05-30-2015, 07:33 PM | #41 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
| Re: Szczerba's Second CXT Build
How do you do your tube rolling? Looking really good. Wes |
05-30-2015, 07:41 PM | #42 |
| Re: Szczerba's Second CXT Build |
05-31-2015, 08:24 PM | #43 |
Welp, I dont have enough 1/4" or 3/8" 0.035" tube left to finish the rear box. Ordered more metal but it will be 4-5 business days at least to get it here. Made the start of the body mount with flat bar and some 3/16" tube. Small panel will fill in this area. I made it like this because I did not want the lower sliders to come all the way up to the cab, just didn't look right with that much space looking from the side at the subframe. Also, the mount will serve as a front inner fender mount as well. ... Last edited by Szczerba; 05-31-2015 at 08:28 PM. |
05-31-2015, 09:03 PM | #44 |
05-31-2015, 09:07 PM | #45 |
05-31-2015, 09:09 PM | #46 |
I'm sure at some point I'll be bored out of my mind, or going mad from the lack of red meat. You know where to find me. |
05-31-2015, 09:20 PM | #47 |
talk to me about the inner link geometry. front lower than rear. longer WB looks good, at it still looks like a shorty. I like your lowered sliders idea. some 1.5" diameter tube fuel tank sliders would have been over the top. on second thought, maybe fuel tank sliders are not such a great idea.... |
05-31-2015, 09:37 PM | #48 | ||
| Szczerba's Second CXT Build Quote:
Mmm....cow muscle. Quote:
Squat/Anti-Squat, ie, suspension leverage. Chassis uppers may get moved to outside of subframe, just have to make a dual shear mount. Simple. Also, I didnt go with a ton of lower link triangulation at the skid, knowing this rig could be a little top heavy. Sway-bar parts on order too. Trying to keep the rear metal work to a minimum. With the sliders at the bottom of the cab, there was just too much "space" when viewed from the side. There is still a ton of clearance from ground to slider. I have tamiya semi fuel tanks but it didnt look right. Using this rig as loose inspiration. The one you posted but most of these class support trucks dont have external showing fuel tanks. | ||
06-01-2015, 09:42 AM | #49 |
I noticed in the vid you found the bed was actually canvas. I never knew that.
06-01-2015, 09:44 AM | #50 | |
| Re: Szczerba's Second CXT Build Quote:
I ordered some black polystyrene sheet. 0.020-0.060, 12"x48. Going to try and form it over the bed area. We'll see, if not, Ill do side and top panels. | |
06-01-2015, 06:33 PM | #51 |
Ripped some 1" square tube. Then cut and welded. Was going to go with 3/8 tube but said, nah. |
06-01-2015, 07:13 PM | #52 |
Rock Crawler Join Date: May 2012 Location: Washougal
This thing is a real beast! I love the bumper work. Don't forget the sweep the shop floor when you are done |
06-01-2015, 09:01 PM | #53 | |
Thanks. The 1" square tube works well for these bigger trucks. Sweep every night but it doesn't look like it. Lol Tacked to hinge. Need to cut one tack and realign bumper. A little crooked. Will weld up fully and make a short bumper skid. | |
06-01-2015, 09:06 PM | #54 |
#profabricator
06-01-2015, 09:08 PM | #55 |
06-01-2015, 09:30 PM | #56 |
What could go wrong? Join Date: Oct 2013 Location: Southern Ontario
#idontevenhavemetaltoworkwith #amidoingthisright? Very nice build! Last edited by Noll11; 06-02-2015 at 06:36 AM. |
06-02-2015, 08:06 AM | #57 |
06-02-2015, 08:54 AM | #58 |
Where did you get the plates you used for your shock mounts? Cut and drill them yourself? Wes |
06-02-2015, 08:59 AM | #59 |
06-02-2015, 11:23 AM | #60 |
Looks like the blue diffy cover has had a few encounters with things that didn't get out of the way fast enough! |
Szczerba's Second CXT Build - Similar Threads | ||||
Szczerba's IFS SCX Build | Szczerba | Axial SCX-10 | 236 | 08-27-2016 07:24 AM |
Szczerba's 1.9 Beckworks Rebuild Build | Szczerba | 1.9 Scale Rigs | 42 | 07-04-2015 08:53 PM |
Szczerba's 2.2 CXT | Szczerba | Axial Wraith | 109 | 12-04-2013 06:08 PM |
Szczerba's Terra-X Build | Szczerba | Axial Wraith | 21 | 02-25-2013 09:10 AM |
Was Szczerba's Defender 90 Build. On to the Next. | Szczerba | 1.9 Scale Rigs | 22 | 07-07-2012 05:18 PM |
