the northkona Shannon Campbell Ultra4 Since I got the bug for building a chassis out of brakeline (my Bomber rig ) I have been searching for a while for another Ultra4 rig to copy. It's taken a long time but I have finally grown to love the look of Shannon Campbells rig , its still damn ugly tho. Fast , very competitive and ugly. I love it. It will be using Wraith axles for a few reasons, I have a heap of spares , tons of great companies make very cool upgrades for them , they're tough and give a heap of steering. I have yet to see an IFS that looks scale enough for my liking. This build will be scaled off photos of the 1:1 so it should be close to the real thing .....minus the IFS. [IMG]http://i57.tinypic.com/2rxwmr5.jpg[/IMG] I'm using 1/4 and 3/16 brake line soldering with Map and silver solder . [IMG]http://i59.tinypic.com/2yz0u2a.jpg[/IMG] [IMG]http://i58.tinypic.com/2s8h5wi.jpg[/IMG] [IMG]http://i59.tinypic.com/2dqpkkg.jpg[/IMG] [IMG]http://i61.tinypic.com/2090o0p.jpg[/IMG] At this stage I thought it was going really well , whats the line ? " measure twice, cut once " I managed to screw up one of the measurements on the rear section of the frame , it was 50mm/ 2 " too short. AAAAAARRRRRRGH !!!!! out with the hacksaw..... [IMG]http://i57.tinypic.com/9apr0p.jpg[/IMG] |
Re: the northkona Shannon Campbell Ultra4 The 3/16 tube fits perfectly inside the 1/4 so I slipped it inside all the joins of the new rear and welded it together. [IMG]http://i57.tinypic.com/4t9d00.jpg[/IMG] How it sits now , spare time seems short around here. [IMG]http://i62.tinypic.com/w015om.jpg[/IMG] [IMG]http://i59.tinypic.com/294km0l.jpg[/IMG] [IMG]http://i61.tinypic.com/25ui138.jpg[/IMG] |
Re: the northkona Shannon Campbell Ultra4 Looks like a sweet start. Some of the early Campbell rigs were solid/solid I believe. Maybe you can get some ideas from the older rigs, if you haven't already done that. |
Re: the northkona Shannon Campbell Ultra4 Quote:
Sweet build, btw. Always love Campbell rigs (even the cone dodgers). If it's anything like your Napier rig this is going to be killer. |
I'm still deciding how much I am going to bling this up , VP make sooo many nice shiny things ! |
Re: the northkona Shannon Campbell Ultra4 Man that's looking awesome ! I was going to finish my ifs this winter and then sell it and build the Campbell rig. All well guess I'll stick with what I got ! Lol.... |
You've got the skills , give it a shot "thumbsup" |
Re: the northkona Shannon Campbell Ultra4 I got a few more braces put in today and looking at sorting out motor/esc/battery positions . One of my MMP's died yesterday so I might go RX8 in this rig . [IMG]http://i61.tinypic.com/29yp6hi.jpg[/IMG] [IMG]http://i57.tinypic.com/20a2miv.jpg[/IMG] |
Re: the northkona Shannon Campbell Ultra4 Nice progress so far! |
Re: the northkona Shannon Campbell Ultra4 I love the Campbell rigs. Maybe that's because he is the only big timer that I have ever met and actually talked to, on three different occasions even. Very easy going and down to earth, until he gets behind the wheel:shock: The build is looking good. Nice fix on the chassis. Takes a bit of bravery to do what you did, feels a lot better afterwards though don't it? |
Re: the northkona Shannon Campbell Ultra4 I made a start on the trailing arm setup and the rear shocks . I found some old HongNor 1/8 buggy shocks with a 3.5mm shaft that are a bit longer than the proline shafts , I'll still be using the Proline bodies but these shafts will make a longer shock . I'll fuel tube the shaft as a bump stop later. [IMG]http://i57.tinypic.com/350jy9l.jpg[/IMG] The top one is with the longer shaft , the lower one is a standard Slash rear. I had a go at making some trailing arms , theyre a bit rough but and I'd like to make some better ones but somehow I think once this rig is built they'll be staying on there. Beefy Stainless tube with stainless plate and stainless allthread laser welded together. [IMG]http://i58.tinypic.com/2v142n4.jpg[/IMG] [IMG]http://i62.tinypic.com/xarifr.jpg[/IMG] [IMG]http://i58.tinypic.com/jhy06t.jpg[/IMG] This is how its sitting at the moment, I was going to try and run a real short link on the front axle but its not going to work out . The driveline angle would be too much so the skid plate is going to be cut back to about the front of the spur and regular length Wraith links will be made up. I'll do a bit on the front end tomorrow. [IMG]http://i61.tinypic.com/1zcmkci.jpg[/IMG] This is where I really get impatient , parts are usually about a 2 week wait out of the States unless I pay $50 shipping for each order, I'm waiting for a 155mm rear driveshaft and trying to find a black VP Wraith axle housing....now green method 101's would be just perfect if I could find some of them too... [IMG]http://i59.tinypic.com/2vhzrc4.jpg[/IMG] |
Re: the northkona Shannon Campbell Ultra4 Nice trailing arm setup. laser welded you say? |
Here are the stainless swing-away mirrors I made for my Penhall rig, for scale reference the screws are 1.4mm and the "mirrors" are 16mm/ 5/8". Stainless and titanium are really easy to laser weld and the welds need no clean-up. Its one great toy I'd love to have at home but the 30K pricetag is a bit much ! [IMG]http://i57.tinypic.com/hv9wqt.jpg[/IMG] |
Re: the northkona Shannon Campbell Ultra4 I got it to a roller stage today , all the links are made and the skidplate was cut back to fit in a better length of link. Next up is to fab a battery box and finish off the spacers for the shock ends. [IMG]http://i59.tinypic.com/2v2d0z9.jpg[/IMG] [IMG]http://i58.tinypic.com/wckb4w.jpg[/IMG] Great clearance on flex, no rubbing on anything, more good luck than good planning ! [IMG]http://i62.tinypic.com/fw0h6s.jpg[/IMG] A mock-up with some paper panels. [IMG]http://i59.tinypic.com/33a53k3.jpg[/IMG] [IMG]http://i58.tinypic.com/261osnm.jpg[/IMG] [IMG]http://i60.tinypic.com/33k9i7a.jpg[/IMG] I'm hoping the performance of this rig matches the 1:1 , I'm loving my Bomber rig right now but this may be my #1 . |
Re: the northkona Shannon Campbell Ultra4 Beautiful northkona ! Looking forward to seeing some video of this running ! |
Re: the northkona Shannon Campbell Ultra4 Yes sir! Proportions look spot on! |
Re: the northkona Shannon Campbell Ultra4 I'm gathering scale bits for the cab , this rig just had to have the cutting brakes in it ! [IMG]http://i60.tinypic.com/9i7ddt.jpg[/IMG] |
Re: the northkona Shannon Campbell Ultra4 1 Attachment(s) Attachment 291070 Did somebody say BLING !! I'm really happy how my wheels have come out, they're RC4WD Predator wheels that I painted with DNA "Dragonfly" and the beadlocks are painted with flat black Ceramatec. The tyres are going to get a heap of siping but I really like the size , a bit narrower than the RB2's and just a touch shorter. [IMG]http://i60.tinypic.com/2ugcffm.jpg[/IMG] I wanted something to fill the rear so I have had a go at making the exhaust and headers with an Exo engine . It looks pretty dodgy now but a bit of paint will tart it up. [IMG]http://i62.tinypic.com/142gger.jpg[/IMG] |
