![]() | #1 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
Its winter. And I don't start getting busy until march. Been out for a couple of years traveling the planet. I figure its the perfect time for a new challenge! This bouncer impressed me. I do not like bouncers mind you. but I like this one. Called " The Outlaw" I am pretty much going to follow the 1/1 build for the most part. But I love competing. So I will make a few tweeks here and there for performance and plan on seeing everyone at ECSC, KOG, and KNK. Who knows where else? ![]() ![]() ![]() ![]() |
![]() | #2 |
Need power and crawlability. I went with the Mamba x and Castle 1415 sensored. Its a lot more power than the slate system, but crawls as well. I may be testing out a new Sensored motor though. Its an inrunner with 6 polls and 18slots! And its not 1/8th scale. Will give you a sneak peak when I get it. I have a feeling it will be the new hotness? And also t-max diffs with lockers since its independent front and rear. Rc4wd tranny and transfer case. Have heard good things and it fits the build. ![]() |
![]() | #3 |
New Pit Bull 2 tires will probably make the comp scene. The 1/1 tires though will be on the final build. And messing around with the air inflatable tires. Pretty cool! Yes I know how they perform ![]() ![]() |
![]() | #4 |
After gathering all my supplies and setting up shop(just moved to another state) I finally started on the tube work. Planning on a 14" wheelbase, and 12" wide to make room for the independent A arms. Yes she is a big girl! Plus with 5.75" tires you got to be big. Got my first upper front A arm completed in the process. I like it! Thoughts? ![]() |
![]() | #5 |
![]() | #6 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Looks awesome man been wanting someone to do a build like this! Sent from my iPhone using Tapatalk |
![]() | #7 |
Pebble Pounder Join Date: May 2016 Location: Texas
I was wondering when someone was going to try and tackle this buggy. It's probably been done some where, just not shared on RCC.com. I can't wait to see the progress. I will be following this build. |
![]() | #8 |
Thanks fellows. I look forward to the challenge also. There has been a few different renditions of the 1/1 So Just following the AArm design is tough. It matched here with the front A arm but in other photos it's a different design. Also I wedged the underside for better performance. The 1/1 has a completely flat belly. ![]() ![]() |
![]() | #9 |
![]() | #10 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
This looks like a very interesting build , beautiful craftsmanship on the tube work I love this machine and am desperately wanting to build one too , why didn’t you go for the monster X ? I had the mamba X 1410 and I’m pretty sure it was a little under powered for my rock rey , looking at the tech specs as an after thought ![]() The 1515 paired with monster was the replacement which is very powerful and rated to 12lbs if I remember correctly, I might be wrong I’m pretty new to the new sensored range of motors . Can’t wait to see the finished product , definitely following this build closely ![]() Sent from my iPhone using Tapatalk Last edited by willyg1981; 01-21-2018 at 11:57 AM. |
![]() | #11 | |
| ![]() Quote:
I think that is the Outlaw 2 with the solid rear axle and turbo 4 cylinder. | |
![]() | #12 |
Good catch. That is why the different A Arms. I will have to try and keep an eye out for that in the future.
![]() | #13 |
Not much done today but I did get the a arm mounts done they look pretty good. Fairly flush on the bottom, overall happy with them. I will add reinforcement later ![]() ![]() ![]() Last edited by holycaveman; 01-23-2018 at 09:40 AM. |
![]() | #14 |
Moderator Rule Breaker ![]() Join Date: Feb 2004 Location: Austin, Tx
Is that piece of all thread? I’m going to suggest you use Titanium hinge pin or screw. There a ton of stress being put on those. I suggest you make a tube sleeve for the middle where the exposed screw is at. That sleeve help with not bending them. |
![]() | #15 |
MODERATOR™ ![]() Join Date: Jul 2004 Location: Ohio
Hi Tom!
![]() | #16 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Awesome! Great start - can't wait to see this progress.
![]() | #17 |
| ![]() Its 6/32 stainless. Just using it for mock up. Thanks. Going to consider these options.
![]() | #18 |
![]() | #19 | |
| ![]() Quote:
![]() | #20 |
Your very welcome holycaveman credit when credits due ![]() I look forward to seeing it ![]() Sent from my iPhone using Tapatalk |
Jkabee's "total noob" TJ build "this should be fun!" | jkabee | Axial SCX-10 | 128 | 03-24-2013 01:10 PM |
RECON G6 Challenge "The Superlift Southern Showdown G6" & "Outlaw Terra-X" | DRIVNMF | Recon G6 | 227 | 10-19-2012 11:26 AM |
Chaotic Crawlers "DEMON" build! aka "Kreacher" | Mac10 | EnRoute Berg | 96 | 09-26-2010 02:49 PM |
J-Fab "NorCal" Outlaw MOA XR10. | Charlie | Axial XR10 | 19 | 09-19-2010 07:58 PM |
