11-04-2020, 12:07 PM | #1 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Need Wroncho Rock Slider help
I'm about at the point in my wroncho build that I need Rock sliders. I'm using The Wraith skid with a Honcho body. From the frame rails to the edge of the body is roughly 1.5 - 1 5/8 in or 40mm. The length is 6.25" or roughly 158 mm. Any suggestions on Rock sliders? I found a few, but have no idea if they would work or not. Thoughts? https://www.amainhobbies.com/bp-cust...msgen2/p770627 https://www.amainhobbies.com/rpm-axi...m73452/p448874 https://www.amainhobbies.com/axial-1...i80041/p151641 Sent from my LM-G710VM using Tapatalk |
11-04-2020, 12:32 PM | #2 |
Quarry Creeper Join Date: Jan 2009 Location: WA state
| Re: Need Wroncho Rock Slider help
Which I could help. I used a Cherokee body and RC4WD sliders for my wroncho build. I used a SCX10 ii Vader products flat skid and every thing worked together. I'd say the RPM sliders look to give you the best fit. seems like you could get it pretty damn close with the stock holes. The axial seems like it would stick too far out and the BP you could possibly trim and drill new holes. Just my .02, but I've never owned a honcho before. I've had the RPM and axial sliders on other rigs though, so I'm familiar with the adjustability. |
11-14-2020, 08:24 PM | #3 |
Rock Crawler Join Date: Apr 2009 Location: bend
Get a small sheet of 1/8 delrin and make some. A heat gun can be used to shape them.
