Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Jeep Brute Double Cab
Old 07-26-2014, 10:21 AM   #21
I joined the Band!
Default Re: Jeep Brute Double Cab
The Jeep I'm building is a hybrid of both the JK8 and the Brute. The bed is level with the bottom of the window frames and that is what the brute offers over the JK8 is the bed depth and size. I'm staying with the short wheel base and short bed but is deep and changes the look.
twissted is offline   Reply With Quote
Old 07-27-2014, 05:22 PM   #22
I joined the Band!
So looking at the Rear window as you see above. it isn't going to be this shape or size for long I'm making it like the JK8 sliding window and yes it will side when it's done.
Old 07-28-2014, 07:50 PM   #23
Looking great man
4X4 Freak is offline   Reply With Quote
Old 07-28-2014, 10:52 PM   #24
I joined the Band!
It's hard to see because of the protective cover on the Lexan but the window is in. I have more to do such as cut the center out and add rails on the edges and trim around the frame. and lots of sanding. Oh by the way my fingers never get tired of sanding because I wrap sad paper around the hacksaw blade and use it as my finger. Try it it will save time and it is clean way to get even sanding done.
Old 07-28-2014, 11:12 PM   #25
I joined the Band!
https://www.youtube.com/watch?v=brlm2qP5b0w
Old 07-30-2014, 07:54 AM   #26
I joined the Band!
Here is some more detail of the rear window. I will add more out side edging to the window just before paint.
I had to cut the reat seat to make a notch so that the track for the window would fit. I also added a slight bend in the upper part of the seat. I looks better, (sporty).
Old 07-30-2014, 12:03 PM   #27
I joined the Band!
The solid aluminum chassis is under construction. The ls motor looks cool but is a pinch on the small size because it' 1/12 scale.
[URL=http://s628.photobucket.com/user/Jack59/media/XJ%20Pickup/002_zps84beed8e.jpg.html]
Old 07-30-2014, 06:56 PM   #28
I joined the Band!
Linked in the front and will have the back done soon. The arms upper and lower are made of titanium.
Old 07-31-2014, 06:34 PM   #29
I joined the Band!
Old 08-03-2014, 03:15 PM   #30
I joined the Band!
Old 08-03-2014, 08:56 PM   #31
I joined the Band!
Old 08-04-2014, 10:25 AM   #32
I joined the Band!
Old 08-05-2014, 01:42 PM   #33
I joined the Band!
Steering is in!
The upper steering link is made with stainless Heim Joints.
Old 08-05-2014, 06:58 PM   #34
I joined the Band!
Cantilever rear suspensionis in!
Old 08-07-2014, 12:54 AM   #35
I joined the Band!
I went wit a stiffer spring so that it works with the weight of the body. It is very smooth and progressive. I like it.
Old 08-09-2014, 01:08 PM   #36
I joined the Band!
If you have the body to do one, you should. They have lots of potential.
It helps to get a band saw from Harbor Freight (a cheap one) to cut frame and stuff.
Old 08-10-2014, 08:57 PM   #37
I joined the Band!
Old 08-11-2014, 03:46 PM   #38
I joined the Band!
I just ordered some parts to keep the build going. I have the RC4WD T1 Disruptor Black Transfer Case (2.18:1 Gearing) and a set of drive shafts JUNFAC HARDENED UNIVERSAL SHAFT (95-130MM) 5MM HOLE on the way also. And some more WHITE STYRENE on the way. should be another week before the parts show up.
Old 08-13-2014, 09:42 AM   #39
I joined the Band!
This is the reason I didn't do the long bed. I wanted the frame to work with this body also. It's going to be a FJ 43 ICON when it's done. the light bucket are Proline and the front floor has been modified also. It will have a roll cage and removable hard top. I need to come up with some working tail light lens. Any ideas?
Old 08-13-2014, 04:25 PM   #40
I joined the Band!
I did get some of the bed pieces in. I'm waiting on the thinner sheets to come in.
Jeep Brute Double Cab - Similar Threads
Double Cab Brute Build BurningMaverick 1.9 Scale Rigs 24 03-20-2014 08:50 PM
58 VW Double Cab NatalieMorgan 1.9 Scale Rigs 88 07-15-2013 10:34 PM
Tacoma Double Cab / Regular Cab Mr. Ed General Scale Talk 6 04-27-2013 12:48 PM
RCMODELEX Double Cab Dab Cab video ray2286 Scale Videos! 3 03-05-2013 08:56 PM
Brute double cab athenscyclist Chit Chat 10 03-23-2012 10:56 PM
