09-18-2015, 06:45 PM | #41 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
| Re: Crawler Innovations "Beastly Beauty" - 2.2 Ultra 4 Rig
Some beautiful joints there my man!
09-29-2015, 08:28 AM | #42 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Re: Crawler Innovations "Beastly Beauty" - 2.2 Ultra 4 Rig |
09-29-2015, 08:29 AM | #43 |
And then?
09-29-2015, 08:39 AM | #44 |
Parts are arriving and time is getting short before Crawlapalooza #9 next weekend in Disney, Oklahoma. Castle Creation One Cell Version MMP ESC Castle Creation BEC Tekin Pro4 HD 2500KV Motor Thank you to my sponsor Vanquish Products for the incredible parts. Since the original axles I built to use in this Beast went in to the CI Dakar truck, the new set will use Vanquish Products new version two axle case that has thicker tube walls and redesigned captured bearing retainers. I will be using the racing Ackerman vp steering arms and Ti drag link. Axial under drive gears front and rear with Grip Fab Lockers. ..Uploaded from the lab @ the C.I. Compound... |
09-29-2015, 01:56 PM | #45 |
Panels removed from chassis so assembly can begin, RC Fab Works has top notch craftsmanship; ..Uploaded from the lab @ the C.I. Compound... |
09-29-2015, 06:42 PM | #46 |
Progression; ..Uploaded from the lab @ the C.I. Compound... |
09-29-2015, 08:26 PM | #47 | |
| Re: Crawler Innovations "Beastly Beauty" - 2.2 Ultra 4 Rig Quote: | |
09-30-2015, 07:50 PM | #48 |
| Re: Crawler Innovations "Beastly Beauty" - 2.2 Ultra 4 Rig I used the opportunity to build two more axles while I had everything out to do so... Sneak peak; ..Uploaded from the lab @ the C.I. Compound... |
09-30-2015, 08:15 PM | #49 |
Today's progress on the beastly beauty; Specs; Vanquish Products Case Axial complete metal gear set Boca bearings Hot racing steel spur gear 57t 32p and input assembly BWD FOFF version aluminum motor plate Tekin Pro4HD 2500KV Motor RRP 14t pinion Crawler Innovations 5mm extended & lightened front and rear 4340 steel transmission outputs (PM me if you'd like a set) Carbon Fiber ESC tray Making progress... ..Uploaded from the lab @ the C.I. Compound... |
09-30-2015, 08:59 PM | #50 |
RCC Addict Join Date: Dec 2012 Location: Crookston
You have some great looking builds that's for sure. Like them all. Nice work. P.S. also have great foams. Just ordered another set. Should be here tomorrow. |
10-05-2015, 07:21 PM | #51 |
10-05-2015, 07:25 PM | #52 |
Mo progression... Blue BEC runs the car at 7.4V and the clear BEC runs the two MORE light bars at 9V. I like to run 4S lipo and because I do it requires the double BEC's. ..Uploaded from the lab @ the C.I. Compound... |
10-06-2015, 07:04 AM | #53 |
I am a fan Traxxas big bore shocks. I run them on nearly everything and have years of experience with them. The shock body is big enough to hold enough shock oil to actually perform & control the vehicle. From left to right, here are the three most common big bores; Left is 2660 and is 3 3/8" e2e Middle is 2661 and is 3 3/4" e2e Right is 2662 and is 4" e2e ..Uploaded from the lab @ the C.I. Compound... |
10-06-2015, 08:40 AM | #54 | |
10-07-2015, 08:23 PM | #55 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
Hmm, Tiger Dormant orange sparkle with clear for the powder choice I would guess.
10-17-2015, 10:04 PM | #56 |
| Re: Crawler Innovations "Beastly Beauty" - 2.2 Ultra 4 Rig ..Uploaded from the lab @ the C.I. Compound... |
11-12-2015, 09:14 AM | #57 |
#CI #beastlybeauty on the rocks for some early morning sunshine and testing. This #rcfabworks chassis is no 8 of the first generation of Beast Chassis. Powered by #castlecreations mamba max pro one cell esc with a #Tekin pro4HD 2500KV motor, #hitec servo, #futaba 4pk TX & RX, running either 3s or 4s lipo, MORE LED Light bars x2 that were custom made for the Beastly Beauty in blue and white. #6boltwheels in the 1.50" width using #vp SLW hubs and the new #vanquishproducts KMC center hubs, with #doubledeucefoams in the 5.5" Comp cut size with Medium Outers, with the #crawlerinnovations cut #pitbulltire growlers #buildit #builtnotbought #ultra4 #u4rc #koh #KMC #solidaxle #dmg #rc #rccrawler #rockracer #4x4 #rockcrawler ..Uploaded from the lab @ the C.I. Compound... |
11-12-2015, 09:17 AM | #58 |
More pics; Mrs. CI made an awesome custom embroidered top for this rig: ..Uploaded from the lab @ the C.I. Compound... |
11-12-2015, 09:18 AM | #59 |
More photos; ..Uploaded from the lab @ the C.I. Compound... |
11-12-2015, 09:23 AM | #60 |
More photos of the CI cut growlers; ..Uploaded from the lab @ the C.I. Compound... |
Crawler Innovations "Beastly Beauty" - 2.2 Ultra 4 Rig - Similar Threads | ||||
Crawler Innovations "Big Blue" - 2.2 KOH Crawler; wraith based | Nova's Ark | Axial Wraith | 91 | 07-17-2019 02:22 PM |
2013 Mini Clod "Crawler Innovations" Shelf Rig | Szczerba | Tamiya Clod Buster | 62 | 01-20-2019 08:56 AM |
Crawler Innovations "Top Shelf" Ultra 4 | Nova's Ark | 1.9 Scale Rigs | 100 | 06-01-2018 10:31 PM |
