Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: JDM74's Ryft Build
Old 06-22-2021, 01:52 PM   #21
Default Re: JDM74's Ryft Build
Originally Posted by JDM74 View Post
I'm not sure but it has been skidding on its lid since this pic was taken and can't see any color fade at all. This 3800 kV motor on 3S is a bit too much, lol. I'm going to try it on 2S and see if it comes close to sanity.
I couldn’t imagine 3s on 3800kv lol. My 4s 2400kv is theoretical 40000rpm. Your 3800kv 3s works out to 47000rpm. Blistering lol. I like it much better with 13t pinion low gear 4s. Is just about near perfect for any situation
RockCrawlingKid is offline   Reply With Quote
Old 06-22-2021, 02:53 PM   #22
How do you like the Proline dual stage foams? Do they fit and fill the tire well? I was debating them but typically use CI foams. These are the tallest tire I've had so far.
Truck looks fantastic
vinnieb729 is offline   Reply With Quote
Old 06-22-2021, 04:33 PM   #23
I think they do a pretty good job of filling the tire but not over stuffing it.
JDM74 is offline   Reply With Quote
Old 06-22-2021, 05:31 PM   #24
3800kv on 3S is WAY, WAY too much. I'm only running a 3200kv (also on 3S) in my R4sty. Did the Ryft, as many others have mentioned, probably shouldn't go any higher than 2700kv for 3S (on the stock gearing). It's no wonder yours has spent so much time upside-down.
~ More peace, love, and kindness would make the world a much better place
Panther6834 is offline   Reply With Quote
Old 06-22-2021, 05:33 PM   #25
Well I am running a 13 tooth pinion.
Old 06-22-2021, 05:36 PM   #26
I'll take the 2700kv & stock pinion, as opposed to "being a turtle".
Old 07-06-2021, 10:09 PM   #27
How are the swampers holding up? Any other wheels you have tried?
Looking for options for mine. I have the sotckers of course, and picked up a set of Pitbulls on Proline USA Beadlock wheels.
Looking to have a 3rd opinion.
mostly trail/dirt running, some hill and some rocks, a bit of low speed crawling here n there.
Suggestions?
Would prefer to stay in the 5.5 - 6 in tall area.
Timmahh is offline   Reply With Quote
Old 07-06-2021, 10:28 PM   #28
Haven't 'tried' anything in the Ryft...at least, not yet. It's ready for "final assembly", but was still waiting for my 'special' items coming from overseas. I've got everything installed on the skid, the cage is together, the tires are mounted, the axles are fully assembled, the Traxxas GTR shocks are ready to install...just need to put these 'groupings' together into a vehicle.
I know I'd have to partially disassemble things once my 'special' items arrive...but, if I temporarily get the vehicle operational, at least I'll be able to get initial testing done...so, I think that's what I'll do.
At the same time, I have tested the Pit Bull Growlers, Hyrax 1.9s, and Hyrax 2.2s on my Capra (ran the Hyrax 1.9s on the Capra at Scale Nationals), and all are excellent. Something I'm considering (especially if the stock Swampers don't work) is the Hyrax 2.2s in G8.
Old 07-23-2021, 04:56 PM   #29
This is on 2s, lol.
https://www.youtube.com/watch?v=xDd4vf9PxcY
https://www.youtube.com/watch?v=97MYbPPBCc4
https://www.youtube.com/watch?v=2wmNIkEOd20
And...ended up mulching the front diff (the only one that isn't locked) so spool in in route on the slow boat.
All in all, pretty happy with it. Need to find some more hills!
Old 07-23-2021, 08:58 PM   #30
This is on 2s, lol.
Rebuilt my F diff. So far slow K but not really had a chance to run it. Have a 3rd axial locker here for when they go tits up.
Im in corn country. what are hills? lol
Old 08-02-2021, 07:41 PM   #31
If you listen at the end you can hear diff gears go to heaven. lol.
https://www.youtube.com/watch?v=3VTjrDzHKlo
Old 08-09-2021, 03:06 PM   #32
New tires! Finally were in stock.
Old 08-13-2021, 03:34 PM   #33
Mounted up with new front spool installed
I had to go back to the stock foams. The Proline dual stage were just too big for the inside of the the USD Stickies. I way even drop back to a 5.5 double deuce CI foam in soft outer front and soft outer rear. Anybody have any thoughts on the USD's as far as foams go?
Old 07-06-2022, 07:01 PM   #34
Been a year since I last updated this thread almost. I have a 2700 kV motor on order from Holmes. Hopefully this will tame this beast a bit. Once I get it in I will take it out and test these tires and the new reduced speed out.
Old 10-02-2022, 10:11 AM   #35
Craweler87's Avatar
So how’s it working for you?
Craweler87 is offline   Reply With Quote
Old 01-16-2023, 03:27 PM   #36
I love those wheels! I’m thinking about getting the bronze ones. How are they holding up? And I assume no rubbing or binding anywhere with them?
Mikeymx26 is offline   Reply With Quote
Old 01-24-2023, 06:05 PM   #37
That came out super nice. How does it run for you.
Runnin2live is offline   Reply With Quote
Old 01-27-2023, 09:29 AM   #38
love the look.. great job
Jbrick is offline   Reply With Quote
JDM74's Ryft Build - Similar Threads
Ryft 2 speed Druxus 2.2 Scale Rigs 18 05-28-2022 08:57 AM
RBX10 Ryft josh9mile General Crawlers 12 07-06-2021 09:33 PM
MT Ryft TAT76 2.2 Scale Rigs 29 05-05-2021 07:30 AM
JDm74's Blazer JDM74 Traxxas TRX-4 79 06-06-2020 08:15 AM
JDM74's Next misadventure JDM74 Element RC 1/10 Enduro Trail Truck Sendero 47 05-02-2020 02:12 PM
