Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: What causes a esc to catch on fire in mud
Old 06-09-2020, 04:55 PM   #1
Default What causes a esc to catch on fire in mud
Hey guys are just got done building my outdoor mud section of my outdoor trail course and in the mud my esc com fire any reasons why?
Sent from my SM-G986U using Tapatalk
jemelumadu2 is offline   Reply With Quote
Old 06-09-2020, 05:04 PM   #2
Default Re: What causes a esc to catch on fire in mud
Any more info? What ESC? Was there a battery involved in the fire?
Did it actually catch fire or just release a puff of smoke?
HumboldtEF is offline   Reply With Quote
Old 06-09-2020, 05:16 PM   #3
Castle mamba x and maxamps 6s 2000mah
Old 06-09-2020, 05:25 PM   #4
And then.....can you answer the other 2 questions. Its hard to help without details.
Old 06-09-2020, 05:30 PM   #5
The esc is the castle mamba x and the battery is a maxamps 6s 2000mah lipo am I reading your question wrong?
Old 06-09-2020, 05:31 PM   #6
It puffed out smoke sorry
Old 06-09-2020, 05:39 PM   #7
Okay a puff of smoke is a little less of a failure, a failure none the less but going up in flames would be hard to explain.
Since you're running 6S the motor is a huge factor here, what motor is it and what KV is it? on 4S they recommend 1800KV or less, they dont list anything for 6S but it should be even less like 1200KV or less.
Another factor is waterproofing, 99.99% of all "waterproof" products have a note saying they're not intended to be submerged so think of it as splash proof.
From the Mamba X product page:
*Although Mamba X is waterproof, it is not intended for operation while completely submerged in liquid. Always rinse the ESC and motor with clean water after exposure to corrosives or dirt. While the motor and controller may be waterproof, we suggest users confirm that the rest of their vehicle, including the batteries, servos, radio and chassis are also waterproof before exposing them to liquids of any kind.
**The cooling fan must be removed prior to driving in wet conditions. It is not waterproof.
MAMBA X, 25.2V WP ESC, 8A PEAK BEC, DATALOGGING
I believe mud is more conductive than straight water due to the minerals present.
Old 06-09-2020, 05:42 PM   #8
I have the holmes hobbies PULLER PRO V2 ROCK CRAWLER MOTOR - STANDARD - 2200KV also sorry for how inexperienced I am I'm new to rc
Old 06-09-2020, 05:58 PM   #9
No dont feel bad, everyone gets their start somewhere.
I will say most get their start in RC running 2S. Running 6S just means you'll be close to the components limits of what they can handle (drivetrain and electronics).
If you want to get to the bottom of this you could contact Castle Creations directly and ask them what the KV limit is for the Mamba X on 6S.
They're usually very helpful, Robert from CC may even chime in here as he is an active member.
https://home.castlecreations.com/contact-us
If your motor is over that rating (which I think it is) thats probably the culprit but it will be hard to rule out the mud/water doing it as well. If the motor is under the limit its a good chance it was the mud/water.
You can take further measures to waterproof components using conformal coating though this only applies to things that aren't potted (sealed up with epoxy) like the Mamba X. I do this to all of my receivers to be safe (I dont run through mud/water).
Old 06-09-2020, 06:00 PM   #10
If your motor is over that rating thats probably the culprit but it will be hard to rule out the mud/water doing it as well. If the motor is under the limit its a good chance it was the mud/water.
Okay thanks Humboldtef
Old 06-09-2020, 08:09 PM   #11
Welcome to the forum...
Letting the smoke out of the esc, that the factory put in is commonly caused by to many amps passing through it. The cause of too many amps is often a stalled motor( load ) or in other words, the motor is pulling more amps than the esc can provide, or as mentioned, water hits stuff it shouldn't. To prevent this we gear the rigs down, put a slower motor in, or use lower voltage, and add water proofing.
I bet the truck you ran, was an absolute blast until it smoked. 6s in a mud truck would sling mud sky high I am sure. More info on your truck would help us help you in a proper long lasting setup.
lonleycreeper is offline   Reply With Quote
Old 06-09-2020, 08:13 PM   #12
I'd be curious to know more too.
Old 06-09-2020, 08:18 PM   #13
About what?
Old 06-09-2020, 08:38 PM   #14
Originally Posted by jemelumadu2 View Post
About what?
Just about your truck, what model is it? pictures? it just sound interesting.
And as lonelycreeper said we can better help guide you if we knew what rig we were talking about.
I'm guessing TRX-4
Old 06-09-2020, 08:49 PM   #15
I'm guessing TRX-4
Traxxas trx6 with capo air suspension,castle mamba x, maxamps 6s 2000mah battery, holmes hobbies servo with 4s battery, holmes hobby puller pro 2200kv, transmission oil mobile1 ,metal gear box Housing, mudslingers 2.2, longer arm lift kit, all electronics waterproofed, yeah Racing heat sink, yeah Racing steel drive shafts, metal traxxas trx4 chassis brace, BowHouse high clearance skid v2 ripple killer cap pack
Old 06-09-2020, 08:50 PM   #16
I'm guessing TRX-4
Also trying to move batteries to the 2 rear axles and install 6 wheel steer
Old 06-09-2020, 09:00 PM   #17
Old 06-09-2020, 09:22 PM   #18
Well that is pretty damn interesting
How's the air suspension to play around with?
I'll say the 2.2" tires and being a 6x6 are another big factor here, these put a bigger load on the ESC.
Its best practice when "volting up" to also gear down, when balanced right this creates a more efficient setup.
I think the TRX's can only gear down to a 9T pinion which isn't a lot lower than stock so you may need to back down the voltage to a 4S as well as gearing down to have a safer setup.
It does sound like a blast but that setup is cruising for a bruising lol
If it were me I'd back down to this 1200KV motor at the least if not backing down to 4S as well https://holmeshobbies.com/motors/bru...or-1200kv.html
its even in stock right now, crazy
You might want to go for the Mamba X monster (if thats not what you have) its rated for heavier rigs
https://www.amainhobbies.com/castle-...145-00/p453455
not in stock unfortunately
Old 06-09-2020, 09:28 PM   #19
I will probably put 2 fans on the front and rear of the truck for more air flow. Also the air suspension works great it's a gem on side hills because you can raise one side and it doesn't flip, also it took a bunch of time to waterproof. Lastly the cap packs make the truck super smooth and the transmission fluid too unexpected right.
Old 06-09-2020, 09:39 PM   #20
sorry I was editing my post as you replied, I always seem to miss something.
I dont think you have an air flow issue, its that your demanding too many amps from the ESC. 6X6 + big 6"(?) tires means a very big load is being put on the ESC.
What causes a esc to catch on fire in mud - Similar Threads
trx4 esc fire! Moneypitrc Videos! 1 06-18-2018 02:12 PM
Recommendations for ESC that WON'T catch on fire gbalstad Axial Yeti 8 01-09-2017 06:57 PM
ESC on fire. Help? SDheavymetal Electronics 7 11-24-2008 11:23 PM
