04-13-2016, 07:07 PM | #81 |
| Re: Szczerba's F350 Welder Rig |
04-13-2016, 09:39 PM | #82 |
Starting a completely generic and no 1:1 vehicle relation front shock, coil and panhard setup. Shortened up the front lowers a tad as well. Last edited by Szczerba; 04-13-2016 at 09:51 PM. |
04-13-2016, 09:55 PM | #83 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
Shock and coil bucket looks like you took it from my truck - 2014 F250 with Carli suspension using 3" king shocks. J/k (sorta), nice work as always. |
04-13-2016, 10:10 PM | #84 | |
| Szczerba's F350 Welder Rig Quote:
I plan on tying the coil tower to the shock tower with some flat steel. Also, I didnt want to buy new shorter shocks but may have to if I want to drop the shock hoop lower to the coil tower. Cheaper to just tie them together and keep it movin. I found this on the internets and kinda copied it. Running dual shocks now after setting the coil towers will require some cutting and rewelding of the shock mounts. May or may not do it. Last edited by Szczerba; 04-13-2016 at 10:13 PM. | |
04-28-2016, 04:48 PM | #85 |
Updates?
04-28-2016, 06:55 PM | #86 |
| Szczerba's F350 Welder Rig Not much. Truck will be on the back burner over the next month to make way for other builds. I have gotten an Exo trans with a Blue Monkey spool tacked in place. Angled due to interior. Shock hoops redone Also, got the CMS roughed in. Up next will be losing the scx skid and mounting up a transfer case. |
06-28-2016, 09:22 AM | #87 |
Newbie Join Date: Jan 2012 Location: NE Texas
Where u from in south west arkansas. I'm a pipeline welder. Wish I could post a pic of my truck. I'm from just across the line in north east Texas.
06-28-2016, 11:17 AM | #88 |
Quarry Creeper Join Date: Mar 2014 Location: Rogers, MN
I may have to borrow the idea of using the exo "trans" with a spool in my tow rig. I'm going to run a 2:1 ratio, centered drop transfer case for a 1/14th semi anyway.
06-28-2016, 11:29 AM | #89 |
Rock Crawler Join Date: May 2007 Location: floriduh
Seems like having the panhard bar mounting being on the opposite side of the servo will cause binding, wont it? I'm sure you've cycled the suspension and all, but just looks weird. :P
06-30-2016, 08:02 AM | #90 | ||
| Re: Szczerba's F350 Welder Rig Quote:
Total screw up on my part. Wasn't paying attention, lol. I will probably fix it before too long. | ||
07-04-2016, 07:12 PM | #91 |
Got the bed mount tacked in on the rails, bed and hitch ball mounted. Mock up pictures. Still alot of work left to do, ignore the crazy ride height. |
07-09-2016, 04:14 PM | #92 |
Finish welding things, swapped panhard mount, built t-case holder Last edited by Szczerba; 07-09-2016 at 08:00 PM. |
07-16-2016, 11:48 AM | #93 |
Welder and cutting torch installed |
07-16-2016, 02:18 PM | #94 |
Quarry Creeper Join Date: Mar 2016 Location: juneau
Amazing!!! Work..... Sent from my SAMSUNG-SM-G891A using Tapatalk |
07-17-2016, 07:39 AM | #95 |
Rock Crawler Join Date: Apr 2012 Location: Bella Vista
You do have a creative mind when it comes to this hobby.
07-17-2016, 03:36 PM | #96 | |
Thanks a lot guys. I litterally just make it up as I go with some google image searching inspiration from time to time. Cutting out light buckets out back now. Im only getting a few hours a week right now to work on trucks, so it's slow going right now. | |
07-18-2016, 08:27 AM | #97 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
Your detail work is legit!!
07-19-2016, 09:06 PM | #98 |
Thanks darkmanx Hooiserpole work |
07-25-2016, 08:26 PM | #99 |
Cable rolls. Axial hubs cut Styrene Joshtoyz4x4 printed hub wideners |
07-30-2016, 09:39 PM | #100 |
Cutting torch spool, mud board (need to make a mount). |
Szczerba's F350 Welder Rig - Similar Threads | ||||
Szczerba's Micro 8x8 Tow Rig | Szczerba | Micro Scale Rigs | 37 | 12-13-2015 11:57 PM |
1999 F350 Tow Rig | JonFoster | Micro Scale Rigs | 14 | 10-23-2015 10:57 PM |
Szczerba's Tow Rig | Szczerba | Multi Axle Rigs | 514 | 06-08-2015 05:15 PM |
F350 Scale rig | ttown180 | Axial SCX-10 | 43 | 01-28-2010 01:10 PM |
