01-23-2018, 02:55 PM | #21 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
| Re: New C3 build. "The Outlaw"
Got to love these rc4wd short shafts. You can easily make them shorter and one side 6mm output the other 5mm output. Can't even tell they were altered.
01-23-2018, 03:00 PM | #22 |
Don't know what happened to the pictures? Using the phone. I will delete a couple later.
01-24-2018, 05:34 PM | #23 |
My heim joints came in. Woo hoo ! 4mm. Built very nice. Smooth as silk and very tight. Gives me about 4" of travel per wheel before bottoming out. Which is plenty. Only issue is I will have to run slw's on narrow wheels because I am setting at 13" for width right now! Took these 6/32 t nuts, shaved them down and used them as bushings. Very smooth and no slop. Will trim up the t nut later. Very good fit, not slop. Tight set up. Last edited by holycaveman; 01-24-2018 at 05:41 PM. |
01-24-2018, 05:47 PM | #24 |
About 1 inch wider than I want. 4" under the chassis at full extension. |
01-24-2018, 06:33 PM | #25 |
I need some 2.2 scale positive off set slw bead locks. Anyone have any suggestions? Thanks
02-06-2018, 06:53 PM | #26 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
I know there not vp’s but the scale counter is pretty high The build quality and finish is pretty good too I have these wheels when they arrived it had a mismatch of bead ring hardware but that was soon rectified And nice and cheap Sent from my iPhone using Tapatalk |
02-07-2018, 05:57 AM | #27 | |
| Re: New C3 build. "The Outlaw" Quote:
02-13-2018, 07:18 AM | #28 |
Found a way to add air valves in this style of beadlocks. Even squeezed hard there is no air leaks. |
02-17-2018, 12:35 PM | #29 |
Finally got a little time to work more. Roughed in tub. Front diff mounts almost finished. All motor, t-case, and transmission mounts finished. Got the gold beadlock rings on with black hardware. The seat is the correct size, but I will make a seat in time and disregard this one. Next order of business is the hydro steer. May take a little time on it? |
02-17-2018, 03:24 PM | #30 |
Thank you sir. Its coming along!
02-21-2018, 09:47 AM | #31 |
Inching away. Going to be 28 metal tabs just on the front bulkhead alone! Only 8 more to go. |
02-21-2018, 12:43 PM | #32 |
Looking pretty sweet holycaveman, have you seen the vp curries front bulkhead that’s going to be released ? Can’t tell you what specific rig it’s for but looks pretty bombproof ! Quick question are you brazing ? Sent from my iPhone using Tapatalk |
02-21-2018, 02:43 PM | #33 |
| Re: New C3 build. "The Outlaw" Those do look nice! Yes I am brazing. Using copper/nickel alloy.
02-21-2018, 02:47 PM | #34 |
Yeah I know lovey bit of machining what are the benefits over silver solder ? Sent from my iPhone using Tapatalk |
02-21-2018, 04:05 PM | #35 |
I'm still using Silver solder but I'm using a copper nickel alloy tubing it seems to braise a lot better and smoother joints it flows easier in my opinion.
02-21-2018, 04:06 PM | #36 |
It also stays pretty soft so you can bend it easily just with your fingers until you put heat to it then it gets hard and rigid.
02-21-2018, 04:16 PM | #37 |
Wow that sounds amazing stuff , Iv only ever used silver solder and 6mm stainless steel tube but never made any cages or anything just several small projects for work and gagging to get started on a bouncer build found a chap online that makes benders specifically for our purposes Jawbreaker bender it’s called check it out cool bit of kit allows you to bend 2 tubes at the same time to get perfect symmetry from one side to the other . Sent from my iPhone using Tapatalk |
02-28-2018, 06:13 PM | #38 |
Little more progress done. Got my front ram built for the steering. Pretty excited to get the steering to a working status. |
02-28-2018, 06:34 PM | #39 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Too cool man! Great job so far. I love watching Clayton send that beast up the hill.
02-28-2018, 06:59 PM | #40 |
Newbie Join Date: Jan 2018 Location: PNW
Is that brass or steel tubing? Sorry but I'm new to all that stuff so just trying to learn. BTW looks really good man keep up the good work.
New C3 build. "The Outlaw" - Similar Threads | ||||
Jkabee's "total noob" TJ build "this should be fun!" | jkabee | Axial SCX-10 | 128 | 03-24-2013 12:10 PM |
RECON G6 Challenge "The Superlift Southern Showdown G6" & "Outlaw Terra-X" | DRIVNMF | Recon G6 | 227 | 10-19-2012 10:26 AM |
Chaotic Crawlers "DEMON" build! aka "Kreacher" | Mac10 | EnRoute Berg | 96 | 09-26-2010 01:49 PM |
J-Fab "NorCal" Outlaw MOA XR10. | Charlie | Axial XR10 | 19 | 09-19-2010 06:58 PM |
