05-11-2016, 04:44 PM | #1 |
Rock Stacker Join Date: Jun 2012 Location: Santa Monica/Venice
| Wraith Spawn Kit Build Front Diff Clicks when stopping hard
Hey everyone, I recently finished the main building of a brand new Axial Wraith Spawn kit. Everything went just fine during the build, but when I run the rig, on decelerations there is a clicking coming from the front diff. I thought it was originally the shorter screws that hold the bearing retainer in place, so I replaced them with longer screws, made sure there wasn't any unwanted slop and closed it back up. I still get the skipping when I let off the throttle. I need to get back in to the diff to examine the edges of the teeth on the gears. Also when I jump in to reverse it does this clicking more, then when I punch it in drive. So reverse, and when the "break/Drag Break" is applied is when the clicking happens. Has anyone else had this problem? In the meantime I have ordered an overdrive gear set for the front. Going from 38t/13t to 43t/13t setup. Anyone else running this setup? |
05-12-2016, 03:03 PM | #2 |
Pebble Pounder Join Date: Aug 2014 Location: Middle
| Re: Wraith Spawn Kit Build Front Diff Clicks when stopping hard
I had this problem with an old ring and pinion in my wraith. I ended up getting new gears and a new housing and making sure the pinion was shimmed up to the ring gear properly. Do you run the plastic diff housing with the axial locker? hope all you have to do is shim it, hope this helps
05-12-2016, 03:26 PM | #3 |
Yes, still running the Axial Locker, and plastic diff housing. I just ordered a set of shims. I bet that's the issue. I'm also going to overdrive the front here shortly. I hope the shimming helps, but if not, then I'll just order a new housing, and rebuild it with fresh parts.
05-13-2016, 07:43 AM | #4 |
RCC Addict Join Date: May 2009 Location: Weston
I would under drive the rear and leave the front stock. Better gear mesh on the under drive gears.
05-13-2016, 08:24 AM | #5 | |
Pebble Pounder Join Date: Dec 2008 Location: Ankeny
| Re: Wraith Spawn Kit Build Front Diff Clicks when stopping hard Quote:
Dlux Fab | |
05-13-2016, 10:10 AM | #6 | ||
05-13-2016, 03:37 PM | #7 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Hardened stock ratio in front, ud in rearl. To much drag brake and an abrupt throttle chop from speed will result in the gears skipping which is the clicking noise you are describing. A heavy throttle finger will also cause the same results. Modify both of those issues and use the above mentioned gear sets and you will be good to go if any of that sounds appropriate to your driveing style.... |
05-17-2016, 11:10 PM | #8 |
Moderator Join Date: Jan 2004 Location: chicago
i had real bad issues with metalhead axles and o.d. front gears that would skip and then eventually grenade. real REAL heavy truck... if i really got on it and wasnt careful i could pop the front gears on command. i went to hardened stock ratio in front and had the cases modded for 13mm pinion bearings and havent had a problem since. might want to get some aluminum locker bearing caps for your axles, and the dlux modded 13mm pinion cases are hella nice for the price. |
Wraith Spawn Kit Build Front Diff Clicks when stopping hard - Similar Threads | ||||
Wraith Spawn Kit Build Up | tc1 | Axial Wraith | 34 | 01-20-2018 01:47 AM |
yeti kit build issues - front diff | littlebuddha | Axial Yeti | 5 | 04-18-2017 03:17 AM |
Wraith Spawn Hot Racing diff lockers | The Dark Knight | Axial Wraith | 4 | 07-31-2015 09:15 PM |
RichMTB01's Wraith Spawn KIT Build | RichMTB01 | Axial Wraith | 0 | 05-13-2015 08:35 AM |
Just build my xr10 - First run, front axle "clicks"? | eddiepfund | Axial XR10 | 9 | 10-06-2010 06:25 AM |
