06-07-2015, 08:20 PM | #101 |
| Re: Szczerba's Second CXT Build
Thanks guys. Debating a FreqEsKinz custom wrap on the bed at least. |
06-09-2015, 09:17 AM | #102 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
no updates in 2 days, thats total blasphemy.
06-09-2015, 09:52 AM | #103 |
agreed. he better be working on a sick 48 hour custom airbrush paint job.
06-09-2015, 09:59 AM | #104 |
| Re: Szczerba's Second CXT Build Mowed the 4.13 acre Szczerba Ranch last night and sent an email to FreqEsKinz for help with a wrap or sticker setup late late last night.
06-11-2015, 09:12 PM | #105 |
Electronics platform Styrene, form, bake at 250 for 30mins= wheel tubs Rears Fronts and rears Rears are not glued or in final position. Will make shock hoop covers too. Underside has mucho protectíoñ. |
06-13-2015, 12:28 PM | #106 |
Work. Cut and lengthed MIP out back. |
06-13-2015, 09:30 PM | #107 |
Stuff |
06-13-2015, 09:32 PM | #108 |
| Re: Szczerba's Second CXT Build Truck is 14.00lbs as it sits, RTR. Super stable at low and high speeds, Will lift a rear rear tire on high speed turns. Supposed to be 3:29 long. 1080p it Geared 62/8 at trans on 3s. some of the video was on a not fully charged lipo, some was. Last edited by Szczerba; 06-13-2015 at 09:39 PM. |
06-13-2015, 10:00 PM | #109 |
Somehow this part got left out of above video. Re-Uploaded this 0:17. 1080p it |
06-14-2015, 08:23 AM | #110 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
Looks awesome! She's a beast! |
06-14-2015, 09:23 AM | #111 |
| Re: Szczerba's Second CXT Build Thanks for commenting guys! Just a few more chassis details to finish up today, hopefully. Add plates up under the sliders for more slidy action. Add a kick up in front of the skid. Notch skid for rod end clearances. Strengthen up inside of body and make a tether to hold cab. |
06-14-2015, 12:17 PM | #112 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Looks good, once you get things dialed I bet it will be impressing many peoples.
06-14-2015, 12:55 PM | #113 |
Turned out great, and runs well! |
06-14-2015, 06:56 PM | #114 | |
| Re: Szczerba's Second CXT Build Quote:
Thanks guys. Still alot of little things to do. Ie, notch the skid for rod ends Front skid extension Bend a crossbar to clear the body mounts. Ran a bead around the notches for some wear protection. Diagonal Cross bar behind cab. | |
06-17-2015, 02:35 PM | #115 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Time for the drive train and electronics to be shipped off to the #szczerbabuilt garage for this Dakar rig. Vanquish Products, the benchmark company for quality machined parts; Axle housings Diff covers Link mounts Truss VVD's Stage 1 kit Titanium links Axles also include: Axial HD UD gears front and rear Grip Fab lockers Creeper Bob Titanium Shafts Dinky RC front truss DMG axle skids We are going to experiment and try the Rc4wd two speed transmission in this Dakar rig. Electronics include: Hitec 7954 - programmed front servo Hitec 645 - shift servo Tekin 2300KV roc412 motor Castle Creation 1 Cell MMP ESC and BEC 4S Lipo Geared 60/12 ..Uploaded from the lab @ the C.I. Compound... |
06-17-2015, 02:56 PM | #116 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
The rc4wd is pretty bullet proof even on brushless as long as the output shaft is the HD version. Not sure if they made it standard or not yet. I ran the stock one for a while and when I put the HD one in I noticed the stock was bent. Luckily I made the change before it broke. Buddy of mine has run his brushless for a long time on a 11lb rig.
06-17-2015, 03:27 PM | #117 |
well we know where this rig is headed now after completion..... @ci what bearing is that in the wraith axle pinion? or is it just dirty? |
06-17-2015, 06:17 PM | #118 |
| Re: Szczerba's Second CXT Build |
06-17-2015, 07:10 PM | #119 | |||
Thanks for the knowledge! Quote:
See below. Quote:
I'm a forester. I got this. Working on something with FreqEskinZ. | |||
06-23-2015, 07:40 PM | #120 |
So CI buys it and all work comes to a halt?!? Wes |
Szczerba's Second CXT Build - Similar Threads | ||||
Szczerba's IFS SCX Build | Szczerba | Axial SCX-10 | 236 | 08-27-2016 07:24 AM |
Szczerba's 1.9 Beckworks Rebuild Build | Szczerba | 1.9 Scale Rigs | 42 | 07-04-2015 08:53 PM |
Szczerba's 2.2 CXT | Szczerba | Axial Wraith | 109 | 12-04-2013 06:08 PM |
Szczerba's Terra-X Build | Szczerba | Axial Wraith | 21 | 02-25-2013 09:10 AM |
Was Szczerba's Defender 90 Build. On to the Next. | Szczerba | 1.9 Scale Rigs | 22 | 07-07-2012 05:18 PM |
