Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: "the reaper"
Old 12-02-2011, 04:47 PM   #1
Default "the reaper"
I DID GET A LITLE AHEAD OF MYSELF ON THIS BUILD!
i started taking crappy pics late but here is the low down...
with all the koh/G6 events popping up i new i wanted to build a go fast truggy.
i wanted an independent front end, trailing arms, wraith rear axle, 2 speed tranny and some brushless speed.
i basically started this ground up and here are some pics to get you jump started to where i am today
i sarted with a slash front end with the stampede rear arms to shorten her up a bit. coupled with some really cool RCE parts, RC4WD trailing arms, summit 2 speed trans, a wraith rear axle and a sheet of 1/8" carbon fiber, some 1/4" delrin and some cnc cutting we are here.
basic roller
i am using the strc slash 4wd parts for the front end with the x duty mips. there were some fitment issues so i had to do some mill work to the hubs to get the clearences i needed.
i will be running the pro 4 motor in this (there is clearence to run the t8 also) but there was an issue with the pinion lining up with the spur no matter what the pinion orientation was, so i made a 1/4" delrin spacer to pull the motor back a bit.
all better
now the tube work went really fast and pics were slim but this will let you see the drection i am going.
battery location
some more progress
krawlfreak is offline   Reply With Quote
Old 12-02-2011, 04:49 PM   #2
now some body work!!
the templates
and now some aluminum
Old 12-02-2011, 04:53 PM   #3
Wow, this thing should go like a bat out of hell!
Any chance of lowering the battery to a different location? Looks like a lot of weight to have up high.
ecoli is offline   Reply With Quote
Old 12-02-2011, 04:54 PM   #4
Scale Detail Engineering
That's pretty tough!
Think you could mount the battery under the tray for a lower cog?
johnnyh66 is offline   Reply With Quote
Old 12-02-2011, 05:16 PM   #5
i wanted the battery there. the intention was to even the weight distribution of the entire vehicle so it will handle at speed and fly well. plus with the leveraged rear suspension i should be able to tune the rear to handle it.
also there is no room with the narrow pan.
hasn't any one told you rock crawling is only the obsicles in the way of the high speed stuff
Old 12-02-2011, 06:28 PM   #6
WOW
I really love builds that color outside the lines!!
What is the carbon fiber belly from?
How do the rear frame rails attach?
Love the look of it!!
sweli is offline   Reply With Quote
Old 12-02-2011, 06:41 PM   #7
looks awesome! robinson makes a pinion that will work for you. I dont think you will need a t8, i got rid of mine and am way happy with the pro4
willipmartinni is offline   Reply With Quote
Old 12-02-2011, 07:14 PM   #8
Originally Posted by sweli View Post
WOW
All of the carbon fiber and delrin pieces are my own design and cutting.
It is all good now. I have a pro 4 in my Tundy and it is great. The t8 would be for all out fury...
Old 12-02-2011, 07:53 PM   #9
no talent hack
I'm gonna need one of those chassis. You know my address
Nabil is offline   Reply With Quote
Old 12-02-2011, 10:19 PM   #10
Way cool!
tcrawler is offline   Reply With Quote
Old 12-02-2011, 10:47 PM   #11
Disk brakes in the carbon fiber flavor...
Old 12-02-2011, 11:08 PM   #12
Sick build!!! I can't wait to see a video. Subscribed!
Bulldog is offline   Reply With Quote
Old 12-02-2011, 11:08 PM   #13
DOOH!!!
Jeremy = taking shit to a whole new level...
MTHead is offline   Reply With Quote
Old 12-02-2011, 11:28 PM   #14
This is one Badass IFS Truggy! Excellent work! I thought I seen some disc in the pics, very nice scale addition.
I'm with Nabil on the chassis... Needing one of those soon.
Gear Jammer is offline   Reply With Quote
Old 12-03-2011, 12:30 AM   #15
looks amazing.
mattcrawler is offline   Reply With Quote
Old 12-03-2011, 07:49 AM   #16
Very cool. Hows the weight?
Whats with the extra screw hole at rear of bottom plate?
Erin is offline   Reply With Quote
Old 12-03-2011, 08:29 AM   #17
cool build man! verry cool
theyukonzoo is offline   Reply With Quote
Old 12-03-2011, 09:04 AM   #18
Thanks.
I was gonna angle the trannys then decided against it...
Ted says its lighter than his wraith.
there will be video of this one!
Thanks!
Old 12-03-2011, 09:09 AM   #19
Trannys shift servo location
Old 12-03-2011, 09:15 AM   #20
I will be using the highland locker with the larger mounting hardware and a set of 36/14 hardened gear set.
Redrilled and countersunk gear assembly
I will try the plastic housing for now until vanquish has there axle housing available...
