10-02-2012, 09:00 AM | #21 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: Clanker's Wreckluse
as an afterthought for this build...I mentioned the $1000 gift from my wife as a starting point....I went well over that amount... but it crawls nice now.... |
10-03-2012, 09:22 PM | #22 |
Lots of views....but no comments Don't be afraid, I'm looking for feedback Thanks for looking |
10-03-2012, 09:34 PM | #23 |
Pebble Pounder Join Date: Sep 2006 Location: Myrtle Creek
I have a set of axles the chassis now I just need the 1k+ budget ;) Any info on link length? Ever thought about cms? I've been reading up on a couple builds with it. |
10-03-2012, 10:12 PM | #24 |
Oh, you don't need to spend as much a s I did. I went kind of nuts on it and bought stuff new when I had spares I could have used, should have made my own links instead of the VP stuff. I've never been a fan of the panhard set up required for CMS. I really didn't even consider it. Link length is as follows: eye to eye Front upper 4.25" Front lower 3.85" Rear upper 5" Rear lower 4.5" Everyone's build is different, I bet your links will be as we'll |
10-03-2012, 10:35 PM | #25 |
Thanks!! Just asking on links for a ruff ballpark figure. I had no idea where to start.
10-03-2012, 10:58 PM | #26 |
Are you using the wraith axles ? Depends on your shocks also. Do a mock up before you cut anything and even then, be prepared to do it a couple of times... I'll help if you need it.... |
10-04-2012, 01:32 PM | #27 | |
RCC Addict Join Date: Dec 2007 Location: (LES) Manhattan, New York
| Re: Clanker's Wreckluse Quote:
I was very close to starting work on the 'luse but chose to leave it on the shelf till i was finished with the broncos (both are winch equipped now) Dont get me wrong, i am doing mental work on it before i start taking things apart. I'm definitely going to go with 1.9 wheels with a set or Iroks (love these tires). My intention are shorter shocks. Currently they are 110mm and im thinking of 90mm. Link lengths are to remain the same but its not written in stone. your right about each build being unique, I researched link length when doing my build and it was different for each build. My link setup was trial an error. till i was happy with wheelbase and angle of the drive line. I will seriously keep your advice under consideration with regards to the extra low placement weight. I have a set of 1.9 titus wheels with the weights that will definitely keep COG low. Not liking the wheels but maybe i can place the weights on inside of a different wheel if that works. Wild willy is still staying as my trusty co-pilot. forgive my ignorance but what did you mean by "still maintain some anti-clocking when compressed"? If we could get both Wreckluses to crawl together that would be SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET!!! | |
10-04-2012, 02:12 PM | #28 |
| Yep same setup as you! Wraith axles. I'm not looking for hard core crawler just want it to have with.
10-04-2012, 05:49 PM | #29 |
Lobo:...when I was getting the links together and trying to find a length that worked, compression would clock the front axel back and almost bind the drive shaft until I found the right length for the links in combo with the shock position I wanted. Then would the servo clear the chassis ?....NO so I augered out the chassis to clear the servo horn then it worked. I mean a 1/4" difference in length would be disasterous. I had to walk away many times, was very frustrating. But then I found the right length/combo ...and it was a beautiful thing. It would compress and squat pretty and no clocking...you'd have thought I won the lotery... I'm not a fan of wheel weight anymore...rotating mass has snapped a couple of Universals on my Wraith. Blue Monkey makes some axel weights for the wraith axel, but they are NOT cheap. I did find some clamp style collars for the TF2 and in searching for those, found some that fit over the end of the wraith axel...been wanting to try that for weight. They weigh about 2 oz a piece. I'll update this thread when I get the chance. I don't have near the power in the Wreckluse I have in the wraith/basher so it might just be a power-weight thing...maybe I just went over the edge. |
10-04-2012, 05:52 PM | #30 |
Hey KMoore...the wide wraith axels are a real plus. They add stability, especially if you can keep it low. If my welding/brazing skils improve, I might consider shopping the roof down. That would help also...but I'm chicken
10-05-2012, 05:40 AM | #31 | |
I gotcha on the wheel weight and im on board with that as well. Just from nitro experience, you want your wheels and tires to be as light as possible in order to accelerate fast. Rotating mass stresses parts. Main reason i've never used the Titus wheels with the weights. unfortunately Ive never tried taping weights to the axle either. It is something to consider to get that stability. Will keep you posted on the wreckluse remix..er i mean rebuild, lol | |
10-05-2012, 05:49 PM | #32 |
Rock Crawler Join Date: Feb 2012 Location: NORTH SYRACUSE N.Y.
turned out nice . I did mine with Axial 60s also , thought they looked better then the sxc10 axles .
10-05-2012, 09:24 PM | #33 |
I think they are stronger as well... Thanks Paleblue, post a pic in here if you would...haven't seen that many use the wraith axle...I'd be interested to see what you did. Multiple pics are ok... |
10-07-2012, 11:18 AM | #34 |
DUDE!, Im not sure what's going on but i started work on the wreckluse last night and ran into your front servo clearance issue. Its crazy how it cleared before and a change of the shocks threw my setup right out the window. I didn't notice that i lost three axle screw/nuts and that my upper link mounts were loose. WOW! I'm trying to figure out how much to rebuild and how much to leave as is. I was looking at your inside setup and im thinking about installing two seats that i have lying around but i want to keep willy as my pilot. currently he doesn't fit with the seats so some modding is required. two seats also requires battery relocation for the lights. Some of the styrene panels are in need of some TLC if not total replacement. oh the pain... Last edited by Lobonyc; 10-07-2012 at 12:46 PM. |
10-07-2012, 12:13 PM | #35 |
Longer shocks would throw the servo right under the chassis....dremel time Also check your clocking at full compression...the slightest little change was very destructive for me...I feel your pain my friend, but I'm sure you can get the right combo. If you use a longer shock, you might have to lengthen your links as well. |
10-07-2012, 12:55 PM | #36 | |
Was contemplating removing the rear steer but i like the 4X4X4. what are your thoughts on just having front steering? I will keep my eye on the clocking. | |
10-07-2012, 02:15 PM | #37 |
No thoughts really....nice to have rear steer...gives you more maneuverability of course...was a bit much for me to bite off at the time. This Wreck was my first build from scratch really... You could also cut off some of the MIP shaft...just a thought |
10-08-2012, 07:23 AM | #38 |
Well Lobo??? How'd it go? Or did you do a Greg and have to walk away ? Post up some pics.... |
10-08-2012, 09:43 AM | #39 | ||
Arctic Cat Wildcat Rock Crawling with Rally on the Rocks! - YouTube Im slapping on some 1.9 Iroks at 4.65". The gmade shocks i had in the beginning were like 115 to 120mm, so going to 110mm was an improvement. I did do some upgrades. Axial universals were installed upfront (the backs will be done either tonight or sometime this week depending on the wife, lol). The width of the rig was extended by about 5 to 10 mm using the hexes from the Predator tracks instead of the axial narrow hexes. not a major deal but it helps. After that, yes i did do the "Greg". But only because i did the "Alex" a few minutes before. The "Alex" is having parts in your hand and then having them suddenly disappear. This usually happens when the wife calls for something. I stop what im doing to attend to her and the gremlins come and swipe my parts. Its like someone up there said "you have to stop working on the wreckluse!", lololol. I took some pics...will post tonight after work. take care my friend | ||
10-08-2012, 11:50 AM | #40 |
Oh Man...I've done the "Alex" so many times...put down a tool...and more times than not...I cannot find it again for the life of me. I then do the "Mimi" (wife's name) and turn around three times (she can't find her way out of the driveway without her GPS) and sure enough put my eyes on the missing part within 5 sec after the dizziness stops more later my friend...gotta go to a meeting... |
Clanker's Wreckluse - Similar Threads | ||||
just got a wreckluse and need help | pontiacfreak | Electronics | 7 | 11-24-2009 10:10 AM |
