09-30-2020, 11:34 AM | #21 |
Newbie Join Date: Feb 2019 Location: US
| Re: MaX-D's Wroncho Build
No problem! Sent from my SM-G965U using Tapatalk |
10-04-2020, 01:51 PM | #22 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
Got the chassis sprayed with primer. I never realized how cool primer can look. Although initially wanting to paint it Satin Black, I'm almost tempted to leave it. Sent from my LM-G710VM using Tapatalk |
10-04-2020, 06:56 PM | #23 |
Satin black. Sent from my LM-G710VM using Tapatalk |
10-08-2020, 07:12 PM | #24 |
Took both front and rear ends apart to check bearings, gears and grease. Bearings and gears still in great shape. Fresh grease and they're good to go. Sent from my LM-G710VM using Tapatalk |
10-08-2020, 07:13 PM | #25 |
New skid. Sent from my LM-G710VM using Tapatalk |
10-08-2020, 07:15 PM | #26 |
I'm going to replace the steel spur with a stock plastic spur. Sent from my LM-G710VM using Tapatalk |
10-08-2020, 07:17 PM | #27 |
I discovered that the idler and lower gear are plastic. New metal gears have been ordered. Sent from my LM-G710VM using Tapatalk |
10-10-2020, 07:51 PM | #28 |
Team KNK stainless screw kit ordered and on the way. Sent from my iPad using Tapatalk |
10-15-2020, 08:53 PM | #29 |
Metal tranny gears arrived. Sent from my LM-G710VM using Tapatalk |
10-15-2020, 08:59 PM | #30 |
Got the red anodized chassis braces de-anodized. Now I'm just waiting on a complete Team KNK stainless screw kit, and a complete bearing kit. If you're gonna do it, do it right. Sent from my LM-G710VM using Tapatalk |
10-16-2020, 07:55 PM | #31 |
Had a nice surprise when I got home from work today. My screw kit arrived! Two days from Ohio to South Florida. I honestly wasn't expecting it until Tuesday-Wednesday of next week. Team KNK never fails to disappoint. Sent from my LM-G710VM using Tapatalk |
10-16-2020, 08:30 PM | #32 | |
| Re: MaX-D's Wroncho Build Quote:
Sent from my SM-T337T using Tapatalk | |
10-16-2020, 08:35 PM | #33 |
| Re: MaX-D's Wroncho Build |
10-17-2020, 08:50 PM | #34 |
Ran into my first problem. The shocks are going to hit the chassis. Can you mount the shocks on the outside of the shock mount on the axle? Pros and cons of this? Sent from my LM-G710VM using Tapatalk Last edited by MaX-D; 10-17-2020 at 08:53 PM. |
10-17-2020, 08:58 PM | #35 | |
Sent from my SM-G965U using Tapatalk | |
10-18-2020, 01:24 PM | #36 |
Problem solved! I cut a piece of delrin to size to fit in where the shock ball used to be. I was just going to use a shock ball but didn't have any that would fit. I used a 3x30mm screw. Sent from my LM-G710VM using Tapatalk |
10-18-2020, 01:42 PM | #37 |
Up top, I used an aluminum shock standoff and a shock insert from a Proline Powerstroke shock. The shock tower support between the towers is an aluminum chassis support I swiped from the donor truck. It's threaded on the inside. Perfect fit! Even at full compression I've got about 4mm of space at the bottom. No rubbing at all whatsoever. I threw a tire on to check my turning at full lock I've been using 15mm extenders so the tires don't hit the springs. Now they hit . Don't know what I'm going to do about that. We'll see once I get it completely together. Sent from my LM-G710VM using Tapatalk |
10-18-2020, 01:46 PM | #38 |
The KNK screw kit didn't include the 3x20mm screws for the lower links. I'm waiting on those from Amazon. Sent from my LM-G710VM using Tapatalk |
10-18-2020, 07:02 PM | #39 |
Made some more progress. Got the rear shocks done, and the rear sway bar set to go. It's starting to resemble a truck. Sent from my LM-G710VM using Tapatalk |
10-19-2020, 07:59 PM | #40 |
I think I may have the sway bar worked out. I used Losi TLR 22 ball cups. They are much shorter than the cups I used on the monster truck. Sent from my LM-G710VM using Tapatalk |
MaX-D's Wroncho Build - Similar Threads | ||||
Mike D's bomber upgrades/build | xmikedentx | Axial RR10 Bomber | 22 | 06-12-2016 05:57 PM |
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) | Irishchamp | 2.2 Scale Rigs | 45 | 10-09-2014 10:26 PM |
R|M|D's Yota Build (Pic Heavy) | R|M|D Photography | 1.9 Scale Rigs | 39 | 12-24-2012 12:33 AM |
C*H*U*D's New F-4 Build | C*H*U*D | Axial AX-10 Scorpion | 81 | 10-28-2010 10:35 AM |
