rock bouncing tube chassis Hey So are there any guys or company that make custom tube chassis? Or if i build my own i was thinking id just build it round the stock link and axle dimesions. Would there be anything id change in the shock angles, softness, etc. Thanks snyds |
Re: rock bouncing tube chassis [IMG]http://i15.photobucket.com/albums/a3...916_214625.jpg[/IMG] This is the one I built for my son. I used all of the stock components from a Redcat Everest. Most of them broke and have now been upgraded to SCX10 stuff. |
Re: rock bouncing tube chassis Quote:
RC Rock Bouncer | Harley Designs |
Re: rock bouncing tube chassis does anyone have the length and width of this tube chassis built from that template? also whats your advice for the best material for the tubes? brakeline? solid round bar? etc. cheers |
Re: rock bouncing tube chassis The info on Harley's site says it is designed around the Axial Wraith drivetrain. I don't have a Wraith, but I'd say wheel base around 13-13.5" and width at outside of tires 11.5-12'. "thumbsup" Hope that helps! I use 3/16 and1/4"od stainless steel tube and rod for my builds. |
Re: rock bouncing tube chassis go to the chassis section and find a builder you like emeryworx does alot of bouncers. or build your own. all stock wraith details Wheelbase:353mm (13.9")Ground Clearance:80mm (3.15")Height:237mm (9.3")Width:280mm (11.02")Weight:2.48kg (5.44 lbs")Length482.6mm (19") |
Re: rock bouncing tube chassis thanks guys |
