May 2010 Location: Midwest
Looks good |
04-04-2012, 11:29 AM | #4 |
Chassis & Tubework Vendor Join Date: May 2006 Location: Portland, OR
Awesome start! I'm curious as to what wheelbase you use.
04-04-2012, 07:25 PM | #5 | |||
| Re: Operation: Super Scrambler a PNW inspired Kentucky fried CJ8 Quote:
04-17-2012, 10:55 PM | #6 |
Finally got some time to work on my axles. Specs: Axial HD Overdrive gears F/R SDS Customs Super 300 CVD's - and Lockers Boca Green seal bearings 3Racing aluminum axle cases - de-anodized, shaved and sanded (will be painted). Vanquish Knuckles - Machined for 12mm outer bearing D-Lux no slop brass bushings J-Fab Aluminum 8mm Super 300 hexes MG200 double-shear upper link mounts / servo mounts. |
04-18-2012, 10:20 AM | #7 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
Love it!! What does it weigh in at?
04-18-2012, 04:46 PM | #8 |
| Re: Operation: Super Scrambler a PNW inspired Kentucky fried CJ8 Thanks! I honestly couldn't tell you how much the frame weighs (I don't own a small scale). It's all tube though, so it weighs about half of what I really expected. I think the truck will be around 8lbs when complete (with any luck). |
04-18-2012, 05:48 PM | #9 | |
I bet it's around 1lb 12oz or so....but that's just a guess. Those fancy skidplates up the weight a little bit. | |
04-18-2012, 06:35 PM | #10 |
Rock Stacker Join Date: Jun 2011 Location: ossipee,NH
| Re: Operation: Super Scrambler a PNW inspired Kentucky fried CJ8 hammer down
04-18-2012, 09:02 PM | #11 |
I was able to get the transmission finished up tonight. Nothing to crazy with this, just simple and strong! I started with the Hot-Racing "all metal" transmission, removed the stock metal shield bearings and replaced them with Boca green-seal bearings. I also added some new super sticky grease that one of the vendors here was kind enough to send me for testing. These come from Hot Racing as nicely built units that feature HR's hardened steel gears. I prefer these to the similar Robinson Racing gears as they are lighter and in my opinion just as durable. I replaced the aluminum spur that comes with the transmission with a 32p duratrax gear (60t). |
04-18-2012, 09:05 PM | #12 |
| Re: Operation: Super Scrambler a PNW inspired Kentucky fried CJ8 |
04-19-2012, 06:46 PM | #13 |
RCC Addict Join Date: Oct 2009 Location: west coast..
Damn mg I should have had you build my chassis.... Oh well excited to see the build..
04-19-2012, 08:43 PM | #14 |
04-22-2012, 01:04 PM | #15 |
Here's a quick "how-to" on removing annodizing. Here's what you'll need: 1. Regular Easy-Off oven cleaner 2. Latex Gloves 3. A brush you won't mind throwing away 4. (optional) some sort of metal pan, or area that can be washed The goal is to use the caustic reaction that the Easy-off creates when it hits the aluminum to remove the anodizing without damaging the surface of the aluminum. Caustic reactions utilize strong bases and are inherently dangerous and can cause chemical burns (see: http://en.wikipedia.org/wiki/Sodium_hydroxide). It's important to consider this while you work with this stuff, and make sure that it doesn't get on your skin or the surrounding area. Anyway, moving on! The parts get a nice 5-10 minute bath in the Easy-off: I usually rinse thoroughly with water, scrub with the brush and then repeat the process by adding more Easy-off until the parts are where you want them. My axles will be painted, so they didn't have to be perfect: You can see that I left some anodizing on there, as I didn't want to pit up the aluminum anymore than I really had too. You can choose to wait longer, and the Easy-off will work to remove the left over anodizing or you can choose to sand it by hand if you want a different finnish. I knew I was going to file and sand the heck out of my housings before they get painted, so I didn't waste anymore time. |
04-22-2012, 10:28 PM | #16 |
Progress: It steers! |
04-23-2012, 05:56 AM | #17 |
I wanna be Dave Join Date: Dec 2008 Location: ?
I like that you left the roof on the body.
04-23-2012, 04:17 PM | #18 |
04-23-2012, 09:16 PM | #19 |
Good clean lines man Great job!!
04-24-2012, 02:11 AM | #20 |
Quarry Creeper Join Date: Apr 2011 Location: Waimanalo, Hawaii \m/
Nice rig man! What wheels are those I really like that deep dish look |
