08-15-2017, 09:10 AM | #101 |
| Re: Szczerba's 4th CXT, Build #58 |
08-15-2017, 10:14 AM | #102 | |
| Re: Szczerba's 4th CXT, Build #58 Quote:
Running one Tekin Roc412, 1200kv 540 sized motor on 4s with a Holmes Hobbies BLE Pro ESC. Single SCX style transmission is geared 66 spur and 6t pinion. Holmes Hobbies SHV500 servo. Yup, it's all about motor selection, gearing and voltage. | |
08-15-2017, 12:03 PM | #103 |
Where did you find a 6t pinion?
08-15-2017, 12:07 PM | #104 |
| Re: Szczerba's 4th CXT, Build #58 RC4WD sold them for the clodbuster. 32p. They look sold out now but HR sells one. Hot Racing CB206L Chrome Steel Long Pinion Gear 32P (6T) | eBay RC4WD 2-speed transmission 64p Spur fits an SCX style trans with minimal effort of hole enlarging. 64t Delrin Spur Gear for R3 2 Speed Transmission .. |
08-15-2017, 12:50 PM | #105 |
RCC Addict Join Date: Aug 2008 Location: Paulina
You should be able to throw a Traxxas slipper onto the SCX transmission and get larger 32p spurs should that be needed.
08-15-2017, 03:15 PM | #106 |
Pebble Pounder Join Date: Apr 2013 Location: SoCal
Great work, truck and trailer are sick!!!
08-15-2017, 03:22 PM | #107 | |
Thank you sir! | |
08-15-2017, 03:24 PM | #108 |
08-29-2017, 08:48 PM | #109 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
Assume you're using 1.55s for the trailer? What foams are you using to handle the weight? My Pitbull Growler foams aren't up to it, wish CI made a DW foam in 1.55
08-30-2017, 12:04 AM | #110 | |
Yah. SSD 1.55's and RC4WD 1.55 desert kings. Cut down 1.9 single stage CI foams. The foams will hold about 100lbs but then squish too much. I welded a removable caster wheel to the underside of the axles for human transport. | |
08-30-2017, 04:07 AM | #111 |
RCC Addict Join Date: May 2009 Location: Weston
08-30-2017, 08:42 AM | #112 |
02-26-2018, 09:13 AM | #113 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
Can you post some info on the trailer axles and how you made them?
02-26-2018, 09:37 AM | #114 | |
Sure, looks like I didn’t post these here but did on IG. 1/2” square tube for the axle housings. Got the axle pivots from a friend, WhiskeyBent Trailers on FB, the RC company not 1:1 company. They slide into the 1/2 tube, use rubber pieces to dampen and a set screw keeps them from coming out. And hollowed out 12mm hexes with bearings on the back side. Last edited by Szczerba; 02-26-2018 at 09:40 AM. | |
02-26-2018, 08:59 PM | #115 |
Wholly Cow. Shame on me for missing this somehow. Thought your 1st one was good but had to read this a few times to catch all the insane work you do as usual. Your girls being towed was so awesome and funny. Like one of those little train things. The trailer was something i have never seen before size wise of course but the axles. Big on that for sure and the overall build. |
02-26-2018, 09:42 PM | #116 | |
I have one unfinished Pikes Peak CXT build sitting on my shelf. I have another full CXT stock truck that I may have the motivation to build one more. | |
02-26-2018, 09:47 PM | #117 |
My daughter didnt want her picture taken but did it, once. Haha. She loves to ride around on it. I need to make a handle extension for it her, as her feet hit the back of the bed now. A few recent builds on it. |
02-26-2018, 11:49 PM | #118 |
Very awesome. Thanks for the info!
03-11-2018, 10:37 PM | #119 |
Thanks! It was a fun build and is even more fun towing crawlers or humans around!
03-12-2018, 09:24 AM | #120 |
Quarry Creeper Join Date: Aug 2017 Location: Surface of the Sun
I could only imagine!! I've had a powerful Rig or two in my long life..... Even did Truck Pulls with my modded Clod, back in the early 90's! However, I don't think I ever had ANYTHING that MASSIVE, that could tow that much weight!!! So...... Trailer with 3 people, 275-300lbs?? BTW, THANK YOU!! My arthritic fingers thank you for the Rod End Tool you made!! I've literally about worn it out, but it still does it's job! I just have to hold the end a little tighter. So, I guess I'll be interested in another one soon! |
Szczerba's 4th CXT, Build #58 - Similar Threads | ||||
Szczerba's Second CXT Build | Szczerba | 2.2 Scale Rigs | 253 | 03-08-2019 07:49 AM |
Szczerba's 3rd CXT, Build #57 | Szczerba | Multi Axle Rigs | 172 | 03-26-2018 08:56 AM |
Szczerba's 2.2 CXT | Szczerba | Axial Wraith | 109 | 12-04-2013 06:08 PM |
Szczerba's Terra-X Build | Szczerba | Axial Wraith | 21 | 02-25-2013 09:10 AM |
