06-29-2021, 10:28 AM | #1 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| any 2.2 comp rigs here?
I see stuff about Ryft and Wraiths but no comp rigs, nothing wrong with that but any 2.2 Comp rigs? Here is mine. TRX 4 front axles with selectable lockers TRX 4 trans, 2 speed but set only in first, needed the channel for the rear steer. Bow House skid NSDRC RS2 V800 servo in front G13 in the back JEC servo mounts. Revolver 1400 SW4 Scattergun Chassis 850 battery up front SSD Wheels Hyrax G8 stock foams Spektrum DX5 rugged controller Last edited by MOguy; 06-29-2021 at 10:33 AM. |
06-29-2021, 12:28 PM | #2 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: any 2.2 comp rigs here?
Sick rig! I love 4ws. How do you like it? I almost prefer 2.2 over 1.9 What tires are you using? Sent from my SM-G991U using Tapatalk |
06-29-2021, 01:31 PM | #3 | |
| Re: any 2.2 comp rigs here? Quote:
I just finished the 4ws and it really increases the capability. The tighter steering is a given but but you can also use to get that tire right were you want it. You can almost pic two lines to run at the same time BUT it can also screw you if you turn at the wrong time. I think with enough practice the added benefit will be incredible. I am running Hyrax G8 with stock foams. | |
06-29-2021, 01:36 PM | #4 |
| Re: any 2.2 comp rigs here? |
06-29-2021, 02:00 PM | #5 |
07-16-2021, 03:59 PM | #6 |
Newbie Join Date: Jun 2007 Location: las vegas
still rolling on some smaller 2.2's |
07-19-2021, 08:10 AM | #7 |
| Re: any 2.2 comp rigs here? I have some old proline hammers 2.2. They are 2.2 rim and the advertised outer diameter is 4.9 but they sit smaller than my Hyrax 4.75. I liked them until I got my Hyrax broke in. BUt the 2.2 Hyrax were so big. I did use the hammers on courses where I thought side hill maybe be an issue because the Hyrax 2.2 were so large. Ounce I went to the LCG chassis, played around tuning the suspension, electronics placement and weight (distribution and loosing weight) and were I sat my chassis (within my sup travel) the lager Hyrax were no longer an issue when side hilling. EDIT: 27 July Back to the smaller Hammers Last edited by MOguy; 07-27-2021 at 06:24 AM. |
07-24-2021, 06:05 PM | #8 |
Pebble Pounder Join Date: Dec 2008 Location: Close
Sorta 2.2...its on xr width axles, 2.2 wheels, and custom 2.2 tires. |
07-28-2021, 04:51 PM | #9 | |
07-29-2021, 06:22 AM | #10 | |
I have Hyrax on my C1 and C2. The big Hyrax do great except on steep side hills. If I fall off a side hill it is usually 10 points if I go out of bounds or can't drive back on my wheels and need a Hand of God. Even then I there is a good chance I will flip again. Last comp had a sidehill I couldn't work around. I had a perfect score until then. I never could get it and timed out. Other were not having as much of an issue. I had let someone borrow my Hammers and they had no issues. The shorter tires MAY? get me high centered but I can reverse (one point) or winch or bungee pull (bungee still good at the places I comp) and only 3 points. I do like how the Proline hammers perform and I am on portals. My next comp is on the 8th. I am excited to see how they do. My at home testing has be excited. I did some body trimming after this photo and I probably need some sliders. Last edited by MOguy; 07-29-2021 at 06:27 AM. | |
any 2.2 comp rigs here? - Similar Threads | ||||
Best way to get into comp rigs | WildsideVT | Newbie General | 11 | 02-04-2021 08:05 PM |
Comp rigs | lowridinjuggalo | North Carolina | 0 | 10-04-2016 12:57 PM |
Pro Comp Rigs on Comp Courses | Harvo | Videos! | 9 | 01-08-2015 11:23 PM |
