06-05-2021, 03:03 PM | #21 | |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: There’s a Ryft forming in my basement Quote:
~ More peace, love, and kindness would make the world a much better place | |
06-05-2021, 03:19 PM | #22 | |
Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
Thanks that’s good to hear! The problem pack will be closely monitored and promptly dealt with if it discharges poorly Sent from my iPhone using Tapatalk | |
06-06-2021, 02:07 PM | #23 |
Newbie Join Date: Jan 2021 Location: Albuquerque
Lookin good, I have the same motor in my kit, looking forward to trying it out.
06-06-2021, 06:17 PM | #24 |
I got some decent footage out on the trail today. The truck is a blast! Took the rear diff out again and broke a m4 angled rod end(my fault I crashed out of control at like half throttle) it’s insanely fast but oh so controllable with the castle system. Torque for days. The kit sway bar definitely works wonders. I’m probably going to jb weld the diff internals in the rear. I like having the front open but I need to get lockers. This rig needs some hardened steel spools(not inserts for the diff case)https://youtu.be/DAZJY6P2u-Q I was not out break it but I definitely didn’t baby it. I think it did well. It climbs great stays planted. It’s definitely bouncy Sent from my iPhone using Tapatalk |
06-09-2021, 08:06 AM | #25 |
Well had the day off from work and the morning was cool so I took the Ryft out for its 2nd run. Diffs are completely busted. They absolutely CANNOT withstand even the lightest form of bouncing. These diffs are JUNK Sent from my iPhone using Tapatalk |
06-09-2021, 08:33 AM | #26 | |
06-09-2021, 08:45 AM | #27 | |
I’ve got some gopro footage I’m uploading and editing which will be up later. I just had to vent as I’m rather displeased with the durability of this truck Sent from my iPhone using Tapatalk | |
06-09-2021, 09:16 AM | #28 | |
06-09-2021, 09:41 AM | #29 | |
Oh ya I will get some pics once I get to tearing the axles down. It’s the differential gears. I’m going to clean up the silicone and fill the cases with jb weld. Sent from my iPhone using Tapatalk | |
06-09-2021, 10:56 AM | #30 | |
06-09-2021, 11:08 AM | #31 | |
Currently there are 2 lockers available. The sintered axial that fits into the diff case. Or the vitavon from China for 42$ cad for hardened steel insert into the case. I’ll wait till proper lockers come out that bolt directly to the ring gear made of hardened steel. Neither option really has me going plus the wait time for shipping to canada. I’m going my route lol I definitely do not advise this route either. But it’s what I’ve got Sent from my iPhone using Tapatalk | |
06-09-2021, 11:38 AM | #32 |
Well this is how the ryft is sitting now… Exploded differentials. As you can see from the shims the diffs are to tightly meshed. Out of the 3 diffs in the kit I now have one able to function if I mix and match parts. After 2 runs. Pathetic Sent from my iPhone using Tapatalk |
06-09-2021, 11:54 AM | #33 | |
Now, what I'm hoping for is either a slight OD gear set for the front and/or a slight UD gear set for the rear...nothing major...say, something in the 8-12% range. In other words, something to give the front just a lil extra "umph". For those who want to keep the vehicle 'fast', they could use one, or the other, depending on the kV of their motor. For those who want to use theirs as a crawler, they could install both, giving the front a 16-24% OD (depending on the actual OD & UD of the gear sets). ~ More peace, love, and kindness would make the world a much better place | |
06-09-2021, 12:11 PM | #34 | |
My thoughts are this Knowing vanquish is designing parts Im positive lockers are on their radar. And given all their other designs are solid spools I doubt they’ll design the ryft spools any differently. It only makes sense eliminate the plastic case which leads to ring gear runout and inconsistency of ring/pinion tolerances upon installation. Not to mention the strength/rigidity increase. I was thinking about od on the trail today. A moderate od less than 20% could work for my purpose of crawling/rock bouncing/hill climbs. Again just waiting to see what vanquish products has in store for the ryft. In the mean time I guess I’ll wait for horizon support to see what they’ll replace before I go making jb weld lockers lol Sent from my iPhone using Tapatalk | |
06-19-2021, 08:59 PM | #35 |
Little update tonight. After my third diff rebuild and subsequent failure I have now resorted to filling the cases with Devcon steel putty. That’ll do the trick nicely. The gears are terribly weak and poorly toleranced. Very disappointing to say the least. Even on 2s the castle system shredded a gear inside. Anyways now that the resin is curing here’s a vid https://youtu.be/TvqBJ3ZD9D0 Sent from my iPhone using Tapatalk |
07-06-2021, 10:26 PM | #36 |
RCC Addict Join Date: Jun 2008 Location: Mudville
locked the rear and center diff with the axial lockers myself. Rebuilt the front hoping for the best, but expecting it to bomb. Have a 3rd axial locker when needed, and another set of diff gears. thinkin of maybe a Vitavon 7075 diff case, or two. maybe that would keep the stock diff gears ok, but I doubt it. Metal seems too soft to be hones. I asked Josh on his stream Friday night about Hardened Diff Gears etc, and he said Most likely yes on them. Treal has a spool out, and it looks like Vitavon is bring a Steel spool option> Trying to holdout |
07-10-2021, 09:50 PM | #37 |
Treal has an actual Spool available for like 35 usd. Hardened steel. I see Vitavon has an 7075 Spool coming. Hoping Vanquish will get to Hardened diff gears before a locker or spool to be honest. The company that comes with the first good set of diff gears will win. I suspect Vanquish will also bring a Curry style aluminum axles and axle shafts and tranny gears. |
There’s a Ryft forming in my basement - Similar Threads | ||||
Ryft 2 speed | Druxus | 2.2 Scale Rigs | 18 | 05-28-2022 08:57 AM |
RBX10 Ryft | josh9mile | General Crawlers | 12 | 07-06-2021 09:33 PM |
Axial Ryft turns off | rubiconrockkrawler | 2.2 Scale Rigs | 1 | 05-16-2021 10:41 PM |
MT Ryft | TAT76 | 2.2 Scale Rigs | 29 | 05-05-2021 07:30 AM |
Treal Ryft axles | Frank211 | General Crawlers | 0 | 04-27-2021 10:32 PM |
