12-15-2006, 09:48 PM | #1 |
Pebble Pounder Join Date: Feb 2005 Location: San Diego
| K2-3S progress....
Well I am building a scaler. Here are some specs. HH Revolver(original) 8T pinion Mamba ESC RC4wd R2 Trans Extreme RC Delrin Links 4.5" uppers 5" lowers RD400 Solid Delrin Beadlocks with Moabs Cirrus CS80 Clear servo Stampede big bore shocks Some items to come: Extreme RC Delrin Steering links TC3 Shocks or HPI Pro MSD servo link plates(in the mail) Well on with some pics. Last edited by bruiserin2002; 12-28-2006 at 01:34 AM. |
12-15-2006, 09:50 PM | #2 |
This is going to be the body for my pulling rig. Kinda pricey but oh well saves me the time. Thanks CJC. It is not going on this chassis. I think I am going to put it on a K2-3L. |
12-16-2006, 08:46 AM | #3 |
RCC Addict Join Date: Feb 2005 Location: Minnesota
That's a nice body you got there. Must of cost a pretty penny. The K2-3S is coming out real nice. You picked some nice parts to use but I don't think the zip ties are goin to keep the tranny in place. |
12-16-2006, 05:44 PM | #4 |
Pebble Pounder Join Date: Nov 2006 Location: Rye Brook, NY
I agree. I assume you are going to mount the tranny with screws. I really like those links. Could You post a link to where you bought those? In my current trail rig i am using a k2 3s. It is a great chassis.
12-16-2006, 06:41 PM | #5 |
yeah the zip ties were just to mock up. Bem- The links I am using are from extreme r/c a vendor on here. I told him the length I needed and he made them. The top links are 4.5 inches and the lower links are 5 inches. They are pretty even if you use the MSD servo link mounts I believe.(Haven't recieved in the mail yet but should be perfect. 1/10 scale bodies sit in the wheel well perfect. |
12-16-2006, 08:31 PM | #6 |
Thanks, its really coming together
12-16-2006, 08:40 PM | #7 |
Newbie Join Date: Sep 2006 Location: Norcal
I like the color of that ford body. very nice!
12-20-2006, 10:12 PM | #8 |
Here is a little update. I have all the electronics in the truck. The 2 cell 1350mAH Lipo pack is sitting next to the R2 Tranny held in by two pieces of delrin on the one to the rear of the truck I screwed my reciever in the the opposite end of the delrin from the chassis. I will try and get some better pics of the floating reciever. Well here are some pics let them do the talking. My COG is pretty low. I think I am going to get some different shocks but these will work for now. Let me know some input. Still working on a body. |
12-20-2006, 10:22 PM | #9 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
Three words, Clocking Axle Cs |
12-20-2006, 10:26 PM | #10 |
Clocking axles C's? I still have some tweaking to do. I need to get the steering dialed in. Going to order delrin steering links and aluminum servo horn. I forgot to get some articulation pics will get some up tomorrow.
12-20-2006, 11:15 PM | #11 |
I wanna be Dave Join Date: Jun 2004 Location: Whales
Very nice!!!!! |
12-28-2006, 01:10 AM | #12 |
Well I have some articulation pic. The truck is working out ok with the big bore shocks I have I might keep them. I might put on the K2 shock towers and test them out. well enough with the talk and on to the pics. Let me have any ideas if you have some. |
12-28-2006, 01:13 AM | #13 |
If you dont have the pede shafts connected, thats why its working okay, my maxx shafts bind with 3.8" shortened maxx shocks! Anything more than 90mm it binds with a 12.25"Wb
12-28-2006, 01:19 AM | #14 |
I am using pede shafts and pede big bore shocks. My top shock mounts I cut to an angle of lower mounts about 45 degrees. They don't bind at all. I drove in and out of each shot. Not bad consider I am on a tile floor. I am running 4.5 top and 5 lower links on my truck. I am about 12 3/4 wb. I wouldn't trade this truck for the world.
12-28-2006, 01:23 AM | #15 |
My rear shaft are two females with a male CA glued into one of them. It was a hair too short and would pop off when I was testing her. The only problem I am having is with the steering I don't get a lot of turning radius. Any ideas?
12-28-2006, 01:24 AM | #16 |
RCP and MIP are making some CVDs, and get axle Cs and alloy knuckles, should be good.
12-28-2006, 01:25 AM | #17 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
clocking axle c's, replace the plastice hub mounts with aluminum ones that allow you to rotate the axle without sacraficing your steering quality TLTs, C-Hubs, and Axle Clocking........... |
12-28-2006, 01:33 AM | #18 |
Ah! That is what is causing my steering not being up to par. Well I am going to put an order in for some things tomorrow. Thanks for the help guys.
12-28-2006, 02:31 AM | #19 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
Nice looking Truck. Been wanting to see a K2-3S built up. Would you happen to have a pic of it with the body on from the side? I would like to see what the body looks like on a K2-3S chassis? Thanks |
12-28-2006, 02:37 AM | #20 |
Thanks. I will take some more pic in the morning.
