11-18-2017, 05:09 PM | #1 |
Quarry Creeper Join Date: Jun 2007 Location: Los Angeles
| C3 rig project
I built a few 2.2 rigs before but was never really happy with their handling. My last one was a Yeti with a UCFab cage, a bit too heavy and fragile for the kind of speed I was looking for. I gathered some parts, bought a few more in classifieds and had a chassis built by Bent Metal around a Proline 66 C-10 body. Axles: - AR60 - VP Stage 1 kit - VP steering link - Incision spools - VDI axles - DLux U4 truss Transmission: - MIP driveshafts - VP case and plate (need to order this) - Incision gears - LURC slipper emiminator - Holmes half drives Wheels Bought the set for quite cheap from Facebook - Silver Voodoo KLRs - CI foams - VP KMC XDs I still need to figure out links and shocks (maybe some Associated big bores) |
11-24-2017, 04:27 PM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
| Re: C3 rig project
Nice little list of parts you have there. Good start
11-24-2017, 06:50 PM | #3 |
| Re: C3 rig project
Some update on the frame, will be powdercoated dark grey. Will cut out the front bumper from the body, maybe switch to a plastic bumper. Last edited by utieh; 11-24-2017 at 07:03 PM. |
12-16-2017, 08:39 AM | #4 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: C3 rig project
Any updates?
12-16-2017, 12:38 PM | #5 |
| Re: C3 rig project
Built the shocks, steering links and few other things will take pics tomorrow. Chassis is coming next week, were waiting for the custom links |
12-16-2017, 03:49 PM | #6 |
| Re: C3 rig project
Photo of the powdercoated chassis Last edited by utieh; 12-16-2017 at 03:51 PM. |
12-30-2017, 05:31 PM | #7 |
| Re: C3 rig project
Small update. I finally received the chassis last week and I was able to start putting everything together/figuring this thing out. I still need to order a tons of little parts - needs a motor mount (any cheap recommandation?) - upper links are too shorts, need the Jato rod ends for this DLux truss - the previous axle owner chopped the upper part of the rear axle mounts, need new ones (how do the plastic ones hold up? What alternative?) - add a battery/ESC tray like this one, it's a bit overpriced though The whole rig is much heavier than expeceted, I'm going to replace the front bumper for a plastic one, remove the one on the body, maybe the sliders too. I'd like to keep this truck low and "light" |
12-31-2017, 05:49 AM | #8 |
Rock Crawler Join Date: May 2013 Location: Dallas
| Re: C3 rig project
Looks good! What does it weigh currently if you don't mind me asking? I assume the cage is solid, or is it tube?
12-31-2017, 10:57 AM | #9 |
| Re: C3 rig project Kind of a rude question I will weigh ut when I have a chance at work. Also it's a hard guess since nothing is mounted. Chassis alone might be around 2 lb.
02-04-2018, 05:54 PM | #10 |
| Re: C3 rig project
Finally finished the truck and took it for a quick test outside, mostly dirt and slick rocks. It's quick despite the "small block" HH motor, not really good on battery, a little bit hard to control at speed. I'm already thinking about replacing the G-speed frame by its carbon fibre counterpart and using plastic bumper and sliders. The truck could be a bit wider too (only missing a pair of wider SLW hub). |
03-15-2018, 10:03 PM | #11 |
Newbie Join Date: Nov 2011 Location: Western
| Re: C3 rig project
Sweet setup. How do you like the DLUX truss? always looking for peoples thoughts and methods so what was major concern so as to swap it over to a DLUX? Great Rig big guy keep er goin
03-15-2018, 11:17 PM | #12 |
| Re: C3 rig project
I love them, really well designed, looks good too. I bought them second hand though so they were already installed on the axles.
03-15-2018, 11:19 PM | #13 |
| Re: C3 rig project
Gotcha. I was like you, i love the way they looked but was curious to see how were holding up to someone who was really using them.
03-15-2018, 11:26 PM | #14 |
| Re: C3 rig project
Axles are solid, I don't run beef tubes, I wanted to keep the rig "light"
03-31-2018, 09:50 PM | #15 |
| Re: C3 rig project
Had a little drive today at Corona del Mar crawling spot. Not so sure about those Voodoo tires anymore... |
04-09-2018, 03:54 PM | #16 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
| Re: C3 rig project
The tyres didn't suit that terrain or something else?
C3 rig project - Similar Threads | ||||
new project for trail rig | lizard017 | Newbie General | 1 | 02-13-2008 04:27 PM |
New Big Rig Project | run2jeepn | Chit Chat | 5 | 10-01-2006 08:03 AM |
