12-30-2017, 11:23 AM | #41 |
RCC Addict Join Date: Dec 2014 Location: So Cal
| Re: A different kind of Bomber...
When I saw the lacing in there and you said you haven't welded the major structure, yikes! You will never get to all of it ( been there, done that). In reality, you could tack it like you have and run it without problems. Look at the mig welded cages out there with all their cold welds running without issues. As for panel mounting, I personally weld sheet metal that I can bolt through, using the aluminum panels like shear paneling on construction projects. You can also get 4-40 nutserts to put in the sheet metal tabs, which is probably the easiest route. 20 or 18 ga tabs. Hold the panel in its location and drill the 1/8 hole thru both parts, drill the tab with a 3/16" and install the nutsert, just allow for the 3/16" hole in the tab and not in the tubing! Whats the eta for a maiden voyage? This build is bad azz.
12-31-2017, 09:54 AM | #42 | |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
| Re: A different kind of Bomber... Quote:
12-31-2017, 09:57 AM | #43 |
| Re: A different kind of Bomber... Most of the time with the TIG, I have to sit in one spot until both metals heat up enough to melt, then dip rod in so I am almost certain the nylon wouldn't hold up. Its different than MIG welding where you can do a quick tack and not get the metal too hot. For precision work like this, I prefer TIG hands down. Thanks! I'd build some more chassis but its such a pain to notch all the tubes that the time invested wouldn't make it inexpensive by any means |
12-31-2017, 02:59 PM | #44 | |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
12-31-2017, 06:02 PM | #45 |
| Re: A different kind of Bomber... |
01-02-2018, 09:11 PM | #46 |
Everyone likes pics right? Full bump and proposed ride height |
01-03-2018, 07:18 AM | #47 |
Does the shock's stroke align with your desired ride height/bump/droop "elevations"? Also, my vote for coating after see these pics is leave it raw and clear coat it. That thing is screaming "Let's go run KOH!" What are the eye to eye lengths on the shocks? Bypasses at all 4 corners would be sick looking on that thing, run them empty. Asia Tees perhaps???
01-03-2018, 07:31 AM | #48 |
That chassis is bad ass, man! Awesome work! |
01-03-2018, 04:47 PM | #49 | |
01-03-2018, 04:50 PM | #50 |
01-03-2018, 06:31 PM | #51 |
| Re: A different kind of Bomber... Somebody 3d prints a 3 tuber if I remember correctly that fits rc4wd kings. Not sure of the shock lengths, but shapeways prints them, maybe someone will remember where, on the Bomber forum. Very cool looking pieces. I hear you on the shock mounts, but you're stuck with locations on the links, shock 90 degrees to the arm at full bump. |
01-03-2018, 09:11 PM | #52 | |
01-04-2018, 12:20 AM | #53 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
01-04-2018, 11:02 AM | #54 | |
| Re: A different kind of Bomber... Quote: | |
01-04-2018, 08:18 PM | #55 | |
01-04-2018, 10:55 PM | #56 | |
I'm going for this look so I ordered a set of SSD rock racers from RC mart to go with my Axial KR2s | |
01-04-2018, 11:10 PM | #57 |
So good Really I think 1.9's would be a lot more scale than 2.2s though |
01-07-2018, 10:33 PM | #58 |
Well they will be less scale than the Kings but I decided to get 103R/93F Gmade Piggybacks for tunability. With how much weight I've added (still not sure yet how much exactly) I think I will enjoy the tuning option on them. Thinking of ways to make them look more scale, maybe some blue paint/anodizing with King stickers Added the last bit of tube to the chassis yesterday. After looking at the 1:1 Bombers, they have a vertical tube in the top section of the B pillar behind the drivers heads so I'll add that real quick. Also ordered 100 M3 stainless square nuts for mounting body panels and a bunch of short M3 button head stainless bolts. Should only need 4 per side and 4 on top. Going to mount the battery in the factory location and use the factory hinge as well. So next is shock mounts or body tabs, whichever comes first |
01-13-2018, 10:22 AM | #59 |
Few new additions... SSD rock racer wheels, got the interior fitted as well as the hood. For the interior, I only had to trim the back of the seats a little bit and the front cowl area to make it fit nicely. I was really wondering how it would go re-installing it after all the tubes were welded in and it wasn't too bad twisting it in from the under side. Happy I got the hood to hinge like stock Also started welding on M3 square nuts for panel tabs but the threads deform quick since they are tiny. Had to order more Gear Head Fab tabs instead. They are bigger and will weld to the chassis easier. Built the G-made Piggyback shocks too, they are huge! Zero room for another shock but I like how smooth they are and the adjustability is key for mobbing. 93mm up front and 103mm out back will work out perfectly. Hows the sanded tubing look? I'm on the fence about it. Still leaning towards Steel It coating after a good sand blast. |
01-13-2018, 12:05 PM | #60 |
I like how it's coming along, the hood looks great, cage looks great. Those two items in particular make it resemble a home-built racer, up to you if you want it to go all fancy and "Pro" looking by painting it... even with Steel It.
A different kind of Bomber... - Similar Threads | ||||
Making Crawling bomber into trail rig bomber. | theTman | Axial RR10 Bomber | 2 | 06-10-2016 01:46 PM |
