01-18-2019, 02:12 PM | #321 | |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: Clanker's Wreckluse Quote:
Sent from my iPhone using Tapatalk Last edited by Postclanker; 01-18-2019 at 02:20 PM. | |
01-19-2019, 10:08 AM | #322 |
RCC Addict Join Date: Dec 2007 Location: (LES) Manhattan, New York
| Re: Clanker's Wreckluse WOW! This Wreckluse has undergone major changes. I love the front end work you did for the extra clearance. You got that thing hooked up with some sweet axles and i love their width. Im still using the ax10 axles (narrow width) and got them running 1.9 wheels, just under 4 inches in diameter. |
01-19-2019, 03:40 PM | #323 |
Pebble Pounder Join Date: Jun 2007 Location: PNW- Eugene.
Lookin' absolutely killer Bud. Glad to see this getting worked on again!
01-20-2019, 09:40 AM | #324 | |
And anyone here would enjoy a sneak peak at that here...post a pic Alex Those axles are XTRA SPEED full metal jackets VP knuckles, shafts, lockouts, the lockers are so tight I had to coax them to work DLUX U4 trusses...stout and strong Metal everything that I could find.... I know...not the best idea, but I will put some horse power to the wheels and I don’t want plastic anymore. So.... on with the heavy metal ! | |
01-20-2019, 09:41 AM | #325 |
| Re: Clanker's Wreckluse |
01-20-2019, 04:43 PM | #326 |
01-24-2019, 10:08 AM | #327 |
| Re: Clanker's Wreckluse Life..got in the way. But I'm getting my feet wet again. Haha. I need to practice more and get a better welder. My welds aren't the prettiest, but they hold, so out come the files and grinder! lookin' forward to seein' this thing tear around! |
01-24-2019, 06:11 PM | #328 | |
Well Greg, here is a pic of my wreckluse. The light bar under the roof has been removed and the wheel/tire setup changed. Other than that, the wreckluse its pretty much how you see it here. Oh and this one has always been equipped with 4 wheel steering | |
01-25-2019, 10:49 AM | #329 |
Yes Sir Always a favorite....what a nice looking wrecluce Alex All my builds are taking forever Quinn...I find time when I can.... I tore it all down yesterday...had prototypes for links...have a buddy who will makes killer threaded ss links... Time for the electronics...fire up that Castle Then on to the interior.... |
01-28-2019, 12:18 AM | #330 | |
Newbie Join Date: May 2017 Location: 3420 E. Georgia Pines Lane, Mead
The chassis is so narrow down there where the servo mounts on my AR60 XR Axle. I'm cutting off the mounting tabs and using a radiator hose clamp to hold the servo, the radiator clamp will first be mounted to my axle. That should give the chassis plenty of room. I dont want to chop it up... Sent from my SM-G930VL using Tapatalk | |
01-28-2019, 12:26 AM | #331 |
Here she is ..my pic is showing a Savox 1210sg waterproof servo. I've waterproofed the Savox 1230sg, which has 500oz of torque at 6.0 volts. That will do the job.. Sent from my SM-G930VL using Tapatalk |
01-28-2019, 09:51 AM | #332 | |
Couldn’t see the hose clamp I had issues with that as well....I had to Dremel my way clear to clear the servo horn from the front plate...it worked until I cut the whole thing up.... I struggled with cutting my chassis...had several people try to buy it from me before I did, I think the highest offer was a C note for just the chassis. It was worth more to me as something different... I’m enjoying this....thanks for looking | |
01-28-2019, 10:04 AM | #333 | |
02-22-2019, 04:39 PM | #334 |
Finally found some time Also had some new links made and fabbed a home made battery tray out of the way and up front Have some pics to share... More later Thanks for looking Sent from my iPhone using Tapatalk |
02-23-2019, 04:18 PM | #335 |
Quarry Creeper Join Date: Nov 2012 Location: Paxton
I bet that thing will flat out get it. I hope you take some videos of it running. Looks good.
02-24-2019, 10:00 AM | #336 |
03-02-2019, 01:49 PM | #337 | |
03-03-2019, 09:30 AM | #338 | |
I don’t like being the same as anybody else... | |
05-18-2019, 08:04 PM | #339 |
A little update Some metal panels and a wacky driver...probably add a fuel tank and a bit more on the interior...then run the hell out of it! Thanks for looking Sent from my iPhone using Tapatalk |
Clanker's Wreckluse - Similar Threads | ||||
just got a wreckluse and need help | pontiacfreak | Electronics | 7 | 11-24-2009 10:10 AM |
