10-24-2016, 07:59 AM | #1 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
| Hairba11's 1:8 version of Hogan's Hot Rod (with Mad Moose Portals)
Back in the day doing crawlapalooza at disney OK at Hogan's Offroad Park, i got to go for a ride with Hogan in is Hot Rod. this was one of the coolest rigs i've ridden in. i loved the look of it. I'm rooting through photobucket and posting images again as i can't find my piece of graph paper i drew the 1:8 scale chassis on. i have 2.2 stompers, and solid black delrin beadlocks with red rings, 7ish years ago i was playing with highlift axles and integy axial portals and trying to make that work, now i have stumbled into a set of the Moose Portal Axles, (thanks Grunt95) so this build will have to happen now. |
10-25-2016, 07:25 AM | #2 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
That rig is seriously cool. This will be badass. Last edited by BadWagon; 10-26-2016 at 01:44 PM. |
10-25-2016, 01:56 PM | #3 |
| Re: Hairba11's 1:8 version of Hogan's Hot Rod (with Mad Moose Portals)
Love the stance on that thing!
10-26-2016, 10:44 AM | #4 |
Quarry Creeper Join Date: Jul 2011 Location: ireland
great idea, i thing hogans bronco was the same set up for the suspension. i had thought of doing one lower link but with a panard on a build im doing at the moment cant wait to see your interpretation off it |
10-27-2016, 07:29 PM | #5 |
Today I made huge progress on the build Bench went from To this And that's it. Ok, not quite. I rooted around and found my box of parts. I have the eritex? Comp solid bead lock wheels, missing rings. A set of 2.2 stompers, and a set of 2,2 swampers. Also had my original set of axles I was planning on using for the build. And ran into my first complications. The link mounts bolt to the top of the axle and due to asymmetry can't be mounted on the bottom. Guess custom fab will be starting early. Sent from my iPhone using Tapatalk |
10-27-2016, 08:33 PM | #6 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
Can't wait to see what the end result will be! That's quite an interesting rig he's got! Sent from my BLU LIFE ONE X using Tapatalk |
10-31-2016, 12:22 PM | #7 |
I've been cleaning the garage and going through boxes trying to find my drawing I made off of measurements I took 6 or 7 years ago. No luck on the drawing. But I've found a lot of missing treasure. I even found the beadlock rings for the eritex wheels! I also have filled the 2 yard dumpster at work with old crap. Sent from my iPhone using Tapatalk |
11-25-2016, 02:58 PM | #8 |
any updates on this build |
11-27-2016, 01:06 PM | #9 |
Newbie Join Date: Jun 2015 Location: SoCal
Awesome rig! Do you have any more info on the 1:1 counterpart? It has a very Mad Max feel to it. Also, where did you find the Unimog axles? Are they just Tamiya units? |
11-27-2016, 05:08 PM | #10 |
Not yet. Sourcing materials still. And took a week off out of state. Sent from my iPhone using Tapatalk |
02-01-2017, 08:10 AM | #11 |
I finally found my drawings! And even started work! Sent from my iPhone using Tapatalk |
02-02-2017, 08:02 AM | #12 |
Progress! Sent from my iPhone using Tapatalk |
02-03-2017, 07:57 AM | #13 |
More progress Sent from my iPhone using Tapatalk |
02-04-2017, 08:35 AM | #14 |
Another morning and some more progress 2.2 swampers, eritex comp solid wheels, fracture v8/trans/transfer, mad moose portal axles. Ran it through the shot blast at work and got it primed. Sent from my iPhone using Tapatalk |
02-05-2017, 03:33 PM | #15 |
Newbie Join Date: Jan 2016 Location: Stockholm, Sweden
This is gonna be awesome!!!!!!
02-06-2017, 08:08 PM | #16 |
I hope so mad moose So a little weekend progress Cage is black I got the tires on the wheels. And figured out the bead ring hits the portals Got my engine mount/subframe cut out of 1" X 1/8" And got it mounted into the chassis with three 8-32 screws, and one broken off 8-32 tap :eek: Sent from my iPhone using Tapatalk |
02-06-2017, 09:22 PM | #17 |
Quarry Creeper Join Date: Jan 2009 Location: Cerritos
Coming along nicely, that thing is going to be sweet!
02-08-2017, 07:41 AM | #18 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
hey, that's pretty sick. a quick tip for scale plug wires, use a sensor wire! it will make it more scale. cant wait to see this finished.
02-08-2017, 08:41 AM | #19 |
This is going to be killer!
02-08-2017, 02:25 PM | #20 |
looking forward to the suspension build up keep up the good work
Hairba11's 1:8 version of Hogan's Hot Rod (with Mad Moose Portals) - Similar Threads | ||||
Hot Rod | Husy | Large Scale Rigs | 16 | 09-22-2014 07:32 PM |
Hogan's Bronco | ROCKEDUP RICKY | 2.2 Scale Rigs | 273 | 06-23-2013 10:04 AM |
Mad Force Nitro version of a Summit | msaloney | Kyosho Crawlers | 11 | 01-28-2013 06:54 PM |
Im going to be on Hot Rod TV! | willipmartinni | Chit Chat | 28 | 04-29-2012 12:21 AM |
