11-24-2020, 10:10 AM | #101 |
Quarry Creeper Join Date: Jan 2009 Location: WA state
| Re: MaX-D's Wroncho Build
Smart body mounting idea! What if you shoe goo the screw? If you ever needed to remove it shoe goo is easy enough to scrape off. It would hold the screw on enough to get the cap on. just a thought.
11-24-2020, 10:22 AM | #102 | |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: MaX-D's Wroncho Build Quote:
Sent from my LM-G710VM using Tapatalk | |
11-24-2020, 10:53 AM | #103 |
Mod .8 and 32p are not exactly the same... but they're close enough that I run them together. I kinda have my doubts that your 9t is going to reach your 56t spur, it wouldn't mesh up as tight as I like with my 58t (motor was all the way up against the trans, no more room for adjustment) hence the reason I suggested 9/60. I know that 10t will fit with a 56t though.
11-24-2020, 12:51 PM | #104 |
Holmes hobby 550 12T crawl Master sport on order, as well as a 32P 10T Robinson Racing pinion. Sent from my LM-G710VM using Tapatalk |
11-24-2020, 02:43 PM | #105 |
Good choice. That's what I'm running in my Gen8 with 2.2s. good mix of speed and Tq.
11-24-2020, 02:54 PM | #106 |
| Re: MaX-D's Wroncho Build |
11-24-2020, 03:02 PM | #107 |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
I wasn't happy with my 12t motor but I probably had it geared too high. It would crawl if you leaned into it but one mistake with the finger and it would go full send lol. And it ran hot.
11-24-2020, 03:22 PM | #108 |
11-24-2020, 05:47 PM | #109 |
11-24-2020, 07:27 PM | #110 |
11-25-2020, 12:19 AM | #111 |
Phildirt: I'm guessing your 12t was a 3 slot motor, like a traxxas titan? The 12t 5-slot Crawlmaster is about the same speed as a 21t 3 slot (so, much slower than a 3 slot 12t) but it has much smoother start up. My neighbor had (has?) a 12t 550 Crawlmaster sport in his Wraith with 6" tires, 10/56 gearing, wp1080 esc, and it was VERY smooth starting up and still had decent (not spectacular) punch/get up & go on 3s. I think that motor on 4s would be pretty sweet.
11-25-2020, 10:16 AM | #112 |
I added the driver side body mount. I'm definitely going with the proline locking knobs. I was actually going to use magnets instead until I found a cracked magnet on my TRX 4 sport last nite. Now I have to peel that off and silicon on a new one. What a PITA. Sent from my LM-G710VM using Tapatalk |
11-25-2020, 11:06 AM | #113 |
I just got confirmation that my motor will be here on Monday. A brand new WP1080 is staying nice and warm in a drawer under my workbench. Sent from my LM-G710VM using Tapatalk |
11-30-2020, 02:50 PM | #114 |
I made some more progress over the weekend. Got the body mounts done. Did some wheel well surgery so the tires don't rub. It's ready for paint. Sent from my LM-G710VM using Tapatalk |
11-30-2020, 04:17 PM | #115 |
I got the front body posts done. Sent from my LM-G710VM using Tapatalk |
11-30-2020, 04:20 PM | #116 |
I decided to add some body posts to the rear just for added support in case of a rollover. I was initially going to use the proline locking knobs, but didn't like the way it looked at all. Plus, I have large mitts and it was hard to get my hands in there to tighten and loosen those knobs. Even my 13 year old son had difficulty doing it. Sent from my LM-G710VM using Tapatalk Last edited by MaX-D; 11-30-2020 at 04:41 PM. |
11-30-2020, 04:31 PM | #117 |
So I decided to go with a traditional body post. I cut a Traxxas Slash body post down to size and used a 3x8mm screw left over from my TRX 4 sport to secure the body post to the L-bracket. The 8mm size was perfect as I didn't have to use a washer. This looks much cleaner and it's so easy to slide a pin into the post. I've come to find that using a actual drill bit to drill body post holes is much easier and cleaner then using an actual body post tool. Sent from my LM-G710VM using Tapatalk |
11-30-2020, 04:32 PM | #118 |
Delete....double post.
11-30-2020, 04:56 PM | #119 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
11-30-2020, 05:04 PM | #120 | |
MaX-D's Wroncho Build - Similar Threads | ||||
Mike D's bomber upgrades/build | xmikedentx | Axial RR10 Bomber | 22 | 06-12-2016 05:57 PM |
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) | Irishchamp | 2.2 Scale Rigs | 45 | 10-09-2014 10:26 PM |
R|M|D's Yota Build (Pic Heavy) | R|M|D Photography | 1.9 Scale Rigs | 39 | 12-24-2012 12:33 AM |
C*H*U*D's New F-4 Build | C*H*U*D | Axial AX-10 Scorpion | 81 | 10-28-2010 10:35 AM |
