12-29-2014, 09:43 PM | #21 |
Rock Crawler Join Date: Dec 2012 Location: Utah
| Re: dp's "1/2 Tundra" C3 project (NON-U4) 2015 rig |
01-21-2015, 12:45 AM | #22 |
Just found out that the Blue Monkey knuckle weights i bought in November are now no longer SORCCA legal..kinda bummed about that, especially cause C3 is a "MODIFIED" class AND i just purchased these darn things... hopefully vendors dont take too big of a hit now with a smaller margin of a crowd that wont be purchasing these with the SORCCA rules change. I understand they are not "scale" but that doesnt mean im not disappointed. Knuckle weights are simply just freakin sweet!!! But that is enough of that.. I worked on the Tundra over the weekend as well as tonight started on the front shock towers and mocking up the front motor Mount so I can tie it all together. check it out. ... Used some fab tabs from RPP and some 3/16 sleeves and brazed it all together. Also fabbed in my firewall that will tie in my shock towers and motor mount. I've got quite a bit more bracing to put in up front but you get the idea. Needed a new style motor brace plate to accommodate the BWD FOff billet motor plate Made a cardboard template Then cut and ground 1 outta .083 CF!! It will look similar to my C2 comp buggy pictured below when its all mounted up in the "1/2 Tundra" |
01-21-2015, 11:05 AM | #23 |
Quarry Creeper Join Date: Jan 2013 Location: UTAH
Dang Braydon your amazing, looking siiiiick bud |
01-21-2015, 03:23 PM | #24 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
01-21-2015, 05:40 PM | #25 |
You've got a great looking build happening here. I like your design you've been thinking about this one for a while? it's sweet.
01-21-2015, 08:46 PM | #26 |
Thanx fellas this has been a very fun build, hoping to have alot more photos up in next couple days!
01-21-2015, 08:59 PM | #27 |
Nice innovation of parts in this build.
01-25-2015, 12:09 PM | #28 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
03-11-2015, 11:08 PM | #29 |
Thanx fellas!!! Small update: Front motor plate/mount |
03-31-2015, 09:05 PM | #30 |
Finished front bumper tonight and tube work above it for the grill and tied it into the shock towers. Im happy with how its coming together.. Just need to build the battery plate that goes between the steer servo and front motor mount then I can sand blast this puppy and paint it!!! |
04-03-2015, 08:35 PM | #31 |
Finished fab today and sand blasted and painted everything . .chassis is sitting in the oven right now baking. |
04-09-2015, 12:29 AM | #32 |
Chassis is painted now and partially reassembled. . IM PRETTY HAPPY WITH PINION ANGLE AND SHOCKS SO FAR!! |
04-09-2015, 12:30 AM | #33 |
STARTING TO LOOK LIKE A TRUCK!! SORTA!!!! |
04-09-2015, 11:02 AM | #34 |
Rock Stacker Join Date: Nov 2009 Location: wny
I absolutely love it!! That's the Tundra I've been wanting to build but just couldn't visualize! Great work man, I love your builds too, still bummed I missed out on picking up that badass Escalade you built a while back. If you ever decide to let this one go, search me out |
04-10-2015, 03:48 AM | #35 |
Quarry Creeper Join Date: Dec 2011 Location: Gold Coast, Australia
I've been trying to do a front mount motor in my c3/u4 chassis for a while but haven't been able to work a way to still use a dig trans in the centre but I love the way you have tackled this! I remember seeing it in your Caddy and c2 builds but never thought it would work in mine but I think it will actually work perfectly. Just wondering what you did to be able to use the spur shaft run through the trans for the tcase shaft? |
04-10-2015, 12:58 PM | #36 |
Thanx guys! Most of my inspiration came from Toyzuki's front mount...his works awesome. .. i however like to build everything i possibly can... mostly because I love to build prob. more than I like to drive them. I with will post some pics tonight on my assembly for front mount and shafts etc... |
04-11-2015, 09:22 PM | #37 |
Rock Stacker Join Date: Jul 2008 Location: amarillo
This sir is badass!! |
04-11-2015, 10:00 PM | #38 |
Moderator Join Date: Jan 2004 Location: chicago
04-14-2015, 06:11 AM | #39 | |
| Re: dp's "1/2 Tundra" C3 project (NON-U4) 2015 rig Quote:
04-14-2015, 09:34 PM | #40 |
This thing is turning iout great im really happy with it. ... I've had a few ask about assembly pics on my custom front motor mount and I'm happy to share First pic is Axial slipper shaft modified (carefully ground) for the front motor mount case. .. aluminum spur flange is required from Hot Racing. .. You must use a plastic axial trans to cut up for mounting purposes and pass through for spur/driveshaft. Also can either use stock upper gear or spacer of equivalent length. Second shaft is AX10 style (non slipper) for the T-case or Axial trans. . PICS WITH FLANGE AND DRIVE SHAFT PIECE ATTACHED TO FRONT MOTOR MOUNT CASE |
dp's "1/2 Tundra" C3 project (NON-U4) 2015 rig - Similar Threads | ||||
dp's C1 local club build off rig "MY-LUX" w/ a side of Yeti | distinctive pd | 1.9 Scale Rigs | 18 | 02-26-2015 10:49 PM |
New project: "The Shop Rig", MRC based Jimny Mud Dragger | 89redranger | Losi Mini-Rock Crawler | 20 | 12-17-2013 02:01 PM |
Project***"hawaiian Pryde" Toyota Tundra | scale808 | 1.9 Scale Rigs | 24 | 01-28-2009 05:51 PM |
My Tundra project " Big Dog " | sleek6mt | 1.9 Scale Rigs | 9 | 12-01-2008 12:44 PM |
