Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Fallout themed Twin Hammers 2.2 trail truck.
Old 08-02-2017, 06:18 PM   #1
Default Fallout themed Twin Hammers 2.2 trail truck.
Started my Twin Hammers 2.2 trail build. Stock electronics for now, but plan on plenty of upgrades there. Intent is to turn it into a moderately fast trail truck. Also posted over on the twin hammers forum. Still a WIP, but the bulk of the cosmetic work is done.
So far it has:
Locked front
Heavy rear sway bar
Redcat RS10 2.2 wheels with proline flatirons, non xl.
Desert truck body swap custom painted with fallout 1 theme.
Just ordered scorched parts bellcrank and upright shock mount, and king off-road 80mm shocks for front.
Going to stick with 2.2 on this rig though going to stay on the smaller side, I hear big tires break things on these trucks. The flatirons are a small 2.2 at 4.8 high but works well with this truck. Unfortunately the flatirons are also very soft and not well suited for fast stuff :(
Sent from my Pixel using Tapatalk
Damatheus is offline   Reply With Quote
Old 08-04-2017, 08:43 AM   #2
Default Re: Fallout themed Twin Hammers 2.2 trail truck.
looks good mate
rs10man is offline   Reply With Quote
Old 08-04-2017, 08:52 AM   #3
Originally Posted by rs10man View Post
looks good mate
Thanks.
Have some work to do still on the cosmetic. Scale accessories, some window coverings, armor panels, and going to 3d print some nuclear waste barrels.
Just ordered a hobbywing wp1080 esc. Trying to decide on best motor for it.
Old 08-05-2017, 11:24 PM   #4
https://youtu.be/6eNzoLJRSQk
Old 08-20-2017, 09:34 AM   #5
You have to get the rear truss to stop the torque twist and I recommend a medium rear swaybar. It made a world of difference on mine.
MeanTT is offline   Reply With Quote
Old 08-20-2017, 09:41 AM   #6
I don't have the rear truss yet, but it's on my list of parts to get. I do have the sway bar set installed. I've ran the truck with the light and the heavy bars. Don't remember which was installed during this video, but there was a sway set installed. I will probably settle on the medium though.
Old 09-12-2017, 10:21 PM   #7
Got my roof rack, driver, window bits, and some accessories installed. Still waiting on screws to arrive for the scorched parts steering upgrade.
Old 11-06-2017, 09:44 PM   #8
Got my scorched parts upright shocks with bell crank installed. Awesome kit, steering is much improved. Shocks look good with the truck body. Need to paint them to match the post apocalyptic theme still.
Got the power armor mounted on the roof as well.
Old 12-19-2017, 08:22 AM   #9
Some shots from a recent outing with over 40 trucks. Recently swapped the factory 15t for an RC4wd 35t, and relocated the battery to inside the tub. Huge difference in capabilities.
Old 12-19-2017, 01:37 PM   #10
You had mentioned how soft the tires were. Have you upgraded the foams yet? I really enjoy the flat irons as they are a good all around tire for a semi go fast rig with the right foam setup
Phins Fan is offline   Reply With Quote
Old 12-19-2017, 01:52 PM   #11
@phins fan. I am still using the factory proline memory foam. Because I've dedicated this truck to trail and crawl duty, I decided it won't need high speed stability. With the new 35t motor, even in second gear it isn't fast anymore.
However, I may still put some dual stage CI foams in to help with side hill stability. The TH is already blow and great at side hill, but reducing the tire rolling over would help. The stock proline foams allow the tires to roll almost all the way to the wheels in extreme cases.
Fallout themed Twin Hammers 2.2 trail truck. - Similar Threads
My fallout themed twin hammers trail truck. Damatheus Vaterra Twin Hammers 24 06-25-2019 11:21 PM
heinie_21 's twin hammers - to - trophy truck heinie_21 Vaterra Twin Hammers 71 08-23-2017 03:10 PM
New Twin Hammers DT, Desert Truck! Toby Lewis Vaterra Twin Hammers 18 10-28-2015 09:55 PM
Vaterra twin hammers 1.9 truck? axial 4x4 crawler Vaterra Twin Hammers 7 05-25-2013 08:41 PM
