Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: The Interceptor: A U4 super car
Old 03-07-2018, 07:48 AM   #101
Default Re: The Interceptor: A U4 super car
Thankfully I could hit your Flickr image then hit photostream to see what you've done. Cool. Photobucket...... sucks. Loving the design on the axles with integral skids. Shocks on the upper links, SXS style? Kinda Razor/Rhino looking. How do you plan to get the front mounts under the hood and not sacrifice wheel travel? Or are you going to leverage the shock ratio at like 4:1 or greater? Or go outside the box and use prop rods and mount the shocks indoard, Revo style, letting you keep a reasonable ratio?
MAC FAB is online now   Reply With Quote
Old 03-07-2018, 09:37 PM   #102
I am leaning towards cantilevers. This does a couple things: Allows me to make antisquat and roll center changes with the uppers links and not affect ride height; separate ride height and motion ratio options without affecting antisquat or roll center and lastly to keep the shocks down low and out of harm's way while not being affected by the lines and tubes of the chassis.
I just need about 100 hours on the computer to draw everything up now haha.
Almighty Malach is offline   Reply With Quote
Old 11-14-2018, 10:36 PM   #103
Yearly update to this project. I redesigned the center sections to keep the axles from self destructing on big rock hits which led to a quick mock up of a carbon fiber TVP test rig. Based on a High Altitude LCG wraith skid, this design will let me verify the link and shock geo before I spend countless hours designing and building a full tube cage.
Screenshot 2018-11-14 12.14.11 by Casey Childs, on Flickr
Screenshot 2018-11-14 12.14.31 by Casey Childs, on Flickr
Screenshot 2018-11-14 12.13.58 by Casey Childs, on Flickr
Its hard sometimes to tell how big a design is going to be on screen so here it is mocked up against my 2.2 FJ ttc model. Both have a wheel base of 14.5" and it ended up looking spot on size wise and proportionally.
Screenshot 2018-11-14 12.17.50 by Casey Childs, on Flickr
Screenshot 2018-11-14 12.17.43 by Casey Childs, on Flickr
Axle files and chassis files have been sent to Shapeways and the carbon guy respectively; now we wait for everything to show up.
Old 11-15-2018, 06:46 AM   #104
*slow clap*
XSRCdesign is offline   Reply With Quote
Old 12-05-2018, 11:04 PM   #105
Parts are starting to roll in.
2018-12-01 04.41.06 by Casey Childs, on Flickr
2018-12-01 04.41.06-1 by Casey Childs, on Flickr
2018-12-03 22.19.36 by Casey Childs, on Flickr
2018-12-03 22.19.28 by Casey Childs, on Flickr
2018-12-03 22.19.22 by Casey Childs, on Flickr
2018-12-03 23.51.27 by Casey Childs, on Flickr
2018-12-03 23.51.30 by Casey Childs, on Flickr
Waiting on more 13mm bearings for the rear axle and the carbon chassis parts right now. I have everything else I need to build this car sitting on the bench waiting.
Old 12-06-2018, 07:11 AM   #106
Tire&Foam Extraordinaire
Nova's Ark's Avatar
This is so over the top Casey. People are really sleeping on the design and ingenuity you are putting into this. I'm very excited to see this completed. Nice work
Nova's Ark is offline   Reply With Quote
Old 12-11-2018, 02:32 PM   #107
ROCK STOP HOBBIES
CM9000's Avatar
nice work for sure. never doubt shapeways lol. the plastic is oddly strong when designed right. I designed a chassis for my pro rig, I was able to stand on it without it breaking.. (never finished it but getting back to it this upcoming spring)
I do have on question though, why the shocks on the upper links?
CM9000 is offline   Reply With Quote
Old 12-12-2018, 09:14 AM   #108
Wider shocks, more room in the chassis, better protected shocks and overall better shock and link geometry. Wider shocks means the car needs less sway bar to keep the chassis flat; more room in the chassis means for a lower CG and a balanced rig; and better geometry is the roll center is lower so the car tracks straight through rough terrain with no axle steer.
Old 12-12-2018, 09:39 AM   #109
Science!
Old 12-12-2018, 10:08 AM   #110
ROCK STOP HOBBIES
CM9000's Avatar
I never thought all that positive would come out of that design. Thanks for the explanation!
Sent from my LGMP260 using Tapatalk
Old 12-13-2018, 01:09 PM   #111
Cat is out of the bag I guess.
2018-12-12 11.20.57 by Casey Childs, on Flickr
2018-12-12 10.57.58 by Casey Childs, on Flickr
2018-12-12 10.58.05 by Casey Childs, on Flickr
2018-12-13 05.39.02 by Casey Childs, on Flickr
2018-12-13 05.39.40 by Casey Childs, on Flickr
2018-12-13 05.40.48 by Casey Childs, on Flickr
2018-12-13 05.44.00 by Casey Childs, on Flickr
2018-12-13 05.44.25 by Casey Childs, on Flickr
2018-12-13 05.45.14 by Casey Childs, on Flickr
2018-12-13 05.45.39 by Casey Childs, on Flickr
Put a battery through this thing today and holy shit does it exceed expectations. Launches flat, corners and steers extremely well and still crawls like that's all it was built for.
Old 12-13-2018, 01:22 PM   #112
Meow
Old 12-13-2018, 02:08 PM   #113
4RunnerKid's Avatar
love this.
4RunnerKid is offline   Reply With Quote
Old 12-14-2018, 09:00 AM   #114
XXXXXXXXXXXXXXXXXXXXXXXXX
durok's Avatar
Man, I'd like to see the finalized design put into production!
Love those axle housings, I have a set of Losi Maxxis Creepy Crawlers on Gearhead CAC wheels that are nearly 6" tall that would be perfect on this thing...
(in case you can't tell, I want one)
durok is offline   Reply With Quote
Old 12-14-2018, 09:36 AM   #115
ROCK STOP HOBBIES
CM9000's Avatar
We need some video bud. If this thing cawls as well as it launches we gotta have some video.
Old 12-15-2018, 06:49 AM   #116
They will be on Shapeways soon.
Working on video. Working nights right now so it's hard to get out and drive when there's light and the weather is good.
Old 12-15-2018, 09:00 AM   #117
ROCK STOP HOBBIES
CM9000's Avatar
I know what you mean. Im on afternoon shift. Got no time but the weekends, but even then.. Still have no time. Kids
Old 12-15-2018, 09:08 AM   #118
If it makes you feel any better, this time of the year working days doesn’t help either
Old 12-18-2018, 02:14 PM   #119
IMG_20181216_064627 by Casey Childs, on Flickr
Got the body mounted and painted saturday night so I could go test drive sunday morning.
Before testing:
IMG_20181216_085001 by Casey Childs, on Flickr
After 3 batteries:
IMG_20181216_093340 by Casey Childs, on Flickr
IMG_20181216_093353 by Casey Childs, on Flickr
IMG_20181216_093409 by Casey Childs, on Flickr
IMG_20181216_093414 by Casey Childs, on Flickr
IMG_20181216_093427 by Casey Childs, on Flickr
Aaaaaaaaaand some videos. I suck at driving fast with one hand; already asked for a gopro for christmas so I can get decent video.
2018-12-16 15.51.24 by Casey Childs, on Flickr
2018-12-16 15.51.39 by Casey Childs, on Flickr
2018-12-16 16.11.29 by Casey Childs, on Flickr
Old 12-19-2018, 09:58 AM   #120
Before testing:
After 3 batteries:
says videos are private and therefore cannot be viewed?!?
WesTX is offline   Reply With Quote
Tags
because race car, better than steel, highaltitudeperformancerc, superstitionmachineworks, y town crawlers
The Interceptor: A U4 super car - Similar Threads
Mattzilla Max Interceptor U4 HillbillyCrawler 2.2 Scale Rigs 13 11-18-2015 08:19 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
