Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Like Tree10Likes
Thread: -Texas 40 part deux.....FJuggy-
Old 01-03-2013, 06:22 PM   #21
R2j
Build What You Want!
R2j's Avatar
Default Re: -Texas 40 part deux.....FJuggy-
Originally Posted by Bananaclip View Post
Man I just love your work. This yoder is mean. Also...I am really digging the surface rust on the cage and the weathered body look.
Thanks again! It's getting there, I'm still on the fence with what I will do with the tube work and body.
Originally Posted by elijah View Post
x 2 on the surface rust rig is sick
Originally Posted by Agama View Post
Looks good Shon. Don't forget about my build...
Thanks Dave! I certainly have not forgot.
R2j is offline   Reply With Quote
Old 01-05-2013, 12:14 AM   #22
R2j
R2j's Avatar
A little ARB bling from RC4WD.....
Old 01-12-2013, 10:56 PM   #23
R2j
R2j's Avatar
Small update. Started working on the drive train, since it is SCX10 based and I want to have as much of a 3D interior as I can. I first mode a couple of new link plates that replace the stock SCX10 skid. Dimension wise they use the same basic location as the skid, but I moved the upper links up 3/8" and the lowers are at the same height, but now right under the frame rails. Moving the lower outward still keeps some decent triangulation and helps reduce the severe angle on the rod ends when using straight links. The picture of the front shows dual bend links, but I will be using straight links like the rears. The new upper link location was an effort to aid in drive line troubles when using AR60 with the SCX10 chassis, in combination with the Axial trans now serving duty as a t-case. I should have plenty of room for a detailed interior. As for the drive, ie: motor and gearing to the t-case, I plan to fab a plate that will hold the Axial spur and motor then be couple via drive shaft to the t-case. I just wanted to be able to have the same gearing options as with a stock trans. More to come on that later, I'm waiting on some flanged bearing yet.
Also had a chance to install my Locked Up 4-40 Acorn nuts...very cool!
And making more progress on the hood.
Turn'Nburn likes this.
Old 01-13-2013, 07:35 AM   #24
Bad Mojo will rise!
Turn'Nburn's Avatar
Very cool! This is giving me motivation to get to work on mine. Sadly, it has gained a patina similar to the Fjuggy's.
I like the Wheels, i'm definitely picking up a set with all the goodies. Are you running the scale hubs too?
Turn'Nburn is offline   Reply With Quote
Old 01-13-2013, 09:54 AM   #25
R2j
R2j's Avatar
Thanks Jon! You better get to work, the JK is way too cool to sit around!
You'll love the Locked Up wheels! They definitely nailed the scale! And yes, I'll be running the scale hubs as soon as I pick up a set
Old 01-24-2013, 07:51 PM   #26
R2j
R2j's Avatar
Picked up a new trans and t-case today, just couldn't pass it up!
Also received some bling to finish up the scale appearance of my wheels! Locked Up R/C scale hub covers for SLW hub wheels.....very nice and complete package now!
Old 01-25-2013, 03:19 PM   #27
RC Mechanic
Bananaclip's Avatar
Love the wheels bro.
Bananaclip is offline   Reply With Quote
Old 01-26-2013, 08:39 PM   #28
R2j
R2j's Avatar
Thanks Banana man! It definitely finishes off the look!
Mr. Postman brought me a little gift today.......my new R3 trans and Hammer t-case!
Old 05-07-2013, 09:42 PM   #29
R2j
R2j's Avatar
Long time no update...since I'm going to use the AR60's on my other build F-Ruggy, I needed to build a new set for this one. So decided to build a set of AXR 10's to help deal with my width issues. Collected everything I needed to build a good set, including Gripfab stainless lockers, Fast Eddie bearings, Axial under and over drive gear and Axial aluminum chubs and knuckles.
Die-Laughing likes this.
Old 05-07-2013, 09:45 PM   #30
Power of the Portals
eric113's Avatar
Sweet! The xr width is going to look perfect!
eric113 is online now   Reply With Quote
Old 05-07-2013, 09:53 PM   #31
R2j
R2j's Avatar
Yep, that's what I figured too I've been on a universal kick, I also threw some in the JK.
Old 05-07-2013, 10:29 PM   #32
eric113's Avatar
Any thoughts about going with ar60 housings cut down ?
Old 05-08-2013, 09:33 AM   #33
R2j
R2j's Avatar
Not really, I think I may go with the Curries once VP get's the XR length tubes done, and since I have all the parts to put in them. I'm going to stick with the centered pumpkins on this one.
Old 05-08-2013, 10:03 AM   #34
eric113's Avatar
Those would look awesome! Glad to see this project hasnt been forgot about.
Old 05-08-2013, 10:12 AM   #35
~The Scale Shop~
STANG KILLA SS's Avatar
agreed. the XR width will look so much better.
great scale eye as usual Shon.
this thing has been like watching a kid grow up.
cant wait for more.
STANG KILLA SS is offline   Reply With Quote
Old 05-08-2013, 10:14 AM   #36
R2j
R2j's Avatar
Yea I usually don't go for too much bling, but I think they will look good. Oh it hasn't been forgot, just swapping parts around and lots of irons in the fire. That's why I built the JK, so I could have at least one out of the four running.
Old 05-08-2013, 10:23 AM   #37
R2j
R2j's Avatar
cant wait for more.
Yep! Thanks Cory! I always knew that the AR's were not exactly what I was after. The XR width is perfect, now I need to get the wheelbase spot on. I'm thinking 13" will be the sweet spot.
Old 05-08-2013, 06:11 PM   #38
Slick Rick
Die-Laughing's Avatar
She's a beauty!
Die-Laughing is online now   Reply With Quote
Old 05-09-2013, 02:48 PM   #39
Scale for Life...
ColquittCustom405's Avatar
WB looks good to me...nice so far. Not a fan of the RipSaws but they look good on here..
ColquittCustom405 is offline   Reply With Quote
Old 05-09-2013, 10:28 PM   #40
R2j
R2j's Avatar
Originally Posted by Die-Laughing View Post
She's a beauty!
Thanks Rick!
Thanks DJ! Yea I only like the height of the Ripsaws, but waiting for the new Axial BFG's now. Hopefully they will be out soon. Wheel base will need to be just a hair shorter to fit into the rules, the axle is just a bit past the rear tube work.
-Texas 40 part deux.....FJuggy- - Similar Threads
Project Part by Part! 1.9 or 1.5 well see...... Robe 1.9 Scale Rigs 5 10-23-2012 04:16 PM
2009-2010 Winter Series Part 2 - Comp #4 at Texas Canyon - 4/11(HD) Ricky G Videos! 16 04-24-2010 10:18 AM
part front& part behind the axle steering assassin_tl Venom Creeper 3 11-03-2009 07:49 AM
Part Crawler, Part Basher WesTX Traxxas Maxx Crawlers 2 12-07-2008 07:27 AM
TXRCRCA East Texas chapter presents: comp 1 Tyler Texas mexiCAN Louisiana 12 05-18-2008 11:19 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
