10-11-2020, 02:43 PM | #121 |
Quarry Creeper Join Date: Aug 2020 Location: Springfield
| Re: NK's V1 Bomber Build
Washed it up and plugged a battery in to dry the tires some Was having all kinds of glitching, and the Mamba X was giving me a receiver error beep I opened the receiver box expecting water but it was bone dry Suspicion lead me to the on/off switch with the broken rubber boot, cut it off and wired the leads together and it works flawlessly again |
10-11-2020, 05:09 PM | #122 | |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: NK's V1 Bomber Build Quote:
Sent from my LM-G710VM using Tapatalk | |
10-11-2020, 05:11 PM | #123 |
| Re: NK's V1 Bomber Build |
10-11-2020, 05:12 PM | #124 |
10-11-2020, 07:55 PM | #125 |
Not a lost a nut, but a broken axle tip! Oh the joys of running in water. |
10-11-2020, 07:55 PM | #126 |
10-11-2020, 08:18 PM | #127 |
Yeah that may cause some issues Factory axial ring gear is completely wallered out Explains the rubbing on the lockouts |
10-12-2020, 06:57 AM | #128 |
10-12-2020, 06:58 AM | #129 |
10-12-2020, 07:01 AM | #130 | |
10-12-2020, 07:12 AM | #131 | |
Then I ran OD/stock open front/locked rear and hated it Only combo I havent tried is OD/stock with a locked front and open rear | |
10-12-2020, 07:13 AM | #132 | |
10-12-2020, 07:41 AM | #133 | |
No issues with speed, the track is so slick it never gets a chance to bind | |
10-12-2020, 09:07 PM | #134 |
New bearings through the rear I also am going to try open/open. But it's Lucas red/tacky up front and #100,000 diff grease in the rear HD gear set, factory ratio front and rear I still need to rebuild the front but I'll wait for the snowballs to show up NO stainless beef tubes in the rear, going to see how it fares. An axle housing is 12$ vs dealing with the filed axle flanges 15mm hot racing extensions instead of 20mm |
10-12-2020, 09:28 PM | #135 | |
While I was running locked front and rear with OD/stock gearing; it would wander across gravel while at top speed Almost like the servo wasn't centering, but It was back/forth as I would run a high speed straight I'm assuming this was the front/rear slipping differently on the gravel, causing it to float off course | |
10-13-2020, 09:03 AM | #136 |
I was thinking about adding OD gears or perhaps UD gears to the rear on my wroncho, but it may see a little speed, so I'm unsure. I'll drive it with the stock gears in it to see how it does and then add either OD or UD to it later on down the road. Sent from my LM-G710VM using Tapatalk |
10-13-2020, 08:40 PM | #137 | |
If it matches the ar60 the ratio is less, but it's also easer to get into the rear axle without the steering system in the way, my .02 | |
10-14-2020, 08:19 PM | #138 |
Got to run today, less than a battery pack tho Lower shock mount came unscrewed from the front axle. Time to look for something decent As far as the open diffs, when it starts to roll in a corner; both inner tires diff out. Long enough that it gives me time to correct it by turning 180. Thinking about some 500,000# in the rear, the tires dont free spin with the 100,000 but it's pretty easy to break a tire free by hand Not sure if the rolling save is a good thing, seems like a lot of wear with all that power transfer I wonder how locked front/open rear might be, would definitely cause some stress on drivetrain and steering servo but it may be more predictable leaving turns? |
10-14-2020, 08:38 PM | #139 |
Nice Big Air pics! How are those wheels working out? Sent from my LM-G710VM using Tapatalk |
10-14-2020, 08:42 PM | #140 |
NK's V1 Bomber Build - Similar Threads | ||||
My Bomber Build | angrchair | Axial RR10 Bomber | 182 | 02-21-2021 05:10 PM |
Need Help with Bomber Build | Digs1111 | Newbie General | 7 | 09-03-2017 01:40 PM |
Bomber Build Need Help | CmdrSmushy | Axial RR10 Bomber | 7 | 12-27-2016 11:05 AM |
Bomber Build | bombardorphil@gmail. | Axial RR10 Bomber | 1 | 03-08-2016 10:58 AM |
My Bomber build | bredmx | Axial RR10 Bomber | 8 | 12-28-2015 11:51 AM |
