08-14-2014, 06:05 PM | #41 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
| Re: Jeep Brute Double Cab Last edited by twissted; 08-14-2014 at 06:11 PM. |
08-15-2014, 12:14 AM | #42 |
| Re: Jeep Brute Double Cab This is my take on a clean snorkel mount. I will give it more detail when the paint is going on. I will also use a zip tie with the roof rack. Last edited by twissted; 08-15-2014 at 12:43 AM. |
08-15-2014, 05:16 AM | #43 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
What method are you using to cut the hood?
08-15-2014, 09:29 AM | #44 |
A razor saw that you can find at all your hobby stores or on line. It does 95% of all the cuts fast, clean and strait! I also use a dremel cut wheel in some of the tricky spots of cutting. I picked up this set on ebay for less than 5 bucks! Last edited by twissted; 08-15-2014 at 09:35 AM. |
08-15-2014, 09:38 AM | #45 |
| Re: Jeep Brute Double Cab Last edited by twissted; 08-15-2014 at 09:53 AM. |
08-16-2014, 02:44 PM | #46 |
The .030 styrene came in today. I have a little bit more to tidy it up and file and smooth the edges. I wil use 3M bed liner spray to finish. I have the coolest paint job for this DBL Cab build. I will be very different than any that's ever done. Last edited by twissted; 08-16-2014 at 02:53 PM. |
08-17-2014, 02:40 PM | #47 |
| Re: Jeep Brute Double Cab |
08-24-2014, 01:43 PM | #48 |
I'm changing the front also. I'm going with what I have done in the past. I like it because it works well and it doesn't look like everything else that is being made these days. Last edited by twissted; 08-24-2014 at 01:59 PM. |
08-24-2014, 09:35 PM | #49 |
Jeep Brute Double Cab - Similar Threads | ||||
Double Cab Brute Build | BurningMaverick | 1.9 Scale Rigs | 24 | 03-20-2014 08:50 PM |
58 VW Double Cab | NatalieMorgan | 1.9 Scale Rigs | 88 | 07-15-2013 10:34 PM |
Tacoma Double Cab / Regular Cab | Mr. Ed | General Scale Talk | 6 | 04-27-2013 12:48 PM |
RCMODELEX Double Cab Dab Cab video | ray2286 | Scale Videos! | 3 | 03-05-2013 08:56 PM |
Brute double cab | athenscyclist | Chit Chat | 10 | 03-23-2012 10:56 PM |
