Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: The Green Goblin- My First Southern Buggy
Old 09-24-2012, 10:27 PM   #21
Default Re: The Green Goblin- My First Southern Buggy
think im going to have to take you to welding class and build me a stainless southern buggy for my wraith axles! ill probably tig weld it on my breaks at work!
jeremyfowler33 is offline   Reply With Quote
Old 09-24-2012, 10:32 PM   #22
WOOPOOW!!
You should do it! Tube is fun, even if you arent the best at it.
I have actually thought about going for a second major in college and doing welding and diesel mechanics instead of just diesel.
Colby is offline   Reply With Quote
Old 09-25-2012, 08:17 PM   #23
WOOPOOW!!
Rear end is done, I am trying to decide if I should do the front hoop and motor cage with smaller tubing.
I strayed away from the Goblin design on accident on the roof and part of the rear, though I dont think you really will notice it unless you are staring right at it. Ive got alot of dremel and weld grinding to do, Maybe have some green paint on it by saturday
Old 09-26-2012, 12:04 AM   #24
Don't rush it! These buggies are complicated. Get all your little tubes done and don't skimp on the little scale details. If you're going to build it...build it right. Any shortcuts will haunt you. Trust me! Nice job so far.
Bulldog is offline   Reply With Quote
Old 09-26-2012, 08:13 AM   #25
WOOPOOW!!
Thanks man! The only thing haunting me at the moment is how in the world im going to bolt the engine cage on. Its going to have to have some tiny hardware. I may braze those on.but im not sure it could handle the abuse its going to get put through.
Old 09-26-2012, 04:25 PM   #26
Go ahead and start the cleanup on the welds now before you cant get into all the little areas as easy. Keep it coming.
Grimreeper is offline   Reply With Quote
Old 09-26-2012, 10:32 PM   #27
WOOPOOW!!
Actually, youd be surprised but with the skid plate out I am able to get every angle of this thing with a dremel
No more invisible axles!! Though these arent the axles I will be using.
I love this thing, even if its not perfect, and if it doesnt closely copy the real goblin. All thats left is motor cage, clean up, paint, and ass kick and be proud of myself because I 100% fabbed this thing from nothing in 2 days in my garage.
Old 09-26-2012, 10:48 PM   #28
dezmoon's Avatar
I Think You Should Totally Be Proud of Yourself,,I think It Looks Killer,,Are You Gonna Try and Do same colors,,Or Your Own Scheme???
dezmoon is offline   Reply With Quote
Old 09-26-2012, 10:52 PM   #29
WOOPOOW!!
Thank you sir! I am definetly going lime green and black motor cage, and totally going to call it the green goblin for sure. I just love the theme of the real thing way too much.
Old 09-26-2012, 11:08 PM   #30
dezmoon's Avatar
Awesome,,,What Axles Are Gonna Call Home Under There,,You Mentioned that those werent the permanant Set??
Old 09-26-2012, 11:13 PM   #31
WOOPOOW!!
Well, my PLAN is to pretty much make the axles you see on it here, but with steel tubes and steel trusses, just like Grizzly4x4 has on Guido. I need strength, because there is going to be a great amount of air under these tires
Though, these axles may be home for the first couple of rides, because I need axle shafts
Old 09-26-2012, 11:19 PM   #32
dezmoon's Avatar
Awesome,,,
Old 09-27-2012, 12:46 AM   #33
Because I've been there...what are your plans for steering? And from the last pic in post 27, are you planning on running semi droop? I don't see enough suspension travel room in there! Post up.
Old 09-27-2012, 06:17 AM   #34
WOOPOOW!!
As far as steering, i mocked it up just siyting on the axle and rverything clears just my the smallest amount when flexing.
As far as suspension it isnt droop at all, i actually had to put some long esavage rod ends on the front shocks to get more length. It just sags a little because its heavy lol.
Old 09-27-2012, 07:30 PM   #35
Looking great Colby. Really glad to see you went with the 3/16" tubing, suits those big meats on there.
ecoli is offline   Reply With Quote
Old 09-27-2012, 08:33 PM   #36
WOOPOOW!!
Thanks Chris! Means alot coming from the southern buggy god! Theres actually some 1/8th on there, but i think it still works just as good.
Old 09-28-2012, 09:31 AM   #37
Wow that is really coming along! Excellent
Work!
Desert Rc is offline   Reply With Quote
Old 09-28-2012, 10:49 AM   #38
WOOPOOW!!
Thanks man! I posted one of these pictures up on Timmie Cameron's facebook and got overloaded with likes on the picture and Tim Cameron loved it! Definetly makes me feel a whole lot better about this thing
Old 09-28-2012, 12:52 PM   #39
I have a lot to live up to apparently I just build what I like, and I like southern buggies, a lot
Yeah, I noticed the 1/8 in the bracing areas. Probably a smart move, especially when dealing with such small pieces. It doesn't take away from the look at all.
Are you planning on rattle can or pc'ing the frame once finished?
Old 09-28-2012, 12:57 PM   #40
Now we're talking. Looks awesome.
Szczerba is offline   Reply With Quote
The Green Goblin- My First Southern Buggy - Similar Threads
Southern buggy inspiration ScaleReady Chit Chat 12 08-14-2012 10:50 AM
