08-06-2016, 06:16 PM | #41 |
Rock Stacker Join Date: Apr 2014 Location: Daytona Beach
| Re: 1992 Ford F-350 6-door long bed build
wow this is amazing! much better and nicer than my 6-door haha
08-07-2016, 07:44 AM | #42 |
Quarry Creeper Join Date: Feb 2014 Location: Russia Ekaterinburg
| Re: 1992 Ford F-350 6-door long bed build DieselRC Thanks! Both your F-350 and trailer are great, I thought about using Tamiya body, but decided to build from scratch. Short demonstration of the chassis. None of my other rigs could not afford to go down from that height. |
08-13-2016, 08:35 AM | #43 |
Thanks! I upgraded it to 4 motor by sacrificing part of the interior. It worked fine when tested, but I had a feeling like the motors are working close to power limit when climbing. I also have a Mad Torque dual ESC - dual motor each, which I got for the snowcat. Last edited by b-kons; 08-13-2016 at 08:38 AM. |
08-13-2016, 11:42 AM | #44 |
Oh my, 4 motors is going to be insane lol
08-15-2016, 10:27 AM | #45 |
Rock Stacker Join Date: Aug 2016 Location: In the doghouse
This is nuts. Where do you learn to do stuff like this? I would be missing more than half of my fingers by now.
08-15-2016, 10:42 AM | #46 |
I tested it on the floor, without a body, when the chassis is up against the wall, the wheels continue to spin at about half or one-third speed, despite the fact that the wheels are big and whole chassis is quite heavy. Continue to work with the bed. |
08-17-2016, 11:00 AM | #47 |
Making... these things, arches. |
08-18-2016, 08:11 AM | #48 |
Pebble Pounder Join Date: Jun 2016 Location: Keizer
Sweet Build. What esc's are you running for the dual motor set ups?
08-22-2016, 07:51 AM | #49 |
Thanks, this is Exceed dual waterproof ESC from Mad Torque, I just got it and have not yet tested on the ground. Start making the sides. |
08-29-2016, 08:59 AM | #50 |
Thank you, I would like to see it too! Put some styrene inside. Make holes for the LEDs. |
08-29-2016, 09:04 AM | #51 |
The bed is done! Interesting, I used the same primer, but this one has a slightly lighter tint. |
08-29-2016, 01:42 PM | #52 |
Quarry Creeper Join Date: Jun 2015 Location: Petaluma, Ca
Body is coming along great. The detail work the bed is outstanding.
09-02-2016, 10:46 AM | #53 |
Thanks, it is actually really long(: Rear bumper |
09-05-2016, 08:36 AM | #54 |
Thanks! Moving to the next step - painting. Classic blue colour with a white line. This is the same technique that was used to paint the GTO: candle, acrylic paint and water. I try to use it less at this time, but I just can not stop. Mask with a tape, paint white, then mask again and paint blue. Stick the tape on the floor or somewhere first to make it not so sticky, otherwise it will peel the paint. Using Modern Masters Metal Effects Kit to make rust. Apply 2-3 layers of Iron Paint, wait until it dries, then apply the Rust Activator, wait a couple of minutes and repeat a few times. Make sure that the surface is horizontal, to protect the Rust Activator from dripping. Drying by a fan makes it flat and bright, cover the surface to make it deeper and more red. The left wheel was lying on top when drying, right one - underneath. And that's all I have painted to date. |
09-10-2016, 08:40 AM | #55 |
Bike flashlight to make the rear lights. The rust has a bright yellow tint this time, although I painted the same way. It's kind of unpredictable, kind of mysterious. |
09-10-2016, 01:14 PM | #56 |
Oh my god... This thing is epic!
09-10-2016, 02:10 PM | #57 |
Quarry Creeper Join Date: Mar 2014 Location: Rogers, MN
Absolutely amazing job! I think a set of RC4WD Mud Basher tires would look right at home on such a large beast of a truck! -Derek |
09-20-2016, 08:46 AM | #58 |
Thanks guys! Body mounting. Windows and some details. |
09-20-2016, 09:33 AM | #59 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
wow... the amount of detail! I think I need to get back to my pile of styrene..
09-21-2016, 12:15 PM | #60 |
Pebble Pounder Join Date: Apr 2013 Location: SoCal
what do you use as a backdrop for your pictures? they look clean, and the lighting is great. I have been playing with ideas, but nothing is working. Also this is an amazing truck the styrene work is incredible!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!! |
Tags |
6 door long bed, ford f-series f-350, rc scale crawler truck |
1992 Ford F-350 6-door long bed build - Similar Threads | ||||
Tamiya Tundra/Hilux Long Bed Build | punchit92 | 1.9 Scale Rigs | 20 | 09-25-2015 04:56 PM |
Losi based 72 Chevy Long Bed C3 build | Rooster87 | 2.2 Scale Rigs | 2 | 08-06-2015 08:56 PM |
tazman's Ford F-350 Truggy build | tazman | Axial SCX-10 | 35 | 07-27-2011 11:21 PM |
