Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: A buggy called Elmo
Old 12-07-2013, 07:41 PM   #81
Default Re: A buggy called Elmo
Awesome new wheel and tire setup. Really makes the rig look even more like a 1:1. On the foams, as mentioned, a little trimming helps on the closed cell inner foams and those narrower wheels.
Szczerba is offline   Reply With Quote
Old 12-12-2013, 07:16 PM   #82
Thanks Shane. I really like this combo too. I also like the narrower track width. Pulls the proportions in.
Also swapped out my Tekin 13.5 with the Roc 3100. Still running the same gearing as my 13.5 (54:12), and holy shit... Such a different animal. Very smooth low end, and even a little bit more top end. Not sure why the top end seems faster since it's 3100 vs my old 3500kv. Must be a difference with 2 vs. 4 pole.
Only drove it for 10 minutes before I froze my ass off and said screw it (too cold).
Next up dipping the sensor board in some Corrosion X, and waterproofing it.
tedo is offline   Reply With Quote
Old 12-21-2013, 06:44 PM   #83
Dropped my ROC and MMP into some Corrosion X. Simple enough. Sealed up the motor leads, sensor wire, and BEC with some silicone.
One thing that had always added significant weight was my full driver, the dash and interior, and the .22 gauge homemade seat. That whole set up was nearly a pound.
Not a concern when it was a dedicated slow comp crawler, but now with the added speed with the ROC 3100, I opted for a new, way lighter 2D cockpit. I hacked up the HPI Apache cockpit, and kept it a single-seater. The overall buggy is a lot lighter (and way easier to work on). The cock pit is pressure fitted into the frame and held into place with 2 3mm screws. It's pretty secure, and fits like a glove. Added some small paint details as well.
I think the new driver scales out great.
As soon as this ice storm lets up, I will get her out on the rocks.
Old 12-22-2013, 12:40 AM   #84
what did you use for window nets?
blakeski is offline   Reply With Quote
Old 12-22-2013, 08:00 AM   #85
They are available in any craft store in the yarn section. I believe they are for crochet? They are under a buck a piece and come 8.5 x 11 in multiple colors.
Old 02-09-2014, 02:15 PM   #86
A few updates:
- installed Locked Up's FI lockers front and rear. These things kick ass.
- completely rebuilt my shocks with 7000wt diff fluid. Green slimed the o-rings. We will see how well they hold fluid. Not 100% happy with these shocks. May step up to some Velvets.
- new diff covers (yay, bling)
And of course since we all just got done watching the King of the Hammers, I decided to see what a spare tire looks like. Just a temporary solution with a 3/16 cable tie down:
I think it looks okay for what it is:
Old 02-09-2014, 10:08 PM   #87
i like the new wheels and tires.
single seaters don't carry a spare.
joeyf is offline   Reply With Quote
Old 02-10-2014, 06:51 AM   #88
It's not permanent. I was just having fun after watching KOH.
Old 04-13-2014, 06:47 PM   #89
So, I decided to make this a strict W.E. Rock unlimited cone dodger. I am hoping axial will release an ifs rig shortly to fill the ultra4 class (emphasis on hoping).
Added a 7955 rear servo with VP chubs and steering. This is so much fun to drive with the new set up. Flexes awesome, and the tires are finally softening up.
A few packs threw her this week with the amazing temps, and I am liking it.
Old 04-28-2014, 06:11 PM   #90
3D printed a new battery tray. I like it. It was a quick project to learn sketch up in our new Makers Space. Batts feel way mure secure, and I don't have to rely on Velcro...
Old:
New:
Still looks the same from the exterior:
Old 08-16-2014, 01:53 PM   #91
Finally had enough with the King shocks. They are the absolute worst. Seriously, the worst.
After checking out a few setups I decided to go with some 4in big bores for a few reasons:
1. They are relatively inexpensive.
2. If they can handle the abuse from 35mph traxxas rigs, the can definitely handle my little crawler.
3. Fully tunable. Shane is tuning them with the RPM pistons. I may try the MIP pistons in a bit.
4. Love the JeepinDoug mini t spring set ups.
5. They have never let me down in the past.
I set this up with 30wt oil, and the softest mini t springs. It gives my comp crawler the stance I want, and being so low it handles great at speed.
I also sold my enduros and picked up some of Eddie's 6 Bolts. These are super nice. And dropped a lot of weight.
I drove a few packs threw her today and was super impressed. Way better performer then the kings in every way. Stuck to the rocks like a spider, and bolted in a straight line at take offs.
Flexin'
Old 03-15-2016, 09:46 PM   #92
Moderator Rule Breaker
eric113's Avatar
I had a chance to buy Elmo.. Soo I did.
This will be a rebuild and continue of Elmo.
This part of the reason I'm replacing what's going to be alot stuff
Couldn't get the lower rod ends off the skid. They also worn out.
So far I replace the skid plate and upgraded to
Super Shafty wraith link raisers
New stainless steel set screws for lower links
New revo rod ends for lower links
Stainless steel screws for the trans
Brass inserts
eric113 is offline   Reply With Quote
Old 01-30-2017, 03:11 PM   #93
distinctive pd's Avatar
This bad boy still in the works? Need to see updates!
distinctive pd is offline   Reply With Quote
Old 01-30-2017, 04:19 PM   #94
eric113's Avatar
Oh yeah. I been slacking on the updates. I did get it up and running. Ran it yesterday.
I do need to figure out how to mount a servo winch somewhere in the chassis. It pretty small chassis.
Old 01-30-2017, 09:17 PM   #95
Let me know when you're ready to do some wheelin'
Highmark is offline   Reply With Quote
Old 01-30-2017, 10:18 PM   #96
eric113's Avatar
You should join Austin Texas crawlers facebook group. They been going out every Sunday to balcones park off Duval.
Old 01-31-2017, 07:47 PM   #97
eric113's Avatar
I worked on the axles. Here the list I of items I replaced.
Dlux big bearing housings
Lockedup Rc bearings
Lockedup Rc F.I. Spools
HD gears front
UD gears rear
Wraith universals
VP scale chubs front
VP wraith chub rear
VP wraith knuckles front & rear
VP wraith Ti steering links front
Unknown Ti steering links rear
VP diff covers
Lockedup Rc wheel hexes
Hitec rebuilt the servos
Need to get new steering links for the rear.
Old 01-31-2017, 07:56 PM   #98
eric113's Avatar
Never touch the shocks. I want to like them, but since they don't hold oil whatever you do them. They be will be replaced with bomber king shocks. I also threw on rock beast on 1" Slw wheels.
Old 01-31-2017, 08:00 PM   #99
Like
Old 01-31-2017, 08:29 PM   #100
Sweetness
Later,
Farmer
Farmer is offline   Reply With Quote
A buggy called Elmo - Similar Threads
Project Elmo k5 Blazer RoCk-SlIdE 2.2 Scale Rigs 3 03-17-2011 02:26 PM
Not sure about elmo toy ROCKEDUP RICKY Chit Chat 15 01-26-2010 01:19 AM
Death-Threat Elmo Rudukai13 Chit Chat 12 02-28-2008 01:36 AM
Where do you get this Elmo? braceysdad Chit Chat 8 08-13-2007 10:46 PM
